How can I check if a function exists in waf?
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Feb 1 09:06:00 UTC 2019
On Fri, 1 Feb 2019 at 12:13, Sebastian Huber <
> Hello,
> how can I check if a function exists in waf (similar to AC_CHECK_FUNC)?
> Currently, we get this output from the RTEMS tools waf configure (please
> note the "Invalid argument 'function_name' in test"):
> Hi,
The support for 'function_name' has been removed since waf 2 as it
was broken ( see
https://gitlab.com/ita1024/waf/blob/master/waflib/Tools/c_config.py#L420)
I guess the best option is to just use 'header_name' or to use the
'fragment' parameter to write a fragment that calls the desired function.
> ./waf configure
> Setting top to : /scratch/git-rtems-tools
> Setting out to : /scratch/git-rtems-tools/build
> Version : 5.551ce0825375-modified (5)
> Checking for program 'python' : /usr/bin/python
> Checking for python version >= 2.6.6 : 2.7.14
> Checking for program 'python2' : /usr/bin/python2
> Checking for program 'python3' : /usr/bin/python3
> Checking for 'gcc' (C compiler) : /usr/bin/gcc
> Checking for 'g++' (C++ compiler) : /usr/bin/g++
> Checking for header alloca.h : yes
> Checking for header fcntl.h : yes
> Checking for header process.h : not found
> Checking for header stdlib.h : yes
> Checking for header string.h : yes
> Checking for header strings.h : yes
> Checking for header sys/file.h : yes
> Checking for header sys/stat.h : yes
> Checking for header sys/time.h : yes
> Checking for header sys/types.h : yes
> Checking for header sys/wait.h : yes
> Checking for header unistd.h : yes
> Checking for header vfork.h : not found
> Checking for header sys/time.h sys/resource.h : yes
> Checking for program 'm4' : /usr/bin/m4
> Checking for header signal.h : yes
> 'configure' finished successfully (1.058s)
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190201/003b2105/attachment-0002.html>
