[rtems commit] psxtests: Remove bogus file
Tue Feb 12 12:33:54 UTC 2019
Is this file present with a .c extension?
This is a math.h method and there should be a test verifying the prototype
is correct.
On Tue, Feb 12, 2019, 3:27 AM Sebastian Huber <sebh at rtems.org wrote:
> Module:    rtems
> Branch:    master
> Commit:    7fdcd02338a5d58122105e3bcd41ed9b8cd184e8
> Changeset:
> http://git.rtems.org/rtems/commit/?id=7fdcd02338a5d58122105e3bcd41ed9b8cd184e8
> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date:      Tue Feb 12 10:26:34 2019 +0100
> This file is unused and makes trouble on Windows.
> Updates #3638.
>  testsuites/psxtests/psxhdrs/math/expm1. | 38
>  1 file changed, 38 deletions(-)
> diff --git a/testsuites/psxtests/psxhdrs/math/expm1.
> b/testsuites/psxtests/psxhdrs/math/expm1.
> deleted file mode 100644
> index bef42e1..0000000
> --- a/testsuites/psxtests/psxhdrs/math/expm1.
> +++ /dev/null
> @@ -1,38 +0,0 @@
> - *  @file
> - *  @brief exp() API Conformance Test
> -  *  COPYRIGHT (c) 2018.
> -  *  Shashvat Jain
> -  *  Permission to use, copy, modify, and/or distribute this software
> -  *  for any purpose with or without fee is hereby granted.
> -  *  THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
> -  *  WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
> -  *  WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE
> AUTHOR
> -  *  BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
> -  *  OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR
> PROFITS,
> -  *  WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS
> ACTION,
> -  *  ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
> SOFTWARE.
> -#ifdef HAVE_CONFIG_H
> -#include "config.h"
> -#endif
> -#include <math.h>
> -int test( void );
> -int test( void )
> -  double x = 0 ;
> -  double result ;
> -  result = expm1(x) ;
> -  return (result);
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190212/8efadd4a/attachment.html>
