[PATCH 3/4] libdl/archive: Check for an overflow of the symbol table.
    chrisj at rtems.org
    chrisj at rtems.org
    Mon Feb 18 02:33:26 UTC 2019
Coverty 1442636
Updates #3686
 cpukit/libdl/rtl-archive.c | 15 ++++++++++++---
 1 file changed, 12 insertions(+), 3 deletions(-)
diff --git a/cpukit/libdl/rtl-archive.c b/cpukit/libdl/rtl-archive.c
index 8490b4bc07..77ad2b0d30 100644
--- a/cpukit/libdl/rtl-archive.c
+++ b/cpukit/libdl/rtl-archive.c
@@ -678,10 +678,20 @@ rtems_rtl_archive_loader (rtems_rtl_archive* archive, void* data)
-       * The first 4 byte value is the number of entries.
+       * The first 4 byte value is the number of entries. Range check the
+       * value so the alloc size does not overflow (Coverity 1442636).
       archive->symbols.entries =
         rtems_rtl_archive_read_32 (archive->symbols.base);
+      if (archive->symbols.entries >= (SIZE_MAX / sizeof (rtems_rtl_archive_symbol)))
+        rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_SYMBOL, archive->symbols.base);
+        close (fd);
+        memset (&archive->symbols, 0, sizeof (archive->symbols));
+        rtems_rtl_archive_set_error (errno, "too many symbols");
+        return true;
       archive->symbols.size   = size;
       archive->symbols.names  = archive->symbols.base;
       archive->symbols.names += (archive->symbols.entries + 1) * 4;
@@ -691,8 +701,7 @@ rtems_rtl_archive_loader (rtems_rtl_archive* archive, void* data)
       if (archive->symbols.entries > RTEMS_RTL_ARCHIVE_SYMBOLS_SORT)
-        const size_t size =
-          archive->symbols.entries * sizeof (rtems_rtl_archive_symbol);
+        size = archive->symbols.entries * sizeof (rtems_rtl_archive_symbol);
         archive->symbols.symbols =
           rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_SYMBOL, size, true);
         if (archive->symbols.symbols != NULL)
2.19.1
