Doxygen @param and [in], [out] or [in,out]?
Sebastian Huber
Thu Feb 28 14:52:56 UTC 2019
Hello,
we agreed to use @param for function parameter documentation:
https://docs.rtems.org/branches/master/eng/coding-doxygen.html#doxygen-best-practices
Do we want to use [in], [out] or [in,out] as well?
If yes, how are [in], [out] or [in,out] used exactly? For example
consider values passed by reference. Is in
void f(int *a)
if (*a == 0) {
*a = 1;
the parameter a an [in,out] parameter? What about
void g(int *a)
*a = 1;
How can we ensure that this extra information is consistent throughout
the documentation?
I think we should remove all the [in], [out] or [in,out] stuff. From the
parameter type it is quite obvious how they are used, e.g. "type *param"
vs. "const type *param". For passed by value it is clear that they are
input parameters. Output only use is normally indicated by the function
name, e.g. "initialize", "set", "create", etc.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
