[PATCH] RSB/gdb: upgrade sis to 2.11
    Chris Johns
    chrisj at rtems.org
    Tue Feb  5 04:21:47 UTC 2019
On 4/2/19 9:49 pm, Jiri Gaisler wrote:
> These two patches should be applied to gdb-8.2.1 to build sis for SPARC and RISC-V:
Thanks.
> https://gaisler.se/gdb/gdb-8.2.1-riscv-config.patch
> https://gaisler.se/gdb/gdb-8.2.1-sis-2.11.patch
I see in this patch `erc32` has been removed and replaced with `sis`. What does
this mean?
I have attached the patches to #3460. The SIS patch had to be compressed.
> I have tested building and running all RTEMS tests - works fine.
> I think it is fine to switch all other targets to gdb-8.2.1 also. Should simplify things ...
I agree. Thank you for the patches and your testing.
