[PATCH] 6: Add unstable RTEMS 6 tool chain
Tue Jan 8 09:49:11 UTC 2019
On 08/01/2019 05:13, Chris Johns wrote:
> On 7/1/19 11:58 pm, Sebastian Huber wrote:
>> I was able to build all tools except epiphany on a FreeBSD 11 machine. I built
>> the erc32 BSP and did a test run. One problem was this:
>> rtems-test --rtems-bsp=erc32 --rtems-tools=/opt/rtems/6 /home/user/build/b-erc32
>> RTEMS Testing - Tester, 5.0.not_released
>>   Command Line: /opt/rtems/6/bin/rtems-test --rtems-bsp=erc32
>>   Python: 2.7.12 (default, Oct 29 2016, 13:38:04) [GCC 4.2.1 Compatible FreeBSD
>> Clang 3.8.0 (tags/RELEASE_380/final 262564)]
>> Host: FreeBSD-11.1-RELEASE-p1-amd64-64bit-ELF (FreeBSD FreeBSDBuild
>> 11.1-RELEASE-p1 FreeBSD 11.1-RELEASE-p1 #0: Wed Aug  9 11:55:48 UTC 2017
>> root at amd64-builder.daemonology.net:/usr/obj/usr/src/sys/GENERIC amd64 amd64)
>> [  3/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   | sparc/erc32:
>> whetstone.exe
>> [  6/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   | sparc/erc32:
>> fsdosfsformat01.exe
>> [  1/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   | sparc/erc32:
>> dhrystone.exe
>> [  2/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   | sparc/erc32:
>> linpack.exe
>> [  5/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   | sparc/erc32:
>> fsclose01.exe
>> [  4/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   | sparc/erc32:
>> fsbdpart01.exe
>> [  8/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   | sparc/erc32:
>> fsdosfsname02.exe
>> [  7/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   | sparc/erc32:
>> fsdosfsname01.exe
>> error: gdb exec: /opt/rtems/6/bin/sparc-rtems5-gdb: No such file or directory
> Ouch.
>> I fixed this with a symbolic link:
>> ln -s /opt/rtems/6/bin/sparc-rtems6-gdb /opt/rtems/6/bin/sparc-rtems5-gdb
> I thought there was a version option but I cannot see it. Please raise a ticket
> on me to add a --version option to allow this to handled cleanly.
https://devel.rtems.org/ticket/3671
>> I will try to automate this to get a weekly update.
> What is updated each week?
GDB, Newlib, Binutils, GCC.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
