Status of RISCV port on sis
Mon Jan 7 14:31:18 UTC 2019
On 07/01/2019 15:21, Jiri Gaisler wrote:
> The sp37 test fails with an interesting error:
>   *** BEGIN OF TEST SP 37 ***
> ] *** TEST VERSION: 5.0.0.eba55a6ad63a1433f50ba0d627394f447bacd04f-modified
> ] *** TEST STATE: EXPECTED-PASS
> ] *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
> ] *** TEST TOOLS: 9.0.0 20181112 (RTEMS 5, RSB
> 96673d751ab488d5d892ae67c1842aef9d5c068b, Newlib
> df6915f029ac9acd2b479ea898388cbd7dda4974)
> /home/jiri/ibm/src/rtems/rtems.seb/c/src/../../testsuites/sptests/sp37/init.c:
> 185 normal_interrupt_level != _ISR_Get_level()
> ] *** FATAL ***
> The RISCV port has only two interrupt levels (on/off), and it seems that
> when a task at level one (irq off) is deleted, the heir inherits
> interrupt level one rather then restore its original level. Has anyone
> seen this on RISCV before? It is probably something in my setup (sim or
> bsp) but the test runs without interrupts and always fails the same way
> regardless of compiler optimization etc.
This is indeed an interesting case. The RISC-V and ARM context switch
code no longer saves and restores the interrupt status. You probably
found a weak spot in threaddispatch.c:
void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level )
   Thread_Control *executing;
   _Assert( cpu_self->thread_dispatch_disable_level == 1 );
#if defined(RTEMS_SCORE_ROBUST_THREAD_DISPATCH)
   if (
     !_ISR_Is_enabled( level )
#if defined(RTEMS_SMP)
       && rtems_configuration_is_smp_enabled()
#endif
     _Internal_error( INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT );
#endif
I think we have to remove the rtems_configuration_is_smp_enabled()
condition. Deleting the thread with interrupts disabled should result in
a fatal error (INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
