[PATCH 1/2] arm/beagle: SPI driver
Pierre-Louis Garnier garnie_a at epita.fr
Mon Feb 25 22:30:09 UTC 2019
 bsps/arm/beagle/headers.am              |   1 +
 bsps/arm/beagle/include/bsp.h           |   4 +-
 bsps/arm/beagle/include/bsp/spi.h       | 144 +++++++
 bsps/arm/beagle/spi/spi.c               | 535 ++++++++++++++++++++++++
 bsps/arm/include/libcpu/am335x.h        |  93 +++-
 c/src/lib/libbsp/arm/beagle/Makefile.am |   3 +
 6 files changed, 778 insertions(+), 2 deletions(-)
 create mode 100644 bsps/arm/beagle/include/bsp/spi.h
 create mode 100644 bsps/arm/beagle/spi/spi.c
diff --git a/bsps/arm/beagle/headers.am b/bsps/arm/beagle/headers.am
index 6692d0b69c..4dc35f2e2a 100644
--- a/bsps/arm/beagle/headers.am
+++ b/bsps/arm/beagle/headers.am
@@ -12,3 +12,4 @@ include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/bbb-pwm.h
 include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/beagleboneblack.h
 include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/i2c.h
 include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/irq.h
+include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/spi.h
diff --git a/bsps/arm/beagle/include/bsp.h b/bsps/arm/beagle/include/bsp.h
index f394c84157..7767456a8e 100644
--- a/bsps/arm/beagle/include/bsp.h
+++ b/bsps/arm/beagle/include/bsp.h
@@ -52,7 +52,9 @@
 #define REG16(x)(*((volatile uint16_t *)(x)))
 #define REG(x)(*((volatile uint32_t *)(x)))
-#define BIT(x)(0x1 << x)
+#define BIT(x)(0x1 << (x))
+// Start and End included
+#define BITS(Start, End) (((1 << (End+1)) - 1) & ~((1 << (Start)) - 1))
 #define udelay(u) rtems_task_wake_after(1 + ((u)/rtems_configuration_get_microseconds_per_tick()))
diff --git a/bsps/arm/beagle/include/bsp/spi.h b/bsps/arm/beagle/include/bsp/spi.h
new file mode 100644
index 0000000000..ffda7edf60
--- /dev/null
+++ b/bsps/arm/beagle/include/bsp/spi.h
@@ -0,0 +1,144 @@
+ * @file
+ * @ingroup arm_beagle
+ * @brief SPI support API.
+ * Based on bsps/m68k/gen68360/spi/m360_spi.h
+ * Copyright (c) 2018 Pierre-Louis Garnier <garnie_a at epita.fr>
+#ifndef LIBBSP_ARM_BEAGLE_SPI_H
+#define LIBBSP_ARM_BEAGLE_SPI_H
+#include <bsp.h>
+#include <rtems/libi2c.h>
+#include <rtems/irq.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#define BBB_SPI_TIMEOUT 1000
+#define BBB_SPI_0_BUS_PATH "/dev/spi-0"
+#define BBB_SPI_0_IRQ AM335X_INT_SPI0INT
+typedef enum {
+  SPI0,
+  SPI1,
+  SPI_COUNT
+} bbb_spi_id_t;
+typedef struct BEAGLE_SPI_BufferDescriptor_ {
+    unsigned short      status;
+    unsigned short      length;
+    volatile void       *buffer;
+} BEAGLE_SPI_BufferDescriptor_t;
+typedef struct beagle_spi_softc {
+  int                     initialized;
+  rtems_id                task_id;
+  uintptr_t               regs_base;
+  rtems_vector_number     irq;
+} beagle_spi_softc_t;
+typedef struct {
+  rtems_libi2c_bus_t  bus_desc;
+  beagle_spi_softc_t softc;
+} beagle_spi_desc_t;
+ * Initialize the driver
+ * Returns: o = ok or error code
+rtems_status_code beagle_spi_init
+ rtems_libi2c_bus_t *bh                  /* bus specifier structure        */
+ * Receive some bytes from SPI device
+ * Returns: number of bytes received or (negative) error code
+int beagle_spi_read_bytes
+ rtems_libi2c_bus_t *bh,                 /* bus specifier structure        */
+ unsigned char *buf,                     /* buffer to store bytes          */
+ int len                                 /* number of bytes to receive     */
+ * Send some bytes to SPI device
+ * Returns: number of bytes sent or (negative) error code
+int beagle_spi_write_bytes
+ unsigned char *buf,                     /* buffer to send                 */
+ int len                                 /* number of bytes to send        */
+ * Set SPI to desired baudrate/clock mode/character mode
+ * Returns: rtems_status_code
+rtems_status_code beagle_spi_set_tfr_mode
+ const rtems_libi2c_tfr_mode_t *tfr_mode /* transfer mode info             */
+ * Perform selected ioctl function for SPI
+int beagle_spi_ioctl
+ int                 cmd,                /* ioctl command code             */
+ void               *arg                 /* additional argument array      */
+ * Register SPI bus and devices
+ * Returns: Bus number or error code
+rtems_status_code bsp_register_spi
+  const char         *bus_path,
+  uintptr_t           register_base,
+static inline rtems_status_code bbb_register_spi_0(void)
+  return bsp_register_spi(
+    BBB_SPI_0_BUS_PATH,
+    AM335X_SPI0_BASE,
+    BBB_SPI_0_IRQ
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_BEAGLE_SPI_H */
diff --git a/bsps/arm/beagle/spi/spi.c b/bsps/arm/beagle/spi/spi.c
index 0000000000..38c0a503e0
--- /dev/null
+++ b/bsps/arm/beagle/spi/spi.c
@@ -0,0 +1,535 @@
+ * @file
+ * @brief BeagleBoard SPI bus initialization and API Support.
+ * Based on bsps/m68k/gen68360/spi/m360_spi.c
+#include <bsp.h>
+#include <bsp/bbb-gpio.h>
+#include <bsp/spi.h>
+#include <errno.h>
+#include <rtems/bspIo.h>
+#include <rtems/error.h>
+#include <stdio.h>
+#include <stdlib.h>
+// #define DEBUG
+// #define TRACE
+#define EVENT_TXEMPTY     RTEMS_EVENT_0
+#define EVENT_RXFULL      RTEMS_EVENT_1
+static void SPI0ModuleClkConfig(void)
+  /* Writing to MODULEMODE field of AM335X_CM_PER_SPI0_CLKCTRL register. */
+  REG( AM335X_CM_PER_ADDR + AM335X_CM_PER_SPI0_CLKCTRL ) |=
+    AM335X_CM_PER_SPI0_CLKCTRL_MODULEMODE_ENABLE;
+  /* Waiting for MODULEMODE field to reflect the written value. */
+  while ( AM335X_CM_PER_SPI0_CLKCTRL_MODULEMODE_ENABLE !=
+          ( REG( AM335X_CM_PER_ADDR + AM335X_CM_PER_SPI0_CLKCTRL ) &
+            AM335X_CM_PER_SPI0_CLKCTRL_MODULEMODE ) )
+    continue;
+   * Waiting for IDLEST field in AM335X_CM_PER_SPI0_CLKCTRL
+   * register to attain desired value.
+  while ( ( AM335X_CM_PER_CONTROL_CLKCTRL_IDLEST_FUNC <<
+            AM335X_CM_PER_CONTROL_CLKCTRL_IDLEST_SHIFT ) !=
+            AM335X_CM_PER_CONTROL_CLKCTRL_IDLEST ) )
+    continue;
+static inline void am335x_spi_clear_irqstatus(uint32_t reg_base, uint32_t irqs)
+  REG(reg_base + AM335X_SPI_SYST) &= ~AM335X_SPI_SYST_SSB;
+  REG(reg_base + AM335X_SPI_IRQSTATUS) = irqs;
+static void am335x_spi0_pinmux(void)
+  REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_SCLK) =
+    (BBB_RXACTIVE | BBB_SLEWCTRL | BBB_PU_EN);
+  REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D0) =
+  REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D1) =
+  REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_CS0) =
+    (BBB_RXACTIVE | BBB_PU_EN);
+static void am335x_spi_reset(uint32_t reg_base)
+  int timeout = BBB_SPI_TIMEOUT;
+  REG(reg_base + AM335X_SPI_SYSCONFIG) |= AM335X_SPI_SYSCONFIG_SOFTRESET;
+  while ((REG(reg_base + AM335X_SPI_SYSSTATUS) & AM335X_SPI_SYSSTATUS_RESETDONE) == 0 && timeout--) {
+    if (timeout <= 0) {
+      puts("ERROR: Timeout in soft-reset\n");
+      return;
+    udelay(1000);
+static void beagle_spi_irq_handler(void *arg)
+  const uint32_t handled_irqs = AM335X_SPI_IRQSTATUS_TX0_EMPTY | AM335X_SPI_IRQSTATUS_RX0_FULL;
+  beagle_spi_softc_t *softc_ptr = arg;
+  rtems_status_code sc = -1;
+  uint32_t irq = 0;
+  uint32_t events = 0;
+  uint32_t tmp;
+  while ((tmp = (REG(softc_ptr->regs_base + AM335X_SPI_IRQSTATUS)) & handled_irqs) != 0) {
+    irq |= tmp;
+    am335x_spi_clear_irqstatus(softc_ptr->regs_base, tmp);
+#if defined(TRACE)
+    printk("beagle_spi_irq_handler: AM335X_SPI_IRQSTATUS = 0x%04lx\r\n", irq);
+#endif
+  if (irq & AM335X_SPI_IRQSTATUS_TX0_EMPTY) {
+#if defined(TRACE)
+    printk("beagle_spi_irq_handler: sending event TXEMPTY to task_id = %ld\r\n", softc_ptr->task_id);
+#endif
+    events |= EVENT_TXEMPTY;
+  if (irq & AM335X_SPI_IRQSTATUS_RX0_FULL) {
+#if defined(TRACE)
+    printk("beagle_spi_irq_handler: sending event RXFULL to task_id = %ld\r\n", softc_ptr->task_id);
+#endif
+    events |= EVENT_RXFULL;
+  sc = rtems_event_send(softc_ptr->task_id, events);
+  _Assert(sc == RTEMS_SUCCESSFUL);
+  (void)sc;
+/* Initialize the driver
+  beagle_spi_softc_t *softc_ptr = &(((beagle_spi_desc_t *)(bh))->softc);
+  rtems_status_code rc = RTEMS_SUCCESSFUL;
+#if defined(DEBUG)
+  printk("beagle_spi_init called...\r\n");
+#endif
+  SPI0ModuleClkConfig();
+  am335x_spi0_pinmux();
+  am335x_spi_reset(softc_ptr->regs_base);
+  REG(softc_ptr->regs_base + AM335X_SPI_MODULCTRL) &= ~AM335X_SPI_MODULCTRL_PIN34;
+  REG(softc_ptr->regs_base + AM335X_SPI_MODULCTRL) &= ~AM335X_SPI_MODULCTRL_MS; // Master mode
+  REG(softc_ptr->regs_base + AM335X_SPI_MODULCTRL) |= AM335X_SPI_MODULCTRL_SINGLE; // Single channel
+  REG(softc_ptr->regs_base + AM335X_SPI_MODULCTRL) &= ~AM335X_SPI_MODULCTRL_PIN34; // SPIEN is usedas a chip select
+  // REG(softc_ptr->regs_base + AM335X_SPI_MODULCTRL) |= (1 << 3); // Test mode
+  // REG(softc_ptr->regs_base + AM335X_SPI_SYST) |= AM335X_SPI_SYST_SPIEN_0; // Not sure about this
+  // REG(softc_ptr->regs_base + AM335X_SPI_SYST) |= AM335X_SPI_SYST_SPIDATDIR0; // Input
+  // REG(softc_ptr->regs_base + AM335X_SPI_SYST) &= ~AM335X_SPI_SYST_SPIDATDIR1; // Output
+  REG(softc_ptr->regs_base + AM335X_SPI_CH0CONF) &= ~AM335X_SPI_CH0CONF_TRM_MASK;
+  REG(softc_ptr->regs_base + AM335X_SPI_CH0CONF) |= AM335X_SPI_CH0CONF_DPE0;
+  REG(softc_ptr->regs_base + AM335X_SPI_CH0CONF) &= ~AM335X_SPI_CH0CONF_DPE1;
+  REG(softc_ptr->regs_base + AM335X_SPI_CH0CONF) &= ~AM335X_SPI_CH0CONF_IS;
+  // REG(softc_ptr->regs_base + AM335X_SPI_CH0CONF) |= AM335X_SPI_CH0CONF_FFEW;
+  // REG(softc_ptr->regs_base + AM335X_SPI_CH0CONF) |= AM335X_SPI_CH0CONF_FFER;
+  REG(softc_ptr->regs_base + AM335X_SPI_CH0CONF) |= AM335X_SPI_CH0CONF_WL(8 - 1);
+  REG(softc_ptr->regs_base + AM335X_SPI_CH0CONF) &= ~AM335X_SPI_CH0CONF_PHA;
+  REG(softc_ptr->regs_base + AM335X_SPI_CH0CONF) &= ~AM335X_SPI_CH0CONF_POL;
+  REG(softc_ptr->regs_base + AM335X_SPI_CH0CONF) |= AM335X_SPI_CH0CONF_EPOL;
+  REG(softc_ptr->regs_base + AM335X_SPI_CH0CONF) |= AM335X_SPI_CH0CONF_CLKD(0x1);
+  // Setup interrupt
+  rc = rtems_interrupt_handler_install(
+    softc_ptr->irq,
+    NULL,
+    RTEMS_INTERRUPT_UNIQUE,
+    (rtems_interrupt_handler)beagle_spi_irq_handler,
+    softc_ptr
+#if defined(DEBUG)
+  printk("beagle_spi_init done\r\n");
+#endif
+  if (rc == RTEMS_SUCCESSFUL) {
+    softc_ptr->initialized = TRUE;
+  return rc;
+static int beagle_spi_read_write_bytes(
+ unsigned char *rx_buf,                  /* buffer to store bytes          */
+ unsigned char *tx_buf,                  /* buffer to send                 */
+  rtems_status_code sc;
+  rtems_event_set received_events;
+#if defined(TRACE)
+  printk("beagle_spi_read_write_bytes called...\r\n");
+#endif
+  softc_ptr->task_id = rtems_task_self();
+  // Enable IRQs
+  if (rx_buf) {
+    am335x_spi_clear_irqstatus(softc_ptr->regs_base, AM335X_SPI_IRQSTATUS_RX0_FULL);
+    REG(softc_ptr->regs_base + AM335X_SPI_IRQENABLE) |= AM335X_SPI_IRQENABLE_RX0_FULL;
+  if (tx_buf) {
+    am335x_spi_clear_irqstatus(softc_ptr->regs_base, AM335X_SPI_IRQSTATUS_TX0_EMPTY);
+    REG(softc_ptr->regs_base + AM335X_SPI_IRQENABLE) |= AM335X_SPI_IRQENABLE_TX0_EMPTY;
+  // Enable Channel
+  REG(softc_ptr->regs_base + AM335X_SPI_CH0CONF) |= AM335X_SPI_CH0CONF_FORCE;
+  REG(softc_ptr->regs_base + AM335X_SPI_CH0CTRL) |= AM335X_SPI_CH0CTRL_EN;
+  // Main loop
+  for (int i = 0; i < len; i++) {
+    received_events = 0;
+    if (tx_buf) {
+      // Wait for IRQ to wake us up (room in TX FIFO)
+#if defined(TRACE)
+      printk("beagle_spi_read_write_bytes: waiting (task_id = %ld)\r\n", softc_ptr->task_id);
+#endif
+      sc = rtems_event_receive(EVENT_TXEMPTY, RTEMS_WAIT, BBB_SPI_TIMEOUT, &received_events);
+      if (sc != RTEMS_SUCCESSFUL) {
+        printk("ERROR: beagle_spi_read_write_bytes timed out on tx byte number %d\n", i);
+        return i > 0 ? i : -RTEMS_TIMEOUT;
+      _Assert(received_events == EVENT_TXEMPTY);
+#if defined(TRACE)
+      printk("beagle_spi_read_write_bytes: sending byte: i = %d, tx_buf[i] = 0x%x\r\n", i, tx_buf[i]);
+#endif
+      REG(softc_ptr->regs_base + AM335X_SPI_TX0) = tx_buf[i];
+    if (rx_buf) {
+      // Wait for IRQ to wake us up (data in RX FIFO)
+      if ((received_events & EVENT_RXFULL) == 0) {
+        sc = rtems_event_receive(EVENT_RXFULL, RTEMS_WAIT, BBB_SPI_TIMEOUT, &received_events);
+          printk("ERROR: beagle_spi_read_write_bytes timed out on rx byte number %d\n", i);
+        _Assert(received_events == EVENT_RXFULL);
+      rx_buf[i] = REG(softc_ptr->regs_base + AM335X_SPI_RX0);
+#if defined(TRACE)
+      printk("beagle_spi_read_write_bytes: received byte: i = %d, rx_buf[i] = 0x%x\r\n", i, rx_buf[i]);
+#endif
+  // REG(softc_ptr->regs_base + AM335X_SPI_IRQENABLE) &= ~AM335X_SPI_IRQENABLE_RX0_FULL;
+  // REG(softc_ptr->regs_base + AM335X_SPI_IRQENABLE) &= ~AM335X_SPI_IRQENABLE_TX0_EMPTY;
+  REG(softc_ptr->regs_base + AM335X_SPI_CH0CTRL) &= ~AM335X_SPI_CH0CTRL_EN;
+  REG(softc_ptr->regs_base + AM335X_SPI_CH0CONF) &= ~AM335X_SPI_CH0CONF_FORCE;
+#if defined(TRACE)
+  printk("beagle_spi_read_write_bytes done\r\n");
+#endif
+  return len;
+  // FIXME
+#if defined(DEBUG)
+  printk("beagle_spi_read_bytes called...\r\n");
+#endif
+  int n = beagle_spi_read_write_bytes(bh, buf, NULL, len);
+#if defined(DEBUG)
+  printk("beagle_spi_read_bytes done\r\n");
+#endif
+  return n;
+#if defined(DEBUG)
+  printk("beagle_spi_write_bytes called...\r\n");
+#endif
+  int n = beagle_spi_read_write_bytes(bh, NULL, buf, len);
+#if defined(DEBUG)
+  printk("beagle_spi_write_bytes done\r\n");
+#endif
+  return n;
+  int ret_val = -1;
+#if defined(DEBUG)
+  printk("beagle_spi_ioctl called...\r\n");
+#endif
+  switch(cmd) { // FIXME: other ioctls
+  case RTEMS_LIBI2C_IOCTL_SET_TFRMODE:
+#if defined(TRACE)
+    printk("cmd == RTEMS_LIBI2C_IOCTL_SET_TFRMODE\r\n");
+#endif
+    // FIXME
+    // ret_val =
+    //   -m360_spi_set_tfr_mode(bh,
+    //     (const rtems_libi2c_tfr_mode_t *)arg);
+    break;
+  case RTEMS_LIBI2C_IOCTL_READ_WRITE: {
+#if defined(TRACE)
+    printk("cmd == RTEMS_LIBI2C_IOCTL_READ_WRITE\r\n");
+#endif
+    const rtems_libi2c_read_write_t *cmd = (const rtems_libi2c_read_write_t *)arg;
+    ret_val = beagle_spi_read_write_bytes(
+      bh,
+      (unsigned char *)cmd->rd_buf,
+      (unsigned char *)cmd->wr_buf,
+      cmd->byte_cnt
+    break;
+  default:
+    ret_val = -RTEMS_NOT_DEFINED;
+    break;
+#if defined(DEBUG)
+  printk("beagle_spi_ioctl done\r\n");
+#endif
+  return ret_val;
+| Board-specific adaptation functions                                       |
+ * Address a slave device on the bus
+static rtems_status_code bsp_spi_sel_addr
+ uint32_t addr,                          /* address to send on bus         */
+ int rw                                  /* 0=write,1=read                 */
+  if (addr != 0)
+    return RTEMS_NOT_IMPLEMENTED;
+  return  RTEMS_SUCCESSFUL;
+ * Dummy function, SPI has no start condition
+static rtems_status_code bsp_spi_send_start_dummy
+#if defined(DEBUG)
+  printk("bsp_spi_send_start_dummy OK\r\n");
+#endif
+  return 0;
+ * Deselect SPI
+static rtems_status_code bsp_spi_send_stop
+#if defined(DEBUG)
+  printk("bsp_spi_send_stop called... ");
+#endif
+  // FIXME
+#if defined(DEBUG)
+  printk("... exit OK\r\n");
+#endif
+  return 0;
+| list of handlers                                                          |
+rtems_libi2c_bus_ops_t bsp_spi_ops = {
+  init:             beagle_spi_init,
+  send_start:       bsp_spi_send_start_dummy,
+  send_stop:        bsp_spi_send_stop,
+  send_addr:        bsp_spi_sel_addr,
+  read_bytes:       beagle_spi_read_bytes,
+  write_bytes:      beagle_spi_write_bytes,
+  ioctl:            beagle_spi_ioctl
+static beagle_spi_desc_t bsp_spi_bus_desc = {
+  {/* public fields */
+    ops:    &bsp_spi_ops,
+    size:   sizeof(bsp_spi_bus_desc)
+  { /* our private fields */
+    initialized: FALSE,
+| initialization                                                            |
+  int ret_code;
+  int spi_busno;
+  beagle_spi_softc_t *softc_ptr = &bsp_spi_bus_desc.softc;
+  if (softc_ptr->initialized) {
+    printk("ERROR: Only one SPI bus at a time is supported\n");
+    return -RTEMS_RESOURCE_IN_USE;
+  softc_ptr->regs_base = register_base;
+  softc_ptr->irq = irq;
+   * init I2C library (if not already done)
+  rtems_libi2c_initialize();
+   * register SPI bus
+  ret_code = rtems_libi2c_register_bus(bus_path,
+                       &(bsp_spi_bus_desc.bus_desc));
+  if (ret_code < 0) {
+    return -ret_code;
+  spi_busno = ret_code;
+#if IS_AM335X
+  // TODO: register board devices
+#endif
+  return spi_busno;
diff --git a/bsps/arm/include/libcpu/am335x.h b/bsps/arm/include/libcpu/am335x.h
index 367e97cae9..a78cbd028d 100644
--- a/bsps/arm/include/libcpu/am335x.h
+++ b/bsps/arm/include/libcpu/am335x.h
@@ -19,6 +19,9 @@
 #if !defined(_AM335X_H_)
 #define _AM335X_H_
+#define AM335X_MASK(Shift, Width) (((1 << (Width)) - 1) << (Shift))
 /* Interrupt controller memory map */
 #define OMAP3_DM37XX_INTR_BASE 0x48200000 /* INTCPS physical address */
@@ -649,6 +652,9 @@
 #define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK (0x00000100u)
 #define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK (0x01000000u)
 #define AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE   (0x00000003u)
+#define AM335X_CM_PER_SPI0_CLKCTRL (0x4c)
+#define AM335X_CM_PER_SPI0_CLKCTRL_MODULEMODE_ENABLE  (0x2u)
+#define AM335X_CM_PER_SPI0_CLKCTRL_MODULEMODE  (0x00000003u)
 #define AM335X_I2C_CON_XSA  (0x00000100u)
 #define AM335X_I2C_CFG_10BIT_SLAVE_ADDR  AM335X_I2C_CON_XSA
 #define AM335X_I2C_CON_XSA_SHIFT  (0x00000008u)
@@ -660,7 +666,6 @@
 #define AM335X_I2C_SYSC_AUTOIDLE   (0x00000001u)
 /*I2C0 module clock registers*/
 #define AM335X_CM_WKUP_CONTROL_CLKCTRL   (0x4)
 #define AM335X_CM_WKUP_CLKSTCTRL   (0x0)
 #define AM335X_CM_WKUP_I2C0_CLKCTRL   (0xb8)
@@ -675,6 +680,12 @@
 #define AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST   (0x00030000u)
 #define AM335X_SOC_CM_WKUP_REGS                     (AM335X_CM_PER_ADDR + 0x400)
+/* SPI0 module clock registers */
+#define AM335X_CM_PER_CONTROL_CLKCTRL_IDLEST_FUNC   (0x0u)
+#define AM335X_CM_PER_CONTROL_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
+#define AM335X_CM_PER_CONTROL_CLKCTRL_IDLEST   (0x00030000u)
 /* I2C status Register */
 #define AM335X_I2C_IRQSTATUS_NACK (1 << 1)
 #define AM335X_I2C_IRQSTATUS_ROVR (1 << 11)
@@ -701,4 +712,84 @@
 #define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK (0x00000020u)
 #define AM335X_I2C_INT_STOP_CONDITION AM335X_I2C_IRQSTATUS_BF
+/* SPI registers */
+#define AM335X_SPI0_BASE 0x48030000
+    /* SPI0 base address */
+#define AM335X_SPI1_BASE 0x481A0000
+    /* SPI1 base address */
+#define AM335X_SPI_REVISION         0x000
+#define AM335X_SPI_SYSCONFIG        0x110
+#define AM335X_SPI_SYSSTATUS        0x114
+#define AM335X_SPI_IRQSTATUS        0x118
+#define AM335X_SPI_IRQENABLE        0x11c
+#define AM335X_SPI_WAKEUPENABLE     0x120
+#define AM335X_SPI_SYST             0x124
+#define AM335X_SPI_MODULCTRL        0x128
+#define AM335X_SPI_CH0CONF          0x12c
+#define AM335X_SPI_CH0STAT          0x130
+#define AM335X_SPI_CH0CTRL          0x134
+#define AM335X_SPI_TX0              0x138
+#define AM335X_SPI_RX0              0x13C
+#define AM335X_SPI_XFERLEVEL        0x17c
+/* SPI sysconfig Register */
+#define AM335X_SPI_SYSCONFIG_SOFTRESET (1 << 1)
+/* SPI sysstatus Register */
+#define AM335X_SPI_SYSSTATUS_RESETDONE (1 << 0)
+/* SPI interrupt status Register */
+#define AM335X_SPI_IRQSTATUS_TX0_EMPTY (1 << 0)
+#define AM335X_SPI_IRQSTATUS_RX0_FULL  (1 << 2)
+/* SPI interrupt enable Register */
+#define AM335X_SPI_IRQENABLE_TX0_EMPTY (1 << 0)
+#define AM335X_SPI_IRQENABLE_RX0_FULL  (1 << 2)
+/* SPI system Register */
+#define AM335X_SPI_SYST_SPIEN_0     (1 << 0)
+#define AM335X_SPI_SYST_SPIDAT_0    (1 << 4)
+#define AM335X_SPI_SYST_SPIDAT_1    (1 << 5)
+#define AM335X_SPI_SYST_SPIDATDIR0  (1 << 8)
+#define AM335X_SPI_SYST_SPIDATDIR1  (1 << 9)
+#define AM335X_SPI_SYST_SSB         (1 << 11)
+/* SPI modulctrl Register */
+#define AM335X_SPI_MODULCTRL_SINGLE (1 << 0)
+#define AM335X_SPI_MODULCTRL_PIN34  (1 << 1)
+#define AM335X_SPI_MODULCTRL_MS     (1 << 2)
+/* SPI Channel 0 Configuration Register */
+#define AM335X_SPI_CH0CONF_PHA      (1 << 0)
+#define AM335X_SPI_CH0CONF_POL      (1 << 1)
+#define AM335X_SPI_CH0CONF_CLKD_SHIFT 2
+#define AM335X_SPI_CH0CONF_CLKD_WIDTH 4
+#define AM335X_SPI_CH0CONF_CLKD_MASK AM335X_MASK(AM335X_SPI_CH0CONF_CLKD_SHIFT, AM335X_SPI_CH0CONF_CLKD_WIDTH)
+#define AM335X_SPI_CH0CONF_CLKD(X) (((X) << AM335X_SPI_CH0CONF_CLKD_SHIFT) & AM335X_SPI_CH0CONF_CLKD_MASK)
+#define AM335X_SPI_CH0CONF_EPOL     (1 << 6)
+#define AM335X_SPI_CH0CONF_WL_SHIFT 7
+#define AM335X_SPI_CH0CONF_WL_WIDTH 5
+#define AM335X_SPI_CH0CONF_WL_MASK AM335X_MASK(AM335X_SPI_CH0CONF_WL_SHIFT, AM335X_SPI_CH0CONF_WL_WIDTH)
+#define AM335X_SPI_CH0CONF_WL(X) (((X) << AM335X_SPI_CH0CONF_WL_SHIFT) & AM335X_SPI_CH0CONF_WL_MASK)
+#define AM335X_SPI_CH0CONF_TRM_SHIFT 12
+#define AM335X_SPI_CH0CONF_TRM_WIDTH 2
+#define AM335X_SPI_CH0CONF_TRM_MASK AM335X_MASK(AM335X_SPI_CH0CONF_TRM_SHIFT, AM335X_SPI_CH0CONF_TRM_WIDTH)
+#define AM335X_SPI_CH0CONF_TRM(X) (((X) << AM335X_SPI_CH0CONF_TRM_SHIFT) & AM335X_SPI_CH0CONF_TRM_MASK)
+#define AM335X_SPI_CH0CONF_DPE0     (1 << 16)
+#define AM335X_SPI_CH0CONF_DPE1     (1 << 17)
+#define AM335X_SPI_CH0CONF_IS       (1 << 18)
+#define AM335X_SPI_CH0CONF_FORCE    (1 << 20)
+#define AM335X_SPI_CH0CONF_SBPOL    (1 << 27)
+#define AM335X_SPI_CH0CONF_FFEW     (1 << 27)
+#define AM335X_SPI_CH0CONF_FFER     (1 << 28)
+/* SPI Channel 0 Status Register */
+#define AM335X_SPI_CH0STAT_RXS      (1 << 0)
+#define AM335X_SPI_CH0STAT_TXS      (1 << 1)
+/* SPI Channel 0 Control Register */
+#define AM335X_SPI_CH0CTRL_EN       (1 << 0)
 #endif
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index acab25c52f..332536c428 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -70,6 +70,9 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/console/console-confi
 # I2C
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/i2c/bbb-i2c.c
+# SPI
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/spi/spi.c
 # GPIO
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/gpio/bbb-gpio.c
2.17.2 (Apple Git-113)
