coverage : not getting coverage for leon3-sis-cov
Jiri Gaisler jiri at gaisler.se
Fri Feb 1 10:17:44 UTC 2019
On 2/1/19 9:34 AM, Sebastian Huber wrote:
> Hello,
> you need the tools from the latest RSB.
> However, the SIS crashed using an ERC32 test program:
Yes, seems like I broke erc32 emulation. Leon2/3 still works fine - I will investigate...
> gdb --args sparc-rtems5-sis -nouartrx -r -cov spsysinit01.exe
> GNU gdb (GDB; devel:gcc) 8.2
> Copyright (C) 2018 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law.
> Type "show copying" and "show warranty" for details.
> This GDB was configured as "x86_64-suse-linux".
> Type "show configuration" for configuration details.
> For bug reporting instructions, please see:
> <http://bugs.opensuse.org/>.
> Find the GDB manual and other documentation resources online at:
>     <http://www.gnu.org/software/gdb/documentation/>.
> For help, type "help".
> Type "apropos word" to search for commands related to "word"...
> No symbol table is loaded.  Use the "file" command.
> Reading symbols from sparc-rtems5-sis...done.
> (gdb) r
> Starting program: /build/rtems/5/bin/sparc-rtems5-sis -nouartrx -r -cov spsysinit01.exe
> Missing separate debuginfo for /lib64/ld-linux-x86-64.so.2
> Try: zypper install -C "debuginfo(build-id)=4062821f420b0c3d46ea03f208cae1a710516c4e"
> Missing separate debuginfo for /lib64/libtinfo.so.6
> Try: zypper install -C "debuginfo(build-id)=613f86254ba17e5782301403eba051a20a0d7480"
> Missing separate debuginfo for /lib64/libdl.so.2
> Try: zypper install -C "debuginfo(build-id)=466795ee7b9ca76122c66d034e7f18c7593d306e"
> Missing separate debuginfo for /lib64/libm.so.6
> Try: zypper install -C "debuginfo(build-id)=1e8038d58788ff7546c54ef151a441567c5119dc"
> Missing separate debuginfo for /lib64/libc.so.6
> Try: zypper install -C "debuginfo(build-id)=95b799e45a989e22af6e9d31ec729170e2c92dd2"
>  SIS - SPARC/RISCV instruction simulator 2.10,  copyright Jiri Gaisler 1995
>  Bug-reports to jiri at gaisler.se
>  ERC32 emulation enabled
> Program received signal SIGSEGV, Segmentation fault.
> 0x000000000040c0f5 in cov_start (address=33554432) at ../../../sourceware-mirror-binutils-gdb-ce73f310150418a9a1625ab60a527d959096a9e2/sim/sis/func.c:1300
> 1300 ../../../sourceware-mirror-binutils-gdb-ce73f310150418a9a1625ab60a527d959096a9e2/sim/sis/func.c: No such file or directory.
> (gdb) bt
> #0  0x000000000040c0f5 in cov_start (address=33554432) at ../../../sourceware-mirror-binutils-gdb-ce73f310150418a9a1625ab60a527d959096a9e2/sim/sis/func.c:1300
> #1  run_sim (icount=icount at entry=9223372036854775807, dis=dis at entry=0) at ../../../sourceware-mirror-binutils-gdb-ce73f310150418a9a1625ab60a527d959096a9e2/sim/sis/func.c:1102
> #2  0x000000000040d36d in exec_cmd (cmd=cmd at entry=0x4a71cd "run") at ../../../sourceware-mirror-binutils-gdb-ce73f310150418a9a1625ab60a527d959096a9e2/sim/sis/func.c:330
> #3  0x0000000000403d29 in main (argc=<optimized out>, argv=0x7fffffffd828) at ../../../sourceware-mirror-binutils-gdb-ce73f310150418a9a1625ab60a527d959096a9e2/sim/sis/sis.c:202
> (gdb) quit
