arm-rtems5-g++ -std=c++11 and -std=c++0x support
Misra, Avinash Avinash.Misra at jhuapl.edu
Fri Jan 4 21:09:12 UTC 2019
Hi,
Does the RTEMS 5 ARM G++ Cross Compiler support the -std flag? I've tried using -std=c++0x and -std=c++11 and both times I have gotten errors with type definitions in the standard includes. If the arm-rtems5-g++ cross compiler doesn't support specifying which c++ standard to use then which standard is it using?
Thanks,
Avi
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190104/29655a39/attachment.html>
