autotools build fail from rsb
    Joel Sherrill
    joel at rtems.org
    Mon Feb 11 17:33:29 UTC 2019
I had an osboxes.org VM laying around from a previous experiment.
$ ../source-builder/sb-set-builder --trace --log=l-qemu.txt
--prefix=${HOME}/rtems-work/tools/5 devel/qemu
Ends with this:
config.status: creating Makefile
config.status: creating t/wrap/aclocal-1.12
config.status: creating t/wrap/automake-1.12
+ make all
  GEN      automake
  GEN      aclocal
  GEN      t/ax/shell-no-trail-bslash
  GEN      runtest
  GEN      doc/aclocal.1
  GEN      doc/automake.1
  GEN      lib/Automake/Config.pm
  GEN      doc/aclocal-1.12.1
  GEN      doc/automake-1.12.1
help2man: can't get `--help' info from automake-1.12
Try `--no-discard-stderr' if option outputs to stderr
Makefile:4114: recipe for target 'doc/automake-1.12.1' failed
make: *** [doc/automake-1.12.1] Error 255
shell cmd failed: /bin/sh -ex
/home/osboxes/rtems-work/rtems-source-builder/bare/build/automake-1.12.6-x86_64-linux-gnu-1/do-build
error: building automake-1.12.6-x86_64-linux-gnu-1
  See error report: rsb-report-automake-1.12.6-x86_64-linux-gnu-1.txt
$ help2man --version
GNU help2man 1.47.6
Copyright (C) 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2009,
2010,
2011, 2012, 2013, 2014, 2015, 2016, 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Written by Brendan O'Dea <bod at debian.org>
Not sure if that helps or not. I am sure the qemu version used in the base
RSB is fairly old though.
--joel
On Sun, Feb 10, 2019 at 9:48 PM Chris Johns <chrisj at rtems.org> wrote:
> On 11/2/19 9:21 am, Gedare Bloom wrote:
> > It seems to be happening during Debian / Ubuntu builds of Qemu using RSB.
> Thanks for confirming this. I will take a look.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190211/4c14e135/attachment-0002.html>
