Status of RISCV port on sis
Mon Jan 7 14:55:34 UTC 2019
On 07/01/2019 15:47, Jiri Gaisler wrote:
> On 1/7/19 3:31 PM, Sebastian Huber wrote:
>> On 07/01/2019 15:21, Jiri Gaisler wrote:
>>> The sp37 test fails with an interesting error:
>>>    *** BEGIN OF TEST SP 37 ***
>>> ] *** TEST VERSION:
>>> 5.0.0.eba55a6ad63a1433f50ba0d627394f447bacd04f-modified
>>> ] *** TEST STATE: EXPECTED-PASS
>>> ] *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
>>> ] *** TEST TOOLS: 9.0.0 20181112 (RTEMS 5, RSB
>>> 96673d751ab488d5d892ae67c1842aef9d5c068b, Newlib
>>> df6915f029ac9acd2b479ea898388cbd7dda4974)
>>> /home/jiri/ibm/src/rtems/rtems.seb/c/src/../../testsuites/sptests/sp37/init.c:
>>> 185 normal_interrupt_level != _ISR_Get_level()
>>> ] *** FATAL ***
>>> The RISCV port has only two interrupt levels (on/off), and it seems that
>>> when a task at level one (irq off) is deleted, the heir inherits
>>> interrupt level one rather then restore its original level. Has anyone
>>> seen this on RISCV before? It is probably something in my setup (sim or
>>> bsp) but the test runs without interrupts and always fails the same way
>>> regardless of compiler optimization etc.
>> This is indeed an interesting case. The RISC-V and ARM context switch
>> code no longer saves and restores the interrupt status. You probably
>> found a weak spot in threaddispatch.c:
>> void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level )
>>    Thread_Control *executing;
>>    _Assert( cpu_self->thread_dispatch_disable_level == 1 );
>> #if defined(RTEMS_SCORE_ROBUST_THREAD_DISPATCH)
>>    if (
>>      !_ISR_Is_enabled( level )
>> #if defined(RTEMS_SMP)
>>        && rtems_configuration_is_smp_enabled()
>> #endif
>>      _Internal_error( INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT );
>> #endif
>> I think we have to remove the rtems_configuration_is_smp_enabled()
>> condition. Deleting the thread with interrupts disabled should result
>> in a fatal error (INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT).
> I compared this with SPARC/leon3, which has 16 levels (0 - 15). At level
> 15, interrupts are effectively disabled but the interrupt level is still
> restored and sp37 test works. At the moment I do not compile with SMP
> and I don't have RTEMS_SCORE_ROBUST_THREAD_DISPATCH defined. So none of
> the above code is active ...
This is another bug, the RISC-V should have this:
#define CPU_ENABLE_ROBUST_THREAD_DISPATCH TRUE
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
