[PATCH 6/6] user: Remove nit-picky warnings.
Wed Feb 27 06:47:41 UTC 2019
On 27/2/19 5:42 pm, Sebastian Huber wrote:
> On 27/02/2019 07:30, Chris Johns wrote:
>> diff --git a/README.txt b/README.txt
>> index e002f60..115d08d 100644
>> --- a/README.txt
>> +++ b/README.txt
>> @@ -415,14 +415,34 @@ existing documentation for an example and if unsure ask.
>>         5  ^^^^^^ Sub-sub-sub-section
>>         6  ~~~~~~ Sub-sub-sub-sub-section
>>   -5. For literal output, such as shell commands and code use '::' at the
>> trailing
>> -   edge of the previous paragraph. Use the '.. code-block::' with
>> -   'c' for C code and 'shell' for shell code and terminal output. If you need
>> -   line number use:
>> +5. For literal output, such as shell commands and code do not use '::'
>> +   at the trailing edge of the previous paragraph as it generates
>> +   warnings as the autodetect fails to find a suitable format. Use the
>> +   '.. code-block::' with a suitable lexical label. The lexers are:
>> +http://pygments.org/docs/lexers/
>> +   Use the short names. For C code use 'c' code and 'shell' for shell
>> +   scripts and for terminal output use 'none'.
> I would not use 'shell' for commands. For example in
> .. code-block:: shell
>     ../configure --enable-rtemsbsp=qoriq_e6500_32 \
>         QORIQ_IS_HYPERVISOR_GUEST=1 \
>         QORIQ_UART_0_ENABLE=0 \
>         QORIQ_UART_1_ENABLE=0 \
>         QORIQ_TLB1_ENTRY_COUNT=16
> the "variables" QORIQ_IS_HYPERVISOR_GUEST, etc. are highlighted and the numeric
> "values" 0, etc. are highlighted differently. Is this useful? I don't think so.
> In real shell scripts with variables, loops, conditions and whatever maybe it
> makes sense to use syntax highlighting.
Is this a bug with the pigments tool?
>> If you need line number
>> +   use:
>>          :linenos:
> It seems there is a difference between the HTML and PDF output in terms of line
> numbering. In the PDF I see the line numbers event without this option.
That is a latex setting we have on.
