'pax' is missing from list of required-packages, for host setup, for Arch Linux, in the documentation
Thu Feb 21 15:00:56 UTC 2019
Thanks for reporting this.
Any chance you can provide a patch for that section of rtems-docs?
On Thu, Feb 21, 2019, 8:25 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> BSP Build fails if I configure RTEMS to enable
> RTEMS TESTER AND RUN as mentioned in: https://docs.rtems.org/branches/master/user/tools/tester.html#building-rtems-tests
> [varodek at varodek home]$ cd ~/development/rtems/kernel[varodek at varodek kernel]$ mkdir erc32 && cd erc32
> [varodek at varodek erc32]$ /home/varodek/development/rtems/kernel/rtems/configure
> --prefix=/home/varodek/development/rtems/5 --enable-maintainer-mode
> --target=sparc-rtems5 --enable-rtemsbsp=erc32 *--enable-tests*
> --enable-posix --disable-networking
> Build fails:
> [varodek at varodek erc32]$ make -j 2
> checking for RTEMS_POSIX_API... yes
> checking whether ln -s works... yes
> checking for pax... no
> checking for gzip... /usr/bin/gzip
> checking for xz... /usr/bin/xz
> configure: error: pax is missing.
> configure: error:
> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/libtests/configure
> failed for libtests
> configure: error: /bin/sh
> '/home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/configure'
> failed for ../../testsuites
> make[2]: *** [Makefile:731: erc32] Error 1
> make[2]: Leaving directory
> '/home/varodek/development/rtems/kernel/erc32/sparc-rtems5/c'
> make[1]: *** [Makefile:289: all-recursive] Error 1
> make[1]: Leaving directory
> make: *** [Makefile:410: all-recursive] Error 1
> The *pax* package is not installed by default in Arch Linux. Moreover it
> is also not present in its official repository. We need to clone, build and
> install it from Arch User Repository (AUR).
> This thing is missing in the documentation of host setup for Arch Linux
> at: https://docs.rtems.org/branches/master/user/hosts/posix.html#archlinux
> The details of my OS:
>     OS: Linux
>     Kernel Version: 4.20.3-arch1-1-ARCH
>     Distribution: Arch Linux
>     CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
> cdc
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190221/37f58ec2/attachment-0002.html>
