[PATCH] score: Avoid some deadlocks in _Once()
Tue Feb 12 12:45:41 UTC 2019
Recursive usage of the same pthread_once_t results now in a deadlock.
Previously, an error of EINVAL was returned.  This usage scenario is
invalid according to the POSIX pthread_once() specification.
Close #3334.
 cpukit/include/rtems/score/onceimpl.h       |  10 ++-
 cpukit/rtems/src/timerserver.c              |   5 +-
 cpukit/score/src/once.c                     | 117 ++++++++++++++++++----------
 testsuites/psxtests/psxonce01/init.c        |  82 ++++++++++++++++---
 testsuites/psxtests/psxonce01/psxonce01.scn |  15 ++--
 testsuites/psxtests/psxonce01/system.h      |   2 +-
 testsuites/sptests/spcxx01/init.cc          |  21 ++++-
 testsuites/sptests/spcxx01/spcxx01.doc      |   2 +
 8 files changed, 183 insertions(+), 71 deletions(-)
diff --git a/cpukit/include/rtems/score/onceimpl.h b/cpukit/include/rtems/score/onceimpl.h
index 60f1378506..f3afe1cd13 100644
--- a/cpukit/include/rtems/score/onceimpl.h
+++ b/cpukit/include/rtems/score/onceimpl.h
@@ -7,7 +7,7 @@
- * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2014, 2019 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -23,6 +23,8 @@
 #ifndef _RTEMS_ONCE_H
 #define _RTEMS_ONCE_H
+#include <rtems/score/thread.h>
 #ifdef __cplusplus
 extern "C" {
 #endif /* __cplusplus */
@@ -37,11 +39,11 @@ extern "C" {
-int _Once( unsigned char *once_state, void (*init_routine)(void) );
+int _Once( unsigned char *once_state, void ( *init_routine )( void ) );
-void _Once_Lock( void );
+Thread_Life_state _Once_Lock( void );
-void _Once_Unlock( void );
+void _Once_Unlock( Thread_Life_state thread_life_state );
diff --git a/cpukit/rtems/src/timerserver.c b/cpukit/rtems/src/timerserver.c
index 09e792aa1c..55c3d96b9b 100644
--- a/cpukit/rtems/src/timerserver.c
+++ b/cpukit/rtems/src/timerserver.c
@@ -228,10 +228,11 @@ rtems_status_code rtems_timer_initiate_server(
   rtems_status_code status;
+  Thread_Life_state thread_life_state;
-  _Once_Lock();
+  thread_life_state = _Once_Lock();
   status = _Timer_server_Initiate( priority, stack_size, attribute_set );
-  _Once_Unlock();
+  _Once_Unlock( thread_life_state );
   return status;
diff --git a/cpukit/score/src/once.c b/cpukit/score/src/once.c
index 5237c11878..5df44c96e7 100644
--- a/cpukit/score/src/once.c
+++ b/cpukit/score/src/once.c
@@ -1,68 +1,99 @@
- *  COPYRIGHT (c) 1989-1999.
- *  On-Line Applications Research Corporation (OAR).
+ * SPDX-License-Identifier: BSD-2-Clause
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * Copyright (C) 2019 embedded brains GmbH
+ * Copyright (C) 2019 Sebastian Huber
+ * are met:
 #ifdef HAVE_CONFIG_H
-  #include "config.h"
+#include "config.h"
 #endif
 #include <rtems/score/onceimpl.h>
-#include <rtems/score/apimutex.h>
+#include <rtems/score/threadimpl.h>
+#include <rtems/thread.h>
+#define ONCE_STATE_INIT 0
-#include <errno.h>
+#define ONCE_STATE_RUNNING 1
-#define ONCE_STATE_NOT_RUN  0
-#define ONCE_STATE_RUNNING  1
 #define ONCE_STATE_COMPLETE 2
+typedef struct {
+  rtems_mutex              Mutex;
+  rtems_condition_variable State;
+} Once_Control;
+static Once_Control _Once_Information = {
+  .Mutex = RTEMS_MUTEX_INITIALIZER( "_Once" ),
+  .State = RTEMS_CONDITION_VARIABLE_INITIALIZER( "_Once" )
-  int eno = 0;
-  if ( *once_state != ONCE_STATE_COMPLETE ) {
-    _Once_Lock();
-     * Getting to here means the once_control is locked so we have:
-     *  1. The init has not run and the state is ONCE_STATE_NOT_RUN.
-     *  2. The init has finished and the state is ONCE_STATE_COMPLETE (already
-     *     caught by the previous if).
-     *  3. The init is being run by this thread and the state
-     *     ONCE_STATE_RUNNING so we are nesting. This is an error.
-    switch ( *once_state ) {
-      case ONCE_STATE_NOT_RUN:
-        *once_state = ONCE_STATE_RUNNING;
-        ( *init_routine )();
-        *once_state = ONCE_STATE_COMPLETE;
-        break;
-      case ONCE_STATE_RUNNING:
-        eno = EINVAL;
-        break;
-      default:
-        break;
+  _Atomic_Fence( ATOMIC_ORDER_ACQUIRE );
+  if ( RTEMS_PREDICT_FALSE( *once_state != ONCE_STATE_COMPLETE ) ) {
+    if ( *once_state == ONCE_STATE_INIT ) {
+      *once_state = ONCE_STATE_RUNNING;
+      ( *init_routine )();
+      _Atomic_Fence( ATOMIC_ORDER_RELEASE );
+      *once_state = ONCE_STATE_COMPLETE;
+      rtems_condition_variable_broadcast( &_Once_Information.State );
+    } else {
+      while ( *once_state != ONCE_STATE_COMPLETE ) {
+        rtems_condition_variable_wait(
+          &_Once_Information.State,
+          &_Once_Information.Mutex
-    _Once_Unlock();
-  return eno;
+  return 0;
-static API_Mutex_Control _Once_Mutex = API_MUTEX_INITIALIZER( "_Once" );
-  _API_Mutex_Lock( &_Once_Mutex );
+  thread_life_state = _Thread_Set_life_protection( THREAD_LIFE_PROTECTED );
+  rtems_mutex_lock( &_Once_Information.Mutex );
+  return thread_life_state;
-  _API_Mutex_Unlock( &_Once_Mutex );
+  rtems_mutex_unlock( &_Once_Information.Mutex );
+  _Thread_Set_life_protection( thread_life_state );
diff --git a/testsuites/psxtests/psxonce01/init.c b/testsuites/psxtests/psxonce01/init.c
index 1c90769d38..41ff5b146b 100644
--- a/testsuites/psxtests/psxonce01/init.c
+++ b/testsuites/psxtests/psxonce01/init.c
@@ -1,4 +1,7 @@
  *  COPYRIGHT (c) 1989-2009.
@@ -16,16 +19,11 @@
 const char rtems_test_name[] = "PSXONCE 1";
-static pthread_once_t nesting_once = PTHREAD_ONCE_INIT;
+static pthread_once_t once_a = PTHREAD_ONCE_INIT;
-static void Test_init_routine_nesting( void )
-  int status;
-  puts( "Test_init_routine_nesting: invoked" );
-  puts( "Test_init_routine_nesting: pthread_once - EINVAL (init_routine_nesting does not execute)" );
-  status = pthread_once( &nesting_once, Test_init_routine_nesting );
-  rtems_test_assert( status == EINVAL );
+static pthread_once_t once_b = PTHREAD_ONCE_INIT;
+static rtems_id master;
 static int test_init_routine_call_counter = 0;
@@ -35,6 +33,66 @@ static void Test_init_routine( void )
   ++test_init_routine_call_counter;
+static void routine_b( void )
+  rtems_status_code sc;
+  rtems_test_assert( test_init_routine_call_counter == 2 );
+  ++test_init_routine_call_counter;
+  sc = rtems_event_send( master, RTEMS_EVENT_0 );
+  rtems_test_assert( sc == RTEMS_SUCCESSFUL );
+static void use_b( rtems_task_argument arg )
+  int status;
+  (void) arg;
+  status = pthread_once( &once_b, routine_b );
+  rtems_test_assert( status == 0 );
+  rtems_task_exit();
+static void routine_a( void )
+  rtems_id id;
+  rtems_event_set events;
+  rtems_test_assert( test_init_routine_call_counter == 1 );
+  master = rtems_task_self();
+  sc = rtems_task_create(
+    rtems_build_name( 'T', 'A', 'S', 'K' ),
+    RTEMS_MINIMUM_PRIORITY,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &id
+  assert(sc == RTEMS_SUCCESSFUL);
+  sc = rtems_task_start( id, use_b, 0 );
+  assert( sc == RTEMS_SUCCESSFUL );
+  events = 0;
+  sc = rtems_event_receive(
+    RTEMS_EVENT_0,
+    RTEMS_EVENT_ANY | RTEMS_WAIT,
+    RTEMS_NO_TIMEOUT,
+    &events
+  rtems_test_assert( events == RTEMS_EVENT_0 );
+  rtems_test_assert( test_init_routine_call_counter == 3 );
 rtems_task Init(rtems_task_argument argument)
   int status;
@@ -62,9 +120,9 @@ rtems_task Init(rtems_task_argument argument)
   printf( "Init: call counter: %d\n", test_init_routine_call_counter );
-  puts( "Init: pthread_once - SUCCESSFUL (init_routine_nesting executes)" );
-  rtems_test_assert( !status );
+  status = pthread_once( &once_a, routine_a );
   TEST_END();
   rtems_test_exit( 0 );
diff --git a/testsuites/psxtests/psxonce01/psxonce01.scn b/testsuites/psxtests/psxonce01/psxonce01.scn
index 2c5d47d2d1..a7afa154cb 100644
--- a/testsuites/psxtests/psxonce01/psxonce01.scn
+++ b/testsuites/psxtests/psxonce01/psxonce01.scn
@@ -1,11 +1,14 @@
-*** TEST POSIX ONCE 01 ***
-Init: pthread_once - SUCCESSFUL (init_routine_nesting executes)
-Test_init_routine_nesting: invoked
+*** BEGIN OF TEST PSXONCE 1 ***
+*** TEST VERSION: 5.0.0.e214ff4b636011bd149e3683c89aa982e361fd1c
+*** TEST STATE: EXPECTED-PASS
+*** TEST BUILD:
+*** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB c41b9d0df7e5b4a5056ca50c2534380a44e92769, Newlib 3e24fbf6f)
 Init: pthread_once - EINVAL (NULL once_control)
 Init: pthread_once - EINVAL (NULL init_routine)
 Init: pthread_once - SUCCESSFUL (init_routine executes)
 Test_init_routine: invoked
+Init: call counter: 1
 Init: pthread_once - SUCCESSFUL (init_routine does not execute)
-*** END OF TEST POSIX ONCE 01 ***
+*** END OF TEST PSXONCE 1 ***
diff --git a/testsuites/psxtests/psxonce01/system.h b/testsuites/psxtests/psxonce01/system.h
index 10d611b86d..fe95285d5f 100644
--- a/testsuites/psxtests/psxonce01/system.h
+++ b/testsuites/psxtests/psxonce01/system.h
@@ -21,7 +21,7 @@
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_TASKS 2
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/sptests/spcxx01/init.cc b/testsuites/sptests/spcxx01/init.cc
index 7962810da0..9443cd0f73 100644
--- a/testsuites/sptests/spcxx01/init.cc
+++ b/testsuites/sptests/spcxx01/init.cc
@@ -29,6 +29,7 @@
 #include "config.h"
 #endif
+#include <future>
 #include <new>
@@ -41,10 +42,8 @@ struct alignas(256) S {
   int i;
-extern "C" void Init(rtems_task_argument arg)
+static void test_aligned_new(void)
-  TEST_BEGIN();
   int *i = static_cast<decltype(i)>(
     ::operator new(sizeof(*i), std::align_val_t(256))
@@ -58,6 +57,20 @@ extern "C" void Init(rtems_task_argument arg)
   rtems_test_assert(s != nullptr);
   rtems_test_assert(reinterpret_cast<uintptr_t>(s) % 256 == 0);
   delete s;
+static void test_future(void)
+  std::future<bool> f = std::async(std::launch::async, []{ return true; });
+  f.get();
+extern "C" void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  test_aligned_new();
+  test_future();
   TEST_END();
   exit(0);
@@ -69,6 +82,8 @@ extern "C" void Init(rtems_task_argument arg)
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 1
diff --git a/testsuites/sptests/spcxx01/spcxx01.doc b/testsuites/sptests/spcxx01/spcxx01.doc
index 669e6820ab..73e6a3f83a 100644
--- a/testsuites/sptests/spcxx01/spcxx01.doc
+++ b/testsuites/sptests/spcxx01/spcxx01.doc
@@ -5,7 +5,9 @@ test set name: spcxx01
 directives:
   - ::operator new()
+  - std::async()
 concepts:
   - Ensure that the aligned new operator works.
+  - Ensure that std::async() works.
2.16.4
