powerpc/mpc5643l_dpu: psxconfig01 too large
Joel Sherrill
joel at rtems.org
Thu Feb 28 23:00:36 UTC 2019
On Thu, Feb 28, 2019, 4:50 PM Chris Johns <chrisj at rtems.org> wrote:
> Hi,
> This test has a number of config values that overflow the memory on the
> powerpc/mpc5643l_dpu BSP. Can these value be reduced so they can fit?
> I can provide support in .tcfg files now to provide specific per BSP
> settings
> but I am not sure what the values should be for this BSP? Some guidance is
> most
> welcome.
Unfortunately I think this is a test like the old sp09 which crammed too
much into one executable. I think it needs to be split into multiple tests.
Ideally one per object class.
> Thanks
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190228/96d7f0a0/attachment.html>
