Issue in fileio.exe
Vaibhav Gupta vaibhavgupta40 at gmail.com
Wed Feb 20 07:42:50 UTC 2019
Hello,
I am new to developer community of RTEMS.
To start with, I have got RTEMS successfully built and executed hello world
program, as directed on:   https://devel.rtems.org/wiki/GSoC/GettingStarted
I was going through documentation and did try to execute:
$HOME//development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites/samples/fileio.exe
The output is:
[varodek at varodek samples]$ time sparc-rtems5-run fileio.exe
*** BEGIN OF TEST FILE I/O ***
*** TEST VERSION: 5.0.0.03fcbb15d24e2eec41bac9f5dee30bbf7dc888b8
*** TEST STATE: USER_INPUT
*** TEST BUILD: RTEMS_POSIX_API
*** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB
c41b9d0df7e5b4a5056ca50c2534380a44e92769, Newlib 3e24fbf6f)
Press any key to start file I/O sample (20s remaining)
Press any key to start file I/O sample (19s remaining)
Press any key to start file I/O sample (18s remaining)
Press any key to start file I/O sample (17s remaining)
Press any key to start file I/O sample (16s remaining)
Press any key to start file I/O sample (15s remaining)
Press any key to start file I/O sample (14s remaining)
Press any key to start file I/O sample (13s remaining)
Press any key to start file I/O sample (12s remaining)
Press any key to start file I/O sample (11s remaining)
Press any key to start file I/O sample (10s remaining)
Press any key to start file I/O sample (9s remaining)
Press any key to start file I/O sample (8s remaining)
Press any key to start file I/O sample (7s remaining)
Press any key to start file I/O sample (6s remaining)
Press any key to start file I/O sample (5s remaining)
Press any key to start file I/O sample (4s remaining)
Press any key to start file I/O sample (3s remaining)
Press any key to start file I/O sample (2s remaining)
Press any key to start file I/O sample (1s remaining)
*** END OF TEST FILE I/O ***
*** FATAL ***
fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
fatal code: 0 (0x00000000)
RTEMS version: 5.0.0.03fcbb15d24e2eec41bac9f5dee30bbf7dc888b8
RTEMS tools: 7.4.0 20181206 (RTEMS 5, RSB
executing thread ID: 0x08a0
real    0m0.463s
user    0m0.385s
After the begin test  header, 6th line states:
indicating the program should run for at least 20 secs, but it got
terminated only in
real    0m0.463s
user    0m0.385s
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190220/9bea9c5e/attachment.html>
