[PATCH] libdebugger: Fix for ARMv7-M with -O0 optimization
Tue Feb 26 06:29:28 UTC 2019
On 25/02/2019 22:46, Chris Johns wrote:
> Hi,
> The patch looks like it is masking something but I am not sure.
> What are the errors at -O0 the patch is attempting to resolve?
> Which BSP is showing the issue?
> What is the multilib ARM arch?
The ARMv7-M is affected by this.
> Are these errors seen at -O2 and if not why does -O0 cause them?
With -O2 the assembler doesn't see the offending machine instructions,
they are optimized away. See the useless local variables in
rtems_debugger_target_set_vectors().
> The intention is for the ARM back end to work on more than the CortexA9 so I am
> concerned with making the whole of `target_exception` dependent on CP15.
I just removed the useless assignment to local variables in
rtems_debugger_target_set_vectors() and expanded the scope of the
ARM_CP15 block. There is no functional change.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
