'pax' is missing from list of required-packages, for host setup, for Arch Linux, in the documentation
Fri Feb 22 01:40:09 UTC 2019
On 22/2/19 12:32 pm, Vaibhav Gupta wrote:
> Okay, but then we should mention it in the documentation, Host setup for Arch Linux.
> Else, without this package the BSP build fails for the scenario I mentioned.
Are you able to create a patch to update the docs?
Thanks
