[PATCH] Coverage: Add support for TSIM format
    Chris Johns
    chrisj at rtems.org
    Thu Feb  7 18:45:41 UTC 2019
On 7/2/19 7:17 pm, Vijay Kumar Banerjee wrote:
> I'm trying to do this ...
> diff --git a/tester/rtems/testing/bsps/leon3-sis-cov.ini
> b/tester/rtems/testing/bsps/leon3-sis-cov.ini
> index d60257c..e450b60 100644
> --- a/tester/rtems/testing/bsps/leon3-sis-cov.ini
> +++ b/tester/rtems/testing/bsps/leon3-sis-cov.ini
> @@ -38,4 +38,4 @@ tester         = %{_rtscripts}/run.cfg
>  target         = sparc-rtems5
>  bsp_run_cmd    = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
>  bsp_run_opts   = -leon3 -nouartrx -r -tlim 200 s -cov
> -bsp_covoar_cmd = -E %{cov_explanations} -f TSIM
> +bsp_covoar_cmd = -S %{bsp_symbol_path} -p %{project_name} -E
Can the common options be moved to coverage part of qemu.cfg?
> diff --git a/tester/rtems/testing/defaults.mc <http://defaults.mc>
> b/tester/rtems/testing/defaults.mc <http://defaults.mc>
> index 54212e0..d3e16a9 100644
> --- a/tester/rtems/testing/defaults.mc <http://defaults.mc>
> +++ b/tester/rtems/testing/defaults.mc <http://defaults.mc>
> @@ -122,5 +122,9 @@ _rtbase:             none,    none,     '%{_rtdir}'
>  _rttesting:          none,    none,     '%{_rtbase}/rtems/testing'
>  _configdir:          none,    none,     '%{_rtbase}/config:%{_rttesting}'
> +#Coverage macros
> +bsp_symbol_path:     none,    none,
> '%{_rtscripts}/coverage/%{bsp}-symbols.ini'
> +project_name:        none,    none,      'RTEMS-%{rtems_version}'
> I'm getting an error "error: cannot expand default macro: %{rtems_version} "
> I see the rtems_version macro if I print the macros. How do I access this macro?
Please add `--trace` to the command line and see how the cfg files are being
processed. Compare this to a tester command that is working.
