[PATCH] Change module imports
    Sebastian Huber
    Fri Feb  8 07:31:54 UTC 2019
 book/wscript             |  3 +--
 bsp-howto/wscript        | 18 +++++++-----------
 c-user/wscript           | 18 +++++++-----------
 cpu-supplement/wscript   | 18 +++++++-----------
 develenv/wscript         | 18 +++++++-----------
 eclipse/wscript          | 18 +++++++-----------
 eng/wscript              | 18 +++++++-----------
 filesystem/wscript       | 18 +++++++-----------
 images/wscript           | 10 +++-------
 networking/wscript       | 18 +++++++-----------
 porting/wscript          | 18 +++++++-----------
 posix-compliance/wscript | 18 +++++++-----------
 posix-users/wscript      | 18 +++++++-----------
 rtemsconfig/wscript      | 18 +++++++-----------
 shell/wscript            | 18 +++++++-----------
 wscript                  |  6 ++----
 17 files changed, 104 insertions(+), 167 deletions(-)
diff --git a/book/wscript b/book/wscript
index 0503604..5488b9b 100644
--- a/book/wscript
+++ b/book/wscript
@@ -1,8 +1,7 @@
 from sys import path
 from os.path import abspath, exists
-path.append(abspath('../common/'))
-from waf import cmd_configure_path, cmd_build_path, cmd_options_path, spell, cmd_spell
+from common.waf import cmd_configure_path, cmd_build_path, cmd_options_path, spell, cmd_spell
 def options(ctx):
diff --git a/bsp-howto/wscript b/bsp-howto/wscript
index 26ab0ca..4063cd4 100644
--- a/bsp-howto/wscript
+++ b/bsp-howto/wscript
@@ -1,11 +1,7 @@
-from sys import path
-from os.path import abspath
-from waf import cmd_configure as configure
-from waf import cmd_build as build
-from waf import cmd_options as options
-from waf import spell
-from waf import cmd_spell
-from waf import linkcheck
-from waf import cmd_linkcheck
+from common.waf import cmd_configure as configure
+from common.waf import cmd_build as build
+from common.waf import cmd_options as options
+from common.waf import spell
+from common.waf import cmd_spell
+from common.waf import linkcheck
+from common.waf import cmd_linkcheck
diff --git a/c-user/wscript b/c-user/wscript
--- a/c-user/wscript
+++ b/c-user/wscript
@@ -1,11 +1,7 @@
diff --git a/cpu-supplement/wscript b/cpu-supplement/wscript
--- a/cpu-supplement/wscript
+++ b/cpu-supplement/wscript
@@ -1,11 +1,7 @@
diff --git a/develenv/wscript b/develenv/wscript
--- a/develenv/wscript
+++ b/develenv/wscript
@@ -1,11 +1,7 @@
diff --git a/eclipse/wscript b/eclipse/wscript
--- a/eclipse/wscript
+++ b/eclipse/wscript
@@ -1,11 +1,7 @@
diff --git a/eng/wscript b/eng/wscript
--- a/eng/wscript
+++ b/eng/wscript
@@ -1,11 +1,7 @@
diff --git a/filesystem/wscript b/filesystem/wscript
--- a/filesystem/wscript
+++ b/filesystem/wscript
@@ -1,11 +1,7 @@
diff --git a/images/wscript b/images/wscript
index 41a9308..179938b 100644
--- a/images/wscript
+++ b/images/wscript
@@ -1,7 +1,3 @@
-from waf import cmd_build_images as build
+from common.waf import cmd_build_images as build
diff --git a/networking/wscript b/networking/wscript
--- a/networking/wscript
+++ b/networking/wscript
@@ -1,11 +1,7 @@
diff --git a/porting/wscript b/porting/wscript
--- a/porting/wscript
+++ b/porting/wscript
@@ -1,11 +1,7 @@
diff --git a/posix-compliance/wscript b/posix-compliance/wscript
index 376ee76..eae2174 100644
--- a/posix-compliance/wscript
+++ b/posix-compliance/wscript
@@ -1,14 +1,10 @@
-from waf import cmd_build as doc_build
+from common.waf import cmd_build as doc_build
 import posix_rst
diff --git a/posix-users/wscript b/posix-users/wscript
--- a/posix-users/wscript
+++ b/posix-users/wscript
@@ -1,11 +1,7 @@
diff --git a/rtemsconfig/wscript b/rtemsconfig/wscript
--- a/rtemsconfig/wscript
+++ b/rtemsconfig/wscript
@@ -1,11 +1,7 @@
diff --git a/shell/wscript b/shell/wscript
--- a/shell/wscript
+++ b/shell/wscript
@@ -1,11 +1,7 @@
diff --git a/user/wscript b/user/wscript
--- a/user/wscript
+++ b/user/wscript
@@ -1,11 +1,7 @@
diff --git a/wscript b/wscript
index 32cca2a..dab736f 100644
--- a/wscript
+++ b/wscript
@@ -5,11 +5,9 @@
 import sys
 import os.path
-sys.path.append(os.path.abspath('common'))
 import waflib
-import waf as docs_waf
-import version
+from common import waf as docs_waf
+from common import version
 # Branch version
2.16.4
