Doxygen @return vs. @retval
Joel Sherrill
joel at rtems.org
Thu Feb 28 16:06:12 UTC 2019
On Thu, Feb 28, 2019 at 9:03 AM Sebastian Huber <
> Hello,
> we agreed to use @retval instead of @return:
> https://docs.rtems.org/branches/master/eng/coding-doxygen.html#doxygen-best-practices
Is there going to be a global replacement or have they been purged?
> How should we indicate that not a particular value is returned, but
> instead an element of a set. For example:
> * @brief Performs something and returns the operation status.
> * @retval 0 Successful operation.
> * @retval EIO Input/output error.
> * @retval <otherwise> Any other value will not be returned.
> int f(void);
That last @retval doesn't match what I thought your statement above
indicated.
The English on the last @retval say there are no more. Why even include
that?
If you mean other errno's may be returned, that's different.
What about the -1 and errno cases?
> * @brief Creates an object.
> * @retval NULL Not enough resources to create an object.
> * @retval <object> Pointer to created object.
> T *create(void);
> We may also use "[object]" or "{object}" or "object" or whatever.
Can we use "instance of T"?
I assume you used object generically. Wouldn't it be the specific noun for
the created object?
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190228/00dd8242/attachment-0002.html>
