[PATCH 1/2] README.txt: Fix typos
    Joel Sherrill
    joel at rtems.org
    Wed Feb 13 22:17:49 UTC 2019
 README.txt | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/README.txt b/README.txt
index d9fc4a6..b1a5978 100644
--- a/README.txt
+++ b/README.txt
@@ -31,7 +31,7 @@ We allow the building of PDF documentation on hosts that do not have a fully
 suitable texlive environment and this results in quality that is not at the
 production level.
-The hosts which produce production quality is:
+The hosts which produce production quality are:
  FreeBSD
  CentOS 6 and 7 (if using texlive, not RPMs of texlive)
@@ -79,7 +79,7 @@ Host Setup
 HTML builds directly with Sphinx, PDF requires a full Latex (texlive) install,
 and building a Single HTML page requires the 'inliner' tool. The
 sphinxcontrib-bibtex extension is mandatory. PlantUML requres the Node.js
-package called 'nde-plantuml' which installs the 'puml' command and Ditaa needs
+package called 'node-plantuml' which installs the 'puml' command and Ditaa needs
 the 'ditaa' command and package. Ditaa images are built using the 'puml'
 command.
1.8.3.1
