'pax' is missing from list of required-packages, for host setup, for Arch Linux, in the documentation
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Fri Feb 22 01:32:45 UTC 2019
Okay, but then we should mention it in the documentation, Host setup for
Arch Linux.
Else, without this package the BSP build fails for the scenario I mentioned.
On Fri, 22 Feb, 2019, 2:42 AM Chris Johns <chrisj at rtems.org wrote:
> On 22/2/19 8:04 am, Joel Sherrill wrote:
> > On Thu, Feb 21, 2019, 3:00 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> > On 22/2/19 1:25 am, Vaibhav Gupta wrote:
> > > The *pax* package is not installed by default in Arch Linux.
> Moreover it
> > is also
> > > not present in its official repository. We need to clone, build
> and install it
> > > from Arch User Repository (AUR).
> > That seems unusual because it is defined here ..
> > https://aur.archlinux.org/packages/pax/ looks like a package to me. But
> I don't
> > use this distribution
> I would be fine with tar if we know all specific tar variant's works. I
> moved to
> pax because there were problems.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190222/e13f51fe/attachment-0001.html>
