Conversion of BSP config files to pkg-config files
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Feb 24 19:57:32 UTC 2019
Hi,
In an attempt to read all the files, I wrote a parser to try to put them
all in one place.
I'm attaching the parser, the generated data and the list of files that
could not be parsed because they use `defines`.
Is this data any helpful?
Is this the right way forward?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190225/a18b6c09/attachment-0001.html>
sparc/leon3/config/gr740.cfg
sparc/leon3/config/gr712rc.cfg
lm32/lm32_evr/config/lm32_evr.cfg
lm32/milkymist/config/milkymist.cfg
powerpc/motorola_powerpc/config/mvme2307.cfg
powerpc/motorola_powerpc/config/qemuprep.cfg
powerpc/motorola_powerpc/config/mtx603e.cfg
powerpc/motorola_powerpc/config/qemuprep-altivec.cfg
powerpc/motorola_powerpc/config/mvme2100.cfg
powerpc/motorola_powerpc/config/mcp750.cfg
powerpc/qemuppc/config/qemuppc.cfg
powerpc/mvme5500/config/mvme5500.cfg
powerpc/beatnik/config/beatnik.cfg
powerpc/mvme3100/config/mvme3100.cfg
powerpc/virtex4/config/virtex4.cfg
powerpc/virtex5/config/virtex5.cfg
powerpc/haleakala/config/haleakala.cfg
powerpc/virtex/config/virtex.cfg
powerpc/ss555/config/ss555.cfg
nios2/nios2_iss/config/nios2_iss.cfg
m68k/mcf5225x/config/mcf5225x.cfg
m68k/mvme167/config/mvme167.cfg
m68k/uC5282/config/uC5282.cfg
m68k/mcf5235/config/mcf5235.cfg
m68k/mvme162/config/mvme162lx.cfg
m68k/mvme162/config/mvme162.cfg
m68k/mcf52235/config/mcf52235.cfg
m68k/av5282/config/av5282.cfg
m68k/mcf5329/config/mcf5329.cfg
mips/rbtx4938/config/rbtx4938.cfg
or1k/generic_or1k/sim.cfg
i386/pc386/config/pc386.cfg
arm/csb337/config/kit637_v6.cfg
arm/lpc176x/config/lpc1768_mbed.cfg
arm/beagle/simscripts/bbxm.cfg
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190225/a18b6c09/attachment-0001.obj>
Type: application/zip
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190225/a18b6c09/attachment-0001.zip>
