[PATCH] RSB/gdb: upgrade sis to 2.11
    Joel Sherrill
    joel at rtems.org
    Mon Feb  4 14:59:41 UTC 2019
On Mon, Feb 4, 2019 at 4:56 AM Chris Johns <chrisj at rtems.org> wrote:
> On 4/2/19 9:49 pm, Jiri Gaisler wrote:
> > These two patches should be applied to gdb-8.2.1 to build sis for SPARC
> and RISC-V:
> > https://gaisler.se/gdb/gdb-8.2.1-riscv-config.patch
> > https://gaisler.se/gdb/gdb-8.2.1-sis-2.11.patch
> > I have tested building and running all RTEMS tests - works fine.
> > I think it is fine to switch all other targets to gdb-8.2.1 also. Should
> simplify things ...
> Awesome, I will sort this out tomorrow.
Should we also bump binutils to the release (2.32) from last week?
> Thanks
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190204/92d10ad4/attachment-0002.html>
