[PATCH v2 8/8] User: Change output block to type none.
chrisj at rtems.org chrisj at rtems.org
Wed Feb 27 21:39:23 UTC 2019
 user/bsps/bsps-powerpc.rst        |  4 ++--
 user/bsps/bsps-x86_64.rst         | 10 ++++-----
 user/bsps/index.rst               |  2 +-
 user/exe/initialization.rst       |  2 +-
 user/exe/loader.rst               |  6 +++---
 user/hardware/architectures.rst   |  4 ++--
 user/hosts/os.rst                 |  4 ++--
 user/hosts/posix.rst              | 20 ++++++++---------
 user/hosts/windows.rst            |  4 ++--
 user/installation/developer.rst   | 36 +++++++++++++++----------------
 user/installation/kernel.rst      | 30 +++++++++++++-------------
 user/installation/releases.rst    | 12 +++++------
 user/rsb/bug-reporting.rst        |  3 ++-
 user/rsb/commands.rst             |  8 +++----
 user/rsb/configuration.rst        |  8 +++----
 user/rsb/cross-canadian-cross.rst |  6 +++---
 user/rsb/deployment.rst           |  8 +++----
 user/rsb/project-sets.rst         |  8 +++----
 user/rsb/third-party-packages.rst |  2 +-
 user/testing/tftp.rst             |  4 ++--
 user/tools/bsp-builder.rst        |  4 ++--
 user/tools/exeinfo.rst            |  4 ++--
 user/tools/symbols.rst            |  6 +++---
 user/tools/tester.rst             | 16 +++++++-------
 user/tracing/captureengine.rst    |  4 ++--
 user/tracing/examples.rst         | 10 ++++-----
 user/tracing/tracelinker.rst      |  6 +++---
 27 files changed, 116 insertions(+), 115 deletions(-)
diff --git a/user/bsps/bsps-powerpc.rst b/user/bsps/bsps-powerpc.rst
index 365571f..623f23b 100644
--- a/user/bsps/bsps-powerpc.rst
+++ b/user/bsps/bsps-powerpc.rst
@@ -94,7 +94,7 @@ Boot via U-Boot
 The application executable file (ELF file) must be converted to an U-Boot
 image.  Use the following commands:
-.. code-block:: shell
+.. code-block:: none
     powerpc-rtems5-objcopy -O binary app.exe app.bin
     gzip -9 -f -c app.bin > app.bin.gz
@@ -102,7 +102,7 @@ image.  Use the following commands:
 Use the following U-Boot commands to boot an application via TFTP download:
     tftpboot ${loadaddr} app.img && run loadfdt && bootm ${loadaddr} - ${fdt_addr} ; reset
diff --git a/user/bsps/bsps-x86_64.rst b/user/bsps/bsps-x86_64.rst
index c872734..eefffab 100644
--- a/user/bsps/bsps-x86_64.rst
+++ b/user/bsps/bsps-x86_64.rst
@@ -40,7 +40,7 @@ Complete detailed instructions are available at `TianoCore's Github's wiki
 Quick instructions (which may fall out of date) are:
     $ git clone git://github.com/tianocore/edk2.git
     $ cd edk2
@@ -63,7 +63,7 @@ shell.
 You can find the ``OVMF.fd`` file like this as well in the edk2 directory:
     $ find . -name "*.fd"
     ./Build/OvmfX64/DEBUG_GCC5/FV/MEMFD.fd
@@ -82,7 +82,7 @@ it. `Download FreeBSD's installer "memstick" image for amd64
 <https://www.freebsd.org/where.html>`_ and then run the following commands,
 replacing paths as appropriate.
   $ qemu-img create freebsd.img 8G
   $ OVMF_LOCATION=/path/to/ovmf/OVMF.fd
@@ -114,14 +114,14 @@ do something to the effect of the following.
 On the host
    # Upload hello.exe anywhere accessible within the host
    $ curl --upload-file hello.exe https://transfer.sh/rtems
 Then on the guest (FreeBSD), login with ``root`` and
    # Back the FreeBSD kernel up
    $ cp -r /boot/kernel/ /boot/kernel.old
diff --git a/user/bsps/index.rst b/user/bsps/index.rst
index a8035e1..0c3b2f6 100644
--- a/user/bsps/index.rst
+++ b/user/bsps/index.rst
@@ -18,7 +18,7 @@ target hardware.
 You can see the current BSP list in the RTEMS sources by asking RTEMS with:
     $ ./rtems-bsps
diff --git a/user/exe/initialization.rst b/user/exe/initialization.rst
index eb96595..cfe39d6 100644
--- a/user/exe/initialization.rst
+++ b/user/exe/initialization.rst
@@ -85,7 +85,7 @@ The RTEMS Tool ``rtems-exeinfo`` can provide some detail about the registered
 handlers. The following shows the initialization handlers for the *hello world*
 sample application in the RTEMS kernel's testsuite::
  $ rtems-exeinfo --init arm-rtems5/c/xilinx_zynq_zedboard/testsuites/samples/hello.exe
  RTEMS Executable Info 5.5416cfa39dd6
diff --git a/user/exe/loader.rst b/user/exe/loader.rst
index 485d691..c11f363 100644
--- a/user/exe/loader.rst
+++ b/user/exe/loader.rst
@@ -456,7 +456,7 @@ is made more complex as it needs to have extra steps to link a second time.
 This example shows creating an embedded symbol table object file and linking it
 into the base image.
  $ sparc-rtems5-gcc -mcpu=cypress foo.o -lrtemsbsp -lrtemscpu -o foo.pre
  $ rtems-syms -e -C sparc-rtems5-gcc -c "-mcpu=cypress" -o foo-sym.o foo.pre
@@ -484,7 +484,7 @@ unpredictable. No checks are made.
 The example shows creating and loading a symbol table executable object
 file. First create the symbol table's executable object file:
  $ sparc-rtems5-gcc -mcpu=cypress foo.o -lrtemsbsp -lrtemscpu -o foo.exe
  $ rtems-syms -C sparc-rtems5-gcc -c "-mcpu=cypress" -o foo-sym.o foo.exe
@@ -630,7 +630,7 @@ debug information and this should be stripped before loading on to the
 target. The tool suite's command :program:`strip` can strip all the object files
 in a library with a single command.
   $ sparc-rtems5-strip libc.a
diff --git a/user/hardware/architectures.rst b/user/hardware/architectures.rst
index 761258f..b604782 100644
--- a/user/hardware/architectures.rst
+++ b/user/hardware/architectures.rst
@@ -25,7 +25,7 @@ automatically by GCC via selecting a specific set of machine options.
 You can query the multilibs of a specific RTEMS GCC compiler via the
 ``-print-multi-lib`` option:
     $ sparc-rtems5-gcc -print-multi-lib
@@ -56,7 +56,7 @@ of machine options for this multilib follows separated by ``@`` characters.
 You can figure out the multilib selected by GCC for a set of machine options
 with the ``-print-multi-directory`` option:
     $ sparc-rtems5-gcc -print-multi-directory -mcpu=leon3
     leon3
diff --git a/user/hosts/os.rst b/user/hosts/os.rst
index d1f0834..4bb873e 100644
--- a/user/hosts/os.rst
+++ b/user/hosts/os.rst
@@ -52,7 +52,7 @@ proven over the years to be difficult to manage in production systems.
     using the ``--prefix`` option so the path you need to configure to build
     applications can be set with the following in a BASH shell:
-    .. code-block:: shell
+    .. code-block:: none
       $ export PATH=$HOME/development/rtems/4.11/bin:$PATH
@@ -75,7 +75,7 @@ proven over the years to be difficult to manage in production systems.
     example, if you want to build a toolchain for 4.11, then you should
     checkout the 4.11 branch of the RSB:
       $ git checkout -t origin/4.11
diff --git a/user/hosts/posix.rst b/user/hosts/posix.rst
index cc40442..7d64fa9 100644
--- a/user/hosts/posix.rst
+++ b/user/hosts/posix.rst
@@ -50,7 +50,7 @@ ArchLinux
 The following packages are required on a fresh Archlinux 64bit installation:
   # pacman -S base-devel gdb xz unzip ncurses git zlib
@@ -58,7 +58,7 @@ Archlinux, by default installs ``texinfo-5`` which is incompatible for building
 GCC 4.7 tree. You will have to obtain ``texinfo-legacy`` from ``AUR`` and
 provide a manual override:
   # pacman -R texinfo
   $ yaourt -S texinfo-legacy
@@ -71,7 +71,7 @@ CentOS
 The following packages are required on a minimal CentOS 6.3 64bit installation:
   # yum install autoconf automake binutils gcc gcc-c++ gdb make patch \
   bison flex xz unzip ncurses-devel texinfo zlib-devel python-devel git
@@ -88,7 +88,7 @@ Fedora
 The RTEMS Source Builder has been tested on Fedora 19 64bit with the following
 packages:
   # yum install ncurses-devel python-devel git bison gcc cvs gcc-c++ \
        flex texinfo patch perl-Text-ParseWords zlib-devel
@@ -101,7 +101,7 @@ Raspbian
 The is the Debian distribution for the Raspberry Pi. The following packages are
 required:
   $ sudo apt-get install autoconf automake bison flex binutils gcc g++ gdb \
   texinfo unzip ncurses-dev python-dev git
@@ -119,7 +119,7 @@ Ubuntu
 The latest version is Ubuntu 18.04.1 LTS 64-bit. This section also includes
 Xubuntu. A minimal installation was used and the following packages installed:
   $ sudu apt-get build-dep gcc-defaults g++ gdb git unzip pax bison \
          flex libpython-dev git libncurses5-dev zlib1g-dev
@@ -142,7 +142,7 @@ Linux Mint
 zlib package is required on Linux Mint. It has a different name (other
 than the usual zlib-dev):
   # sudo apt-get install zlib1g-dev
@@ -162,7 +162,7 @@ FreeBSD
 The RTEMS Source Builder has been tested on FreeBSD 9.1, 10.3 and 11 64bit
 version. You need to install some ports. They are:
   # cd /usr/ports
   # portinstall --batch lang/python27
@@ -170,7 +170,7 @@ version. You need to install some ports. They are:
 If you wish to build Windows (mingw32) tools please install the following
 ports:
   # cd /usr/ports
   # portinstall --batch devel/mingw32-binutils devel/mingw32-gcc
@@ -190,7 +190,7 @@ NetBSD
 The RTEMS Source Builder has been tested on NetBSD 6.1 i386. Packages to add
 are:
   # pkg_add ftp://ftp.netbsd.org/pub/pkgsrc/packages/NetBSD/i386/6.1/devel/gmake-3.82nb7.tgz
   # pkg_add ftp://ftp.netbsd.org/pub/pkgsrc/packages/NetBSD/i386/6.1/devel/bison-2.7.1.tgz
diff --git a/user/hosts/windows.rst b/user/hosts/windows.rst
index ffd70a0..7aaa9c3 100644
--- a/user/hosts/windows.rst
+++ b/user/hosts/windows.rst
@@ -157,7 +157,7 @@ The packages we require are:
 Install the packages using ``pacman``:
   $ pacman -S python mingw-w64-x86_64-python2 mingw-w64-x86_64-gcc \
   bison cvs diffutils git make patch tar texinfo unzip
@@ -225,7 +225,7 @@ cross-compiler is required to build the C runtime for the RTEMS target because
 we are building under Cygiwn. The build output for an RTEMS 4.10 ARM tool set
 is:
   chris at cygwin ~/development/rtems/src/rtems-source-builder/rtems
   $ ../source-builder/sb-set-builder --log=l-arm.txt \
diff --git a/user/installation/developer.rst b/user/installation/developer.rst
index 90912cc..541e04b 100644
--- a/user/installation/developer.rst
+++ b/user/installation/developer.rst
@@ -62,7 +62,7 @@ This procedure will build a SPARC tool chain.
 Clone the RTEMS Source Builder (RSB) repository:
   $ cd
   $ mkdir -p development/rtems
@@ -80,7 +80,7 @@ Check all the host packages you need are present. Current libraries are not
 checked and this includes checking for the python development libraries GDB
 requires:
   $ cd rsb
   $ ./source-builder/sb-check
@@ -90,7 +90,7 @@ requires:
 If you are unsure how to specify the build set for the architecture you wish to
 build, just ask the tool:
     $ ../source-builder/sb-set-builder --list-bsets   <1>
     RTEMS Source Builder - Set Builder, v4.11.0
@@ -164,7 +164,7 @@ architecture because GDB has a good simulator that lets us run and test the
 samples RTEMS builds by default. The current development version
 is `5` and is on master:
   $ cd rtems
   $ ../source-builder/sb-set-builder --prefix=/usr/home/chris/development/rtems/5 5/rtems-sparc
@@ -316,7 +316,7 @@ Create a workspace for RTEMS using the following shell command:
   Add ``--bset-tar-file`` to the ``sb-set-builder`` command line to create
   tar files of the built package set.
   $ mkdir -p /c/opt/rtems
@@ -328,7 +328,7 @@ another drive please subsitute ``/c`` with your drive letter.
 We build and install all RTEMS packages under the `prefix` we just
 created. Change to that directory and get a copy of the RSB:
   $ cd /c/opt/rtems
@@ -347,7 +347,7 @@ created. Change to that directory and get a copy of the RSB:
 We are building RTEMS 4.11 tools so select the *4.11* branch:
    /c/opt/rtems/rsb
   $ git checkout 4.11
@@ -358,7 +358,7 @@ We are building RTEMS 4.11 tools so select the *4.11* branch:
 Check the RSB has a valid environment:
    /c/opt/rtems/rsb
   $ cd rtems
@@ -375,7 +375,7 @@ long time so please be patient. The RSB creates a log file containing all the
 build output and it will be changing size. The RSB command to build ``i386``
 tools is:
    /c/opt/rtems/rsb/rtems
   $ ../source-builder/sb-set-builder --prefix=/c/opt/rtems/4.11 \
@@ -495,7 +495,7 @@ Building the Kernel
 We can now build the RTEMS kernel using the RTEMS tools we have just
 built. First we need to set the path to the tools:
    /c
   $ cd /c/opt/rtems
@@ -506,7 +506,7 @@ built. First we need to set the path to the tools:
 We currently build RTEMS from the git release branch for 4.11:
    /c/opt/rtems
   $ mkdir kernel
@@ -538,7 +538,7 @@ clean away any files, then generate the pre-install header file lists and
 finally we generate the ``autoconf`` and ``automake`` files using the RSB's
 bootstrap tool. First we clean any generated files that exist:
    /c/opt/rtems/kernel/rtems
   $ ./bootstrap -c
@@ -548,7 +548,7 @@ bootstrap tool. First we clean any generated files that exist:
 Then we generate the pre-install header file automake make files:
   $ ./bootstrap -p
@@ -579,7 +579,7 @@ Then we generate the pre-install header file automake make files:
 Finally we run the RSB's parallel ``bootstrap`` command:
   $ /c/opt/rtems/rsb/source-builder/sb-bootstrap
   RTEMS Source Builder - RTEMS Bootstrap, 4.11 (76188ee494dd)
@@ -615,7 +615,7 @@ BSP. You can check the available BSPs by running the ``rtems-bsps`` command
 found in the top directory of the RTEMS kernel source. We build the Board
 Support Package (BSP) outside the kernel source tree:
   $ cd ..
@@ -629,7 +629,7 @@ Support Package (BSP) outside the kernel source tree:
 Configure the RTEMS kernel to build ``pc686`` BSP for the ``i386`` target with
 networking disabled, We will build the external libBSD stack later:
    /c/opt/rtems/kernel/pc686
   $ /c/opt/rtems/kernel/rtems/configure --prefix=/c/opt/rtems/4.11 \
@@ -667,7 +667,7 @@ networking disabled, We will build the external libBSD stack later:
 Build the kernel:
   $ make
@@ -706,7 +706,7 @@ Build the kernel:
 Install the kernel to our prefix:
   $ make install
   Making install in tools/build
diff --git a/user/installation/kernel.rst b/user/installation/kernel.rst
index 4978d41..f8c3c6f 100644
--- a/user/installation/kernel.rst
+++ b/user/installation/kernel.rst
@@ -16,7 +16,7 @@ Development Sources
 Create a new location to build the RTEMS kernel:
   $ cd
   $ cd development/rtems
@@ -25,7 +25,7 @@ Create a new location to build the RTEMS kernel:
 Clone the RTEMS respository:
   $ git clone git://git.rtems.org/rtems.git rtems
   Cloning into 'rtems'...
@@ -44,7 +44,7 @@ section. The RTEMS tools needs to be first in your path because RTEMS provides
 specific versions of the ``autoconf`` and ``automake`` tools. We want to use
 the RTEMS version and not your host's versions:
   $ export PATH=$HOME/development/rtems/5/bin:$PATH
@@ -61,7 +61,7 @@ to speed it up the RSB provides a command that can perform the bootstrap in
 parallel using your available cores. We need to enter the cloned source
 directory then run the bootstrap commands:
   $ cd rtems
   $ ./bootstrap -c && $HOME/development/rtems/rsb/source-builder/sb-bootstrap
@@ -103,7 +103,7 @@ We build RTEMS in a directory outside of the source tree we have just cloned
 and ``bootstrapped``. You cannot build RTEMS while in the source tree. Lets
 create a suitable directory using the name of the BSP we are going to build:
   $ cd ..
   $ mkdir erc32
@@ -115,7 +115,7 @@ files. If you are source level debugging you will be able to access the source
 code to RTEMS from the debugger. We will build for the ``erc32`` BSP with POSIX
 enabled and the networking stack disabled:
   $ $HOME/development/rtems/kernel/rtems/configure --prefix=$HOME/development/rtems/5 \
                      --target=sparc-rtems5 --enable-rtemsbsp=erc32 --enable-posix \
@@ -158,7 +158,7 @@ enabled and the networking stack disabled:
 Build RTEMS using two cores:
   $ make -j 2
   Making all in tools/build
@@ -250,7 +250,7 @@ the API headers and architecture specific libraries to a locaiton under the
 RTEMS. Do not mix versions of RTEMS under the same `prefix`. Make installs
 RTEMS with the following command:
   $ make install
@@ -311,7 +311,7 @@ Changes to the source tree are tracked using git. If you have not made changes
 and enter the source tree and enter a git status command you will see nothing
 has changed:
   $ cd ../rtems
   $ git status
@@ -323,7 +323,7 @@ We will make a change to the source code. In this example I change the help
 message to the RTEMS shell's ``halt`` command. Running the same git status
 command reports:
   $ git status
   On branch master
@@ -339,14 +339,14 @@ command reports:
 As an example I have a ticket open and the ticket number is 9876. I commit the
 change with the follow git command:
   $ git commit cpukit/libmisc/shell/main_halt.c
 An editor is opened and I enter my commit message. The first line is a title
 and the following lines form a body. My message is:
   shell: Add more help detail to the halt command.
@@ -366,7 +366,7 @@ and the following lines form a body. My message is:
 When you save and exit the editor git will report the commit's status:
   [master 9f44dc9] shell: Add more help detail to the halt command.
@@ -375,14 +375,14 @@ When you save and exit the editor git will report the commit's status:
 You can either email the patch to :r:list:`devel` with the following git
 command, and it is `minus one` on the command line:
   $ git send-email --to=devel at rtems.org -1
    <add output here>
 Or you can ask git to create a patch file using:
   $ git format-patch -1
   0001-shell-Add-more-help-detail-to-the-halt-command.patch
diff --git a/user/installation/releases.rst b/user/installation/releases.rst
index 10ef30e..a20f948 100644
--- a/user/installation/releases.rst
+++ b/user/installation/releases.rst
@@ -66,7 +66,7 @@ RTEMS Tools and Kernel
 This procedure will build a SPARC tool chain. Set up a suitable workspace to
 build the release in. On Unix:
  $ cd
  $ mkdir -p development/rtems/releases
@@ -74,7 +74,7 @@ build the release in. On Unix:
 If building on Windows:
  $ cd /c
  $ mkdir -p opt/rtems
@@ -84,7 +84,7 @@ If building on Windows:
 Download the RTEMS Source Builder (RSB) from the RTEMS FTP server:
  $ wget https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0/rtems-source-builder-4.11.0.tar.xz
  --2016-03-21 10:50:04-- https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0/rtems-source-builder-4.11.0.tar.xz
@@ -100,7 +100,7 @@ Download the RTEMS Source Builder (RSB) from the RTEMS FTP server:
 On Unix unpack the RSB release tar file using:
  $ tar Jxf rtems-source-builder-4.11.0.tar.xz
  $ cd rtems-source-builder-4.11.0/rtems/
@@ -108,7 +108,7 @@ On Unix unpack the RSB release tar file using:
 On Windows you need to shorten the path (See :ref:`windows-path-length`) after
 you have unpacked the tar file:
  $ mv rtems-source-builder-4.11.0 4.110
@@ -121,7 +121,7 @@ and test the samples RTEMS builds by default
 If building on Windows add ``--jobs=none`` to avoid GNU make issues on Windows
 discussed in :ref:`msys2_parallel_builds`.
  $ ../source-builder/sb-set-builder \
      --prefix=/opt/rtems/4.11 4.11/rtems-sparc
diff --git a/user/rsb/bug-reporting.rst b/user/rsb/bug-reporting.rst
index 2adf90a..06a4bbf 100644
--- a/user/rsb/bug-reporting.rst
+++ b/user/rsb/bug-reporting.rst
@@ -13,8 +13,9 @@ find a bug please report it via the :r:url:`devel` or email on the RTEMS Users
 list.
 Please include the generated RSB report. If you see the following a report has
-been generated::
+been generated:
+.. code-blocks:: none
     Build FAILED   <1>
diff --git a/user/rsb/commands.rst b/user/rsb/commands.rst
index 80d74a5..b85692d 100644
--- a/user/rsb/commands.rst
+++ b/user/rsb/commands.rst
@@ -10,7 +10,7 @@ Checker (sb-check)
 This commands checks your system is set up correctly. Most options are ignored:
     $ ../source-builder/sb-check --help
     sb-check: [options] [args]
@@ -54,7 +54,7 @@ Defaults (sb-defaults)
 This commands outputs and the default macros for your when given no
 arguments. Most options are ignored:
     $ ../source-builder/sb-defaults --help
     sb-defaults: [options] [args]
@@ -94,7 +94,7 @@ Set Builder (sb-set-builder)
 This command builds a set:
     $ ../source-builder/sb-set-builder --help
     RTEMS Source Builder, an RTEMS Tools Project (c) 2012-2013 Chris Johns
@@ -302,7 +302,7 @@ Set Builder (sb-builder)
 This command builds a configuration as described in a configuration
 file. Configuration files have the extension of ``.cfg``:
     $ ./source-builder/sb-builder --help
     sb-builder: [options] [args]
diff --git a/user/rsb/configuration.rst b/user/rsb/configuration.rst
index 85e3626..e9a6ad4 100644
--- a/user/rsb/configuration.rst
+++ b/user/rsb/configuration.rst
@@ -238,7 +238,7 @@ with:
 The ``sb-defaults`` command lists the defaults for your host. I will not include
 the output of this command because of its size:
@@ -518,7 +518,7 @@ provides.
 To create a private configuration change to a suitable directory:
     $ cd ~/work
     $ mkdir test
@@ -749,7 +749,7 @@ Once we have the configuration files we can execute the build using the
 ``sb-builder`` command. The command will perform the build and create a tar file
 in the ``tar`` directory:
     $  ../source-builder/sb-builder --prefix=/usr/local \
          --log=log_dtc devel/dtc-1.2.0
@@ -782,7 +782,7 @@ The DTC build set file is called ``dtc.bset`` and contains:
 To build this you can use something similar to:
     $ ../source-builder/sb-set-builder --prefix=/usr/local --log=log_dtc \
        --trace --bset-tar-file --no-install dtc
diff --git a/user/rsb/cross-canadian-cross.rst b/user/rsb/cross-canadian-cross.rst
index fc903e4..d78952f 100644
--- a/user/rsb/cross-canadian-cross.rst
+++ b/user/rsb/cross-canadian-cross.rst
@@ -22,7 +22,7 @@ development machine.
 To build the NTP package for RTEMS you enter the RSB command:
        --log=log_ntp_arm.txt \
@@ -85,7 +85,7 @@ To perform a cross build add ``--host=`` to the command line. For example
 to build a MinGW tool set on FreeBSD for Windows add ``--host=mingw32``
 if the cross compiler is ``mingw32-gcc``:
     $ ../source-builder/sb-set-builder --host=mingw32 \
        --log=l-mingw32-4.11-sparc.txt \
@@ -95,7 +95,7 @@ if the cross compiler is ``mingw32-gcc``:
 If you are on a Linux Fedora build host with the MinGW packages installed the
 command line is:
     $ ../source-builder/sb-set-builder --host=i686-w64-mingw32 \
diff --git a/user/rsb/deployment.rst b/user/rsb/deployment.rst
index c0cd1ce..ad5dd57 100644
--- a/user/rsb/deployment.rst
+++ b/user/rsb/deployment.rst
@@ -32,7 +32,7 @@ directory to the root (``/``) and untar the file because the ``/home`` is root
 access only. To install a tar file you have downloaded into your new machine's
 ``Downloads`` directory in your home directoty you would enter:
     $ cd /somewhere
     $ tar --strip-components=3 -xjf \
@@ -41,7 +41,7 @@ access only. To install a tar file you have downloaded into your new machine's
 A build set tar file is created by adding ``--bset-tar-file`` option to the
 ``sb-set-builder`` command:
     $ ../source-builder/sb-set-builder --log=l-sparc.txt \
              --prefix=$HOME/development/rtems/4.11 \
@@ -84,7 +84,7 @@ You can also suppress installing the files using the ``--no-install``
 option. This is useful if your prefix is not accessiable, for example when
 building Canadian cross compiled tool sets:
@@ -124,7 +124,7 @@ A package tar file can be created by adding the ``--pkg-tar-files`` to the
 ``sb-set-builder`` command. This creates a tar file per package built in the
 build set:
diff --git a/user/rsb/project-sets.rst b/user/rsb/project-sets.rst
index 64a23d4..5ffce26 100644
--- a/user/rsb/project-sets.rst
+++ b/user/rsb/project-sets.rst
@@ -50,7 +50,7 @@ The **bare metal** support for GNU Tool chains. An example is the
 for an ARM compiler you would use ``arm-eabi`` or ``arm-eabihf``, and for SPARC
 you would use ``sparc-elf``:
     $ cd rtems-source-builder/bare
     $ ../source-builder/sb-set-builder --log=log_arm_eabihf \
@@ -109,7 +109,7 @@ packages only after they have been built so if you host does not have a
 recent enough version of ``autoconf`` and ``automake`` you first need to build them
 and install them then build your tool set. The commands are:
     $ ../source-builder/sb-set-builder --log=l-4.11-at.txt \
        --prefix=$HOME/development/rtems/4.11 4.11/rtems-autotools
@@ -131,7 +131,7 @@ passing them on the command line using the ``--macros`` option. For RTEMS these
 are held in ``config/snapshots`` directory. The following builds *newlib* from
 CVS:
     $ ../source-builder/sb-set-builder --log=l-4.11-sparc.txt \
@@ -141,7 +141,7 @@ CVS:
 and the following uses the version control heads for ``binutils``, ``gcc``,
 ``newlib``, ``gdb`` and *RTEMS*:
     $ ../source-builder/sb-set-builder --log=l-heads-sparc.txt \
        --prefix=$HOME/development/rtems/4.11-head \
diff --git a/user/rsb/third-party-packages.rst b/user/rsb/third-party-packages.rst
index c02153b..b8ca15a 100644
--- a/user/rsb/third-party-packages.rst
+++ b/user/rsb/third-party-packages.rst
@@ -39,7 +39,7 @@ needs to be the same as the prefix used to build RTEMS.
 To build Net-SNMP the command is:
     $ cd rtems-source-builder/rtems
     $ ../source-builder/sb-set-builder --log=log_sis_net_snmp \
diff --git a/user/testing/tftp.rst b/user/testing/tftp.rst
index 54b744a..1abf469 100644
--- a/user/testing/tftp.rst
+++ b/user/testing/tftp.rst
@@ -61,7 +61,7 @@ you follow the instructions for you target.
 Configure U-Boot to network boot using the TFTP protocol. This is U-Boot script
 for a Zedboard:
   loadaddr=0x02000000
   uenvcmd=echo Booting RTEMS Zed from net; set autoload no; dhcp; set serverip 10.10.5.2; tftpboot zed/rtems.img; bootm; reset;
@@ -166,7 +166,7 @@ substituted
 Some of these field are normally provided by a user's configuration. To do this
 use:
+.. code-block:: ini
   requires = bsp_tty_dev, target_on_command, target_off_command, target_reset_command
diff --git a/user/tools/bsp-builder.rst b/user/tools/bsp-builder.rst
index 0c1d330..7e79462 100644
--- a/user/tools/bsp-builder.rst
+++ b/user/tools/bsp-builder.rst
@@ -344,7 +344,7 @@ spinning disk mounted under `build`. The build uses a development source tree
 that is bootstrapped and ready to build. The source can have local patches that
 need to be regression tested:
   $ /opt/rtems/5/bin/rtems-bsp-builder --build-path=/build/rtems \
             --rtems-tools=/opt/work/rtems/5 \
@@ -393,7 +393,7 @@ need to be regression tested:
 To build a couple of BSPs you are interested in with tests:
diff --git a/user/tools/exeinfo.rst b/user/tools/exeinfo.rst
index 1913986..279129c 100644
--- a/user/tools/exeinfo.rst
+++ b/user/tools/exeinfo.rst
@@ -94,7 +94,7 @@ Examples
 Prints all reports for the ``hello.exe`` for the ``i386/pc686`` BSP:
   $ rtems-exeinfo -a i386-rtems5/c/pc686/testsuites/samples/hello/hello.exe
   RTEMS Executable Info 5.6f5cfada964c
@@ -168,7 +168,7 @@ drivers.
 Print the ``Init`` section data for the ``cdtest.exe`` for the ``i386/pc686`` BSP:
   $ rtems-exeinfo -I i386-rtems5/c/pc686/testsuites/samples/cdtest/cdtest.exe
diff --git a/user/tools/symbols.rst b/user/tools/symbols.rst
index 16e04ee..d1188f8 100644
--- a/user/tools/symbols.rst
+++ b/user/tools/symbols.rst
@@ -135,7 +135,7 @@ Examples
 Create a dynamlically loaded symbol table for the ``minimum.exe`` sample
 program for the ``i386/pc686`` BSP:
   $ rtems-syms -o ms.o i386-rtems5/c/pc686/testsuites/samples/minimum/minimum.exe
   $ file ms.o
@@ -143,7 +143,7 @@ program for the ``i386/pc686`` BSP:
 Run the same command, this time create a map file:
   $ rtems-syms -o ms.o -m ms.map i386-rtems5/c/pc686/testsuites/samples/minimum/minimum.exe
   $ head -10 ms.map
@@ -161,7 +161,7 @@ Run the same command, this time create a map file:
 Run the same command with a raise verbose level to observe the stages the
 command performs:
   $ rtems-syms -vvv -o ms.o i386-rtems5/c/pc686/testsuites/samples/minimum/minimum.exe
   RTEMS Kernel Symbols 5.a72a462adc18
diff --git a/user/tools/tester.rst b/user/tools/tester.rst
index 09d07ac..1a8f4a0 100644
--- a/user/tools/tester.rst
+++ b/user/tools/tester.rst
@@ -36,7 +36,7 @@ Available BSP testers
 You can list the available BSP testers with:
     $ rtems-test --list-bsps
     arm920
@@ -76,7 +76,7 @@ running the ``bootstrap`` procedure, building and finally installing the
 kernel. Be sure to enable tests by using ``--enable-tests`` option with
 configure after running ``bootstrap``.
     $ ../../rtems.git/configure --target=sparc-rtems5 \
                         --enable-tests --enable-rtemsbsp=erc32
@@ -97,7 +97,7 @@ Before running all the tests it is a good idea to run the ``hello`` test. The
 running it shows you have a working tool chain and build of RTEMS ready to run
 the tests. Using the run with the ERC32 BSP the command is:
     $ sparc-rtems5-run sparc-rtems5/c/erc32/testsuites/samples/hello/hello.exe
@@ -109,7 +109,7 @@ The run command is the GDB simulator without the GDB part.
 Running the example using GDB:
     $ sparc-rtems5-gdb sparc-rtems5/c/erc32/testsuites/samples/hello/hello.exe
     GNU gdb (GDB) 7.12
@@ -160,7 +160,7 @@ extension for RTEMS executables built within RTEMS.
 To run the erc32 tests enter the following command from the top of the erc32
 BSP build tree:
     $ ~/development/rtems/test/rtems-tools.git/tester/rtems-test \
              --log=log_erc32_run \
@@ -232,7 +232,7 @@ invalid count changing means a test running before this test started failed,
 not the starting test. The status here has 7 tests passed, no failures, 5
 timeouts and 1 invalid test.
     [ 5/13] p:2  f:0  u:0  e:0  I:0  B:0  t:0  i:0  | sparc/erc32: hello.exe
@@ -343,7 +343,7 @@ The output is tagged so you can determine where it comes from. The following is
 the complete output for the In Memory File System test ``imfs_fslink.exe``
 running on a Coldfire MCF5235 using GDB and a BDM pod:
     [ 11/472] p:9   f:0   t:0   i:1   | m68k/mcf5235: imfs_fslink.exe
     > gdb: ..../bin/m68k-rtems4.11-gdb -i=mi --nx --quiet ..../imfs_fslink.exe
@@ -427,7 +427,7 @@ Command Line Help
 The :program:`rtems-test` command line accepts a range of options. You can
 review the available option by the ``--help`` option:
     RTEMS Tools Project (c) 2012-2014 Chris Johns
     Options and arguments:
diff --git a/user/tracing/captureengine.rst b/user/tracing/captureengine.rst
index d04b8a4..a8bca53 100644
--- a/user/tracing/captureengine.rst
+++ b/user/tracing/captureengine.rst
@@ -19,7 +19,7 @@ file: `sparc-rtems5/c/erc32/testsuites/samples`. In order to access the capture
 testcase perform the following set of operations inside the RTEMS build
 directory.
   $ cd /sparc-rtems5/c/erc32/testsuites/samples
   $ sparc-rtems5-run ./capture.exe
@@ -98,7 +98,7 @@ traces the context switches between these tasks. ``cwceil`` and ``cwfloor`` are
 set to a narrow range of task priorities to avoid creating noise from a large
 number of context switches between tasks we are not interested in.
   *** BEGIN OF TEST CAPTURE ENGINE ***
   *** TEST VERSION: 5.0.0.de9b7d712bf5da6593386fd4fbca0d5f8b8431d8
diff --git a/user/tracing/examples.rst b/user/tracing/examples.rst
index c44daff..d0bef0b 100644
--- a/user/tracing/examples.rst
+++ b/user/tracing/examples.rst
@@ -46,7 +46,7 @@ has been stored) run the following commands to generate traces:
 BSP is configured with the following command -
   ../rtems/configure --target=sparc-rtems5 --prefix=/development/rtems/5 \
   --enable-networking --enable-tests --enable-rtemsbsp=erc32 --enable-cxx
@@ -58,7 +58,7 @@ following commands according to your installation. Also confirm the path of the
 fileio's executable and object files in the last line of the command according
   sparc-rtems5-gcc -Bsparc-rtems5/erc32/lib/ \
   -specs bsp_specs -qrtems -mcpu=cypress -O2 -g -ffunction-sections \
@@ -72,7 +72,7 @@ the application. The link command follows the escape sequence "--". "-C" option
 denotes the name of the user configuration file and "-W" specifies the name of
 the wrapper c file.
   rtems-tld -C fileio-trace.ini -W fileio-wrapper -- -Bsparc-rtems5/erc32/lib/ \
@@ -88,13 +88,13 @@ display the contents of the trace buffer and save the buffer to disk in the form
 of binary files. Use `rtrace -l` to list the availalble options for commands
 with `rtrace`.
   sparc-rtems5-run sparc-rtems5/c/erc32/testsuites/samples/fileio.exe
 The output from the above commands will be as follows:
   *** BEGIN OF TEST FILE I/O ***
diff --git a/user/tracing/tracelinker.rst b/user/tracing/tracelinker.rst
index b1e60fd..d32e52b 100644
--- a/user/tracing/tracelinker.rst
+++ b/user/tracing/tracelinker.rst
@@ -25,7 +25,7 @@ options it needs and the second part is a standard linker command line you would
 use to link an RTEMS application. The current command line for trace linker
 consists of:
   $ rtems-tld -h
   rtems-trace-ld [options] objects
@@ -482,12 +482,12 @@ commands in the topmost build directory to build the tools project:
 First we configure using:
   $./waf configure --prefix=$HOME/development/rtems/5
 Then we build and install using:
   $./waf build install
2.19.1
