[PATCH 6/6] user: Remove nit-picky warnings.
Wed Feb 27 08:29:23 UTC 2019
On 27/2/19 6:51 pm, Sebastian Huber wrote:
> On 27/02/2019 07:47, Chris Johns wrote:
>> On 27/2/19 5:42 pm, Sebastian Huber wrote:
>>> On 27/02/2019 07:30, Chris Johns wrote:
>>>> diff --git a/README.txt b/README.txt
>>>> index e002f60..115d08d 100644
>>>> --- a/README.txt
>>>> +++ b/README.txt
>>>> @@ -415,14 +415,34 @@ existing documentation for an example and if unsure ask.
>>>>          5  ^^^^^^ Sub-sub-sub-section
>>>>          6  ~~~~~~ Sub-sub-sub-sub-section
>>>>    -5. For literal output, such as shell commands and code use '::' at the
>>>> trailing
>>>> -   edge of the previous paragraph. Use the '.. code-block::' with
>>>> -   'c' for C code and 'shell' for shell code and terminal output. If you need
>>>> -   line number use:
>>>> +5. For literal output, such as shell commands and code do not use '::'
>>>> +   at the trailing edge of the previous paragraph as it generates
>>>> +   warnings as the autodetect fails to find a suitable format. Use the
>>>> +   '.. code-block::' with a suitable lexical label. The lexers are:
>>>> +http://pygments.org/docs/lexers/
>>>> +   Use the short names. For C code use 'c' code and 'shell' for shell
>>>> +   scripts and for terminal output use 'none'.
>>> I would not use 'shell' for commands. For example in
>>> .. code-block:: shell
>>>      ../configure --enable-rtemsbsp=qoriq_e6500_32 \
>>>          QORIQ_IS_HYPERVISOR_GUEST=1 \
>>>          QORIQ_UART_0_ENABLE=0 \
>>>          QORIQ_UART_1_ENABLE=0 \
>>>          QORIQ_TLB1_ENTRY_COUNT=16
>>> the "variables" QORIQ_IS_HYPERVISOR_GUEST, etc. are highlighted and the numeric
>>> "values" 0, etc. are highlighted differently. Is this useful? I don't think so.
>>> In real shell scripts with variables, loops, conditions and whatever maybe it
>>> makes sense to use syntax highlighting.
>> Is this a bug with the pigments tool?
> From my point of view this is a bug. I don't have time to report it.
Sure, I can look into that. I suggest we keep the formatting as it should be and
get the tool fixed.
