[PATCH] Update User Documentation for Host setup for Linux
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Thu Feb 28 03:38:43 UTC 2019
Thankyou for support!
On Thu, 28 Feb, 2019, 5:05 AM Chris Johns <chrisj at rtems.org wrote:
> Pushed with the following minor changes.
> - the git commit message was wrapped to 80 columns
> - a `the` was added.
> Thank you for this patch. The online docs have been updated. :)
> Chris
> On 27/2/19 9:07 am, Vaibhav Gupta wrote:
> > Mention the requirement of 'pax' package for building BSP if RTEMS is
> configured with '--enable-tests' option, else build fails.
> > user/hosts/posix.rst | 5 +++++
> > user/tools/tester.rst | 2 ++
> > 2 files changed, 7 insertions(+)
> > diff --git a/user/hosts/posix.rst b/user/hosts/posix.rst
> > index 063ebe2..bcc2646 100644
> > --- a/user/hosts/posix.rst
> > +++ b/user/hosts/posix.rst
> > @@ -40,6 +40,11 @@ control of the machine. We call this project
> sandboxing and
> > Linux
> > +BSP Build will require ``pax`` package if RTEMS is configured with
> > +``--enable-tests`` option, see :ref:`BuildingRTEMSTests`. This package
> is not
> > +installed , by default, on many Linux distributions, you can check for
> it
> > +using your package manager. Install it, if it is not present on your
> system.
> > A number of different Linux distrubutions are known to work. The
> following have
> > been tested and report as working.
> > diff --git a/user/tools/tester.rst b/user/tools/tester.rst
> > index 09d07ac..967016e 100644
> > --- a/user/tools/tester.rst
> > +++ b/user/tools/tester.rst
> > @@ -68,6 +68,8 @@ There is the ``erc32`` tester which uses the GDB
> back-end and the
> > how to use :program:`rtems-test` command with the erc32 BSP because it
> is easy
> > to build an use.
> > +.. _BuildingRTEMSTests:
> > Building RTEMS Tests
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190228/bbe7424b/attachment-0002.html>
