Requirements Format
Tue Feb 26 14:57:25 UTC 2019
Hello Joel,
On 26/02/2019 15:44, Joel Sherrill wrote:
> Hi
> I have mentioned this before but reading ticket 3703, you obviously
> didn't remember it.
I remember it and I think I proposed to use ReqIF.
> ReqIF is an OMG standard for representing
> requirements in XML format. It was designed to facilitate requirements
> exchange between partnering organizations.
> https://www.omg.org/spec/ReqIF/About-ReqIF/
> It appears to be supported by all the major requirement tools including
> DOORS and LDRA's toolset. Importantly, it is supported by the Eclipse
> Requirements Management Framework (RMF) and the ProR tool
> https://en.wikipedia.org/wiki/Requirements_Modeling_Framework
> https://www.eclipse.org/rmf/
> https://www.eclipse.org/rmf/pror/
> This is a solved problem. We should not define our own XML format.
> One exists and there is a set of open source tools we can use to work
> with requirements.
Did you try to use these tools? It is a nightmare.
We evaluated also Papyrus:
https://www.eclipse.org/papyrus/
I will try to summarize the problems we encountered using ReqIF in the
next days.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
