Issue in fileio.exe
Wed Feb 20 07:47:10 UTC 2019
On 20/02/2019 08:42, Vaibhav Gupta wrote:
> After the begin test  header, 6th line states:
> Press any key to start file I/O sample (20s remaining)
> indicating the program should run for at least 20 secs, but it got
> terminated only in
> real 0m0.463s
> user    0m0.385s
This BSP has a special device driver which is able to locally modify the
flow of time. If there is nothing to do then the clock tick interrupt
simply advances to the next clock tick. Search for
CLOCK_DRIVER_USE_FAST_IDLE in the RTEMS sources.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
