[PATCH 1/2] arm/beagle: SPI driver
Tue Feb 26 06:55:45 UTC 2019
Hello Pierre-Louis,
thanks for your SPI driver. We have a new framework for SPI drivers in
RTEMS which is compatible to the Linux user-space API:
https://docs.rtems.org/branches/master/bsp-howto/spi.html
It would be great if you could convert your new driver to use this
framework. In case you have no time for this, then we can still add this
driver as is.
New code should use the BSD-2-Clause license:
https://git.rtems.org/rtems/tree/LICENSE.BSD-2-Clause
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
