How can I check if a function exists in waf?
    Chris Johns
    chrisj at rtems.org
    Sat Feb  2 01:07:02 UTC 2019
On 1/2/19 8:19 pm, Sebastian Huber wrote:
> So, there is no standard compile and link test for functions? If I use this
>     conf.check_cc(fragment = 'int main(void) { strnlen("", 0); return 0; }',
>                   header_name="string.h", features = 'c', mandatory = False)
> waf outputs
> Checking for header string.h                  : yes
> I don't want to test for string.h, I want to test for strnlen(). In config.log
> we have:
> [1/1] Compiling [32mbuild/.conf_check_6da1e91772980301eb2528a1d150a7ab/test.c[0m
> ['/usr/bin/gcc', '../test.c', '-c',
> '-o/scratch/git-rtems-tools/build/.conf_check_6da1e91772980301eb2528a1d150a7ab/testbuild/test.c.1.o']
> err: ../test.c: In function ‘main’:
> ../test.c:1:18: warning: implicit declaration of function ‘strnlen’
> [-Wimplicit-function-declaration]
> yes
> So, this test uses already quite some code and still is basically useless.
You have a powerful language available. I would create a function to handle
repeated checks, for example:
https://git.rtems.org/chrisj/rtems_waf.git/tree/rtems.py?h=libbsd-libdl#n270
I think having the ability to perform checks for an RTEMS application highlights
the power available.
