'pax' is missing from list of required-packages, for host setup, for Arch Linux, in the documentation
Fri Feb 22 07:32:14 UTC 2019
On 21/02/2019 22:01, Chris Johns wrote:
> On 22/2/19 1:25 am, Vaibhav Gupta wrote:
>> The *pax* package is not installed by default in Arch Linux. Moreover it is also
>> not present in its official repository. We need to clone, build and install it
>> from Arch User Repository (AUR).
> That seems unusual because it is defined here ..
> https://pubs.opengroup.org/onlinepubs/009695399/utilities/pax.html
It is not installed by default on all Linux distributions I worked with.
Maybe we should just check in the archive used by the test suite and not
use pax at all. We want to test RTEMS and not the host pax program.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
