[PATCH 1/2] arm/beagle: SPI driver
pierre-louis garnier
pierre-louis.garnier at epita.fr
Tue Feb 26 21:28:30 UTC 2019
Hello Sebastian,
It would be great if you could convert your new driver to use this framework. In case you have no time for this, then we can still add this driver as is.
I don't know how I missed the new framework.
Unfortunately I won't have the time to port the driver to the new framework in the near future.
New code should use the BSD-2-Clause license:
I agree to license the code as such. Here's a patch to change that.
bsps/arm/beagle/spi/spi.c | 27 +++++++++++++++++++++++----
1 file changed, 23 insertions(+), 4 deletions(-)
diff --git a/bsps/arm/beagle/spi/spi.c b/bsps/arm/beagle/spi/spi.c
index 38c0a503e0..0ad152a06e 100644
--- a/bsps/arm/beagle/spi/spi.c
+++ b/bsps/arm/beagle/spi/spi.c
@@ -9,11 +9,30 @@
- * Copyright (c) 2018 Pierre-Louis Garnier <garnie_a at epita.fr<mailto:garnie_a at epita.fr>>
+ * SPDX-License-Identifier: BSD-2-Clause
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * Copyright (c) 2018 Pierre-Louis Garnier
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#include <bsp.h>
#include <bsp/bbb-gpio.h>
2.20.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190226/4814cfdc/attachment.html>
