[PATCH] bsp/lpc1768_mbed: Disable unsupported tests
Wed Feb 27 21:44:31 UTC 2019
On 26/2/19 5:50 pm, Sebastian Huber wrote:
> Yes, moving the test suite specific OPERATION_COUNT from the bsp.h to the *.tcfg
> would be good. However, I would like to resolve the build errors as soon as
> possible. So, change the patch to define OPERATION_COUNT to 10 and adjust the
> *.tcfg accordingly?
I agree. I am working on the .tcfg change but time is limited at the moment.
I am not sure if we need to change the tests using OPERATION_COUNT to avoid
clashes, that is, the .tcfg files would define TEST_OPERATION_COUNT or something
like that and if this is present it is used or the default (OPERATION_COUNT) is
used. This requires a change in the tests which is a tedious change. This last
part may happen in pieces.
