[PATCH 1/6] Remove build date from first page
Tue Jan 8 13:14:17 UTC 2019
On 08/01/2019 07:53, Chris Johns wrote:
>> On 8 Jan 2019, at 5:19 pm, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>>> On 08/01/2019 02:59, Chris Johns wrote:
>>>> On 7/1/19 11:30 pm, Sebastian Huber wrote:
>>>>> On 07/01/2019 12:49, Sebastian Huber wrote:
>>>>> On 07/01/2019 12:39, Chris Johns wrote:
>>>>>>> On 7 Jan 2019, at 10:03 pm, Sebastian Huber
>>>>>>> The usage of a build date prevents reproducible builds.
>>>>>> -1
>>>>>> I prefer a build date being present. For unreleased it marks the online
>>>>>> builds and for releases it tags the day built.
>>>>> Adding the Git commit to the documents would be more useful. The build date is
>>>>> completely arbitrary.
>>>> What do you think about replacing the date with a Git commit hash? I can try to
>>>> do this.
>>> For branch builds this is OK and I am happy to see it added and for releases we
>>> also need to have the release details.
>>> Technically a hash is all that is needed so it is correct if you need to
>>> determined the exact source used but is this what people expect with
>>> documentation, ie is a date expected?
>>> The catalog holds the build date which is shown if you point a browser at the
>>> documentation. Our online page has this.
>>> If the users and community are OK with no date in the documentation then I am
>>> OK. I am still not sure how repeatable builds of docs can be made because of the
>>> dependence on so many other parts that can vary. I also do not know how you
>>> perform the comparison on a PDF.
>> What about the Git commit hash and the check in date of the commit?
> That is a good idea. The catalogue can still have the build date and the PDF has the creation date in it’s properties.
Getting the information from git is easy:
Figure out if the checkout is modified:
git diff-index --quiet HEAD
Get the commit hash and date:
git log -1 --format='%H %cd' --date=format:%Y-%M-%d
What should I use to execute the git command and get the output in
"common/conf.py"? The subprocess command is only available in Python 3.5
and later.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
