[PATCH] Update User Documentation for host setup for Linux
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Tue Feb 26 11:25:32 UTC 2019
I will format it today.
On Mon, 25 Feb, 2019, 3:05 AM Chris Johns <chrisj at rtems.org wrote:
> On 23/2/19 1:52 am, Vaibhav Gupta wrote:
> > - mention for the installion of 'pax' package if RTEMS is configured
> with --enable-tests, else build will fail.
> > user/hosts/posix.rst | 5 +++++
> > user/tools/tester.rst | 2 ++
> > 2 files changed, 7 insertions(+)
> > diff --git a/user/hosts/posix.rst b/user/hosts/posix.rst
> > index 063ebe2..ed2cdb5 100644
> > --- a/user/hosts/posix.rst
> > +++ b/user/hosts/posix.rst
> > @@ -40,6 +40,11 @@ control of the machine. We call this project
> sandboxing and
> > Linux
> > +BSP Build will require ``pax`` package if RTEMS is configured with
> > +``--enable-tests`` option, see :ref:`BuildingRTEMSTests`.
> > +By default, this package is not installed on many Linux distributions.
> You can check for it using your package manager.
> Please format lines to 80 columns ...
> https://git.rtems.org/rtems-docs/tree/README.txt#n353
> Thanks
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190226/b4ebcb99/attachment.html>
