[PATCH] 6: Add unstable RTEMS 6 tool chain
Mon Jan 7 12:58:44 UTC 2019
I was able to build all tools except epiphany on a FreeBSD 11 machine. I
built the erc32 BSP and did a test run. One problem was this:
rtems-test --rtems-bsp=erc32 --rtems-tools=/opt/rtems/6
/home/user/build/b-erc32
RTEMS Testing - Tester, 5.0.not_released
  Command Line: /opt/rtems/6/bin/rtems-test --rtems-bsp=erc32
--rtems-tools=/opt/rtems/6 /home/user/build/b-erc32
  Python: 2.7.12 (default, Oct 29 2016, 13:38:04) [GCC 4.2.1 Compatible
FreeBSD Clang 3.8.0 (tags/RELEASE_380/final 262564)]
Host: FreeBSD-11.1-RELEASE-p1-amd64-64bit-ELF (FreeBSD FreeBSDBuild
11.1-RELEASE-p1 FreeBSD 11.1-RELEASE-p1 #0: Wed Aug  9 11:55:48 UTC 2017
root at amd64-builder.daemonology.net:/usr/obj/usr/src/sys/GENERIC amd64 amd64)
[  3/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: whetstone.exe
[  6/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: fsdosfsformat01.exe
[  1/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: dhrystone.exe
[  2/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: linpack.exe
[  5/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: fsclose01.exe
[  4/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: fsbdpart01.exe
[  8/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: fsdosfsname02.exe
[  7/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: fsdosfsname01.exe
error: gdb exec: /opt/rtems/6/bin/sparc-rtems5-gdb: No such file or
directory
I fixed this with a symbolic link:
ln -s /opt/rtems/6/bin/sparc-rtems6-gdb /opt/rtems/6/bin/sparc-rtems5-gdb
I will try to automate this to get a weekly update.
What do we want to do with failing targets? I will probably take care of
the main stream targets, but what about epiphany?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
