[PATCH] libdebugger: Fix for ARMv7-M with -O0 optimization
Sebastian Huber
Mon Feb 25 12:47:19 UTC 2019
cpukit/libdebugger/rtems-debugger-arm.c | 14 +++++---------
1 file changed, 5 insertions(+), 9 deletions(-)
diff --git a/cpukit/libdebugger/rtems-debugger-arm.c b/cpukit/libdebugger/rtems-debugger-arm.c
index 722dd54924..95e26ada76 100644
--- a/cpukit/libdebugger/rtems-debugger-arm.c
+++ b/cpukit/libdebugger/rtems-debugger-arm.c
@@ -439,6 +439,7 @@ arm_debug_break_write_control(int bp, uint32_t control)
+#if ARM_CP15
static void
arm_debug_break_write_value(int bp, uint32_t value)
@@ -493,6 +494,7 @@ arm_debug_break_write_value(int bp, uint32_t value)
break;
+#endif
static void
arm_debug_break_clear(void)
@@ -514,6 +516,7 @@ arm_debug_set_context_id(const uint32_t id)
ARM_CP15_WRITE(id, 0, 13, 0, 1);
+#if ARM_CP15
* You can only load the hardware breaks points when in the SVC mode or the
* single step inverted break point will trigger.
@@ -540,6 +543,7 @@ arm_debug_break_load(void)
rtems_interrupt_lock_release(&target_lock, &lock_context);
+#endif
static void
arm_debug_break_unload(void)
@@ -583,6 +587,7 @@ rtems_debugger_target_configure(rtems_debugger_target* target)
return arm_debug_probe(target);
+#if ARM_CP15
static void
target_exception(CPU_Exception_frame* frame)
@@ -938,7 +943,6 @@ target_exception_data_abort(void)
EXCEPTION_EXIT_EXC();
-#if ARM_CP15
* The init value for the text section.
@@ -975,14 +979,6 @@ rtems_debugger_target_set_vectors(void)
* Dummy, please add support for your ARM variant.
- void* ui = target_exception_undefined_instruction;
- void* sc = target_exception_supervisor_call;
- void* pa = target_exception_prefetch_abort;
- void* da = target_exception_data_abort;
- (void) ui;
- (void) sc;
- (void) pa;
- (void) da;
#endif
2.16.4
