[PATCH] Replace build date with Git hash and commit date
Sebastian Huber
Wed Jan 9 08:24:47 UTC 2019
The usage of a build date prevents reproducible builds.
common/conf.py | 25 +------------------------
common/waf.py | 22 ++--------------------
wscript | 39 ++++++++++++++++++++++++++++++++++++---
3 files changed, 39 insertions(+), 47 deletions(-)
diff --git a/common/conf.py b/common/conf.py
index 60db066..8d5e6b8 100644
--- a/common/conf.py
+++ b/common/conf.py
@@ -1,26 +1,3 @@
-import datetime
-def build_date():
- now = datetime.date.today()
- m = now.strftime('%B')
- y = now.strftime('%Y')
- if now.day == 11:
- s = 'th'
- elif now.day % 10 == 1:
- s = 'st'
- elif now.day == 12:
- s = 'th'
- elif now.day % 10 == 2:
- s = 'nd'
- elif now.day == 13:
- s = 'th'
- elif now.day == 3:
- s = 'rd'
- else:
- s = 'th'
- d = '%2d%s' % (now.day, s)
- return '%s %s %s' % (d, m, y)
extensions = [
"sphinx.ext.autodoc",
"sphinx.ext.coverage",
@@ -47,7 +24,7 @@ master_doc = 'index'
# General information about the project.
project = u'RTEMS Documentation Project'
-copyright = u'2018, RTEMS Project (built %s)' % (build_date())
+copyright = u'2018, RTEMS Project'
# The version info for the project you're documenting, acts as replacement for
# |version| and |release|, also used in various other places throughout the
diff --git a/common/waf.py b/common/waf.py
index d2cb432..01dd24f 100644
--- a/common/waf.py
+++ b/common/waf.py
@@ -17,24 +17,8 @@ import latex
sphinx_min_version = (1, 3)
-def build_date():
- import datetime
- if now.day % 10 == 1:
- s = 'st'
- s = 'nd'
- s = 'rd'
- else:
- s = 'th'
def version_cmdline(ctx):
- return '-Drelease="%s" -Dversion="%s"' % (ctx.env.VERSION, ctx.env.VERSION)
+ return '-Drelease="%s" -Dversion="%s"' % (ctx.env.RELEASE, ctx.env.VERSION)
def sphinx_cmdline(ctx, build_type, conf_dir, doctrees,
source_dir, output_dir, configs = []):
@@ -207,8 +191,6 @@ def check_sphinx_extension(ctx, extension):
def cmd_configure(ctx):
check_sphinx = not ctx.env.BIN_SPHINX_BUILD
if check_sphinx:
- ctx.msg('Checking version', ctx.env.VERSION)
ctx.find_program("sphinx-build", var="BIN_SPHINX_BUILD", mandatory = True)
ctx.find_program("aspell", var = "BIN_ASPELL", mandatory = False)
@@ -502,7 +484,7 @@ def xml_catalogue(ctx, building):
cat = xml.Document()
root = cat.createElement('rtems-docs')
- root.setAttribute('date', build_date())
+ root.setAttribute('date', ctx.env.DATE)
cat.appendChild(root)
heading = cat.createElement('catalogue')
diff --git a/wscript b/wscript
index 82d5eaa..1488d3a 100644
--- a/wscript
+++ b/wscript
@@ -9,8 +9,6 @@ path.append(abspath('common'))
import waflib
import waf as docs_waf
-version = '5.0.0 (master)'
build_all = ['user',
'rsb',
'c-user',
@@ -31,7 +29,6 @@ def options(opt):
docs_waf.cmd_options(opt)
def configure(conf):
- conf.env.VERSION = version
for b in building:
conf.recurse(b)
conf.env['BUILD_FROM_TOP'] = 'yes'
@@ -53,7 +50,43 @@ def coverpage_js(ctx):
with open(ctx.outputs[0].abspath(), 'w') as o:
o.write(js.replace('@CATALOGUE', xml))
+def pretty_day(day):
+ if day == 3:
+ s = 'rd'
+ elif day == 11:
+ s = 'th'
+ elif day == 12:
+ s = 'th'
+ elif day == 13:
+ s = 'th'
+ elif day % 10 == 1:
+ s = 'st'
+ elif day % 10 == 2:
+ s = 'nd'
+ else:
+ s = 'th'
+ return str(day) + s
def build(ctx):
+ # Get date and version from Git
+ version = '5.0.0'
+ if ctx.exec_command(['git', 'diff-index', '--quiet', 'HEAD']) == 0:
+ modified = ''
+ else:
+ modified = '-modified'
+ try:
+ out = ctx.cmd_and_log(['git', 'log', '-1', '--format=%H,%cd', '--date=format:%e,%B,%Y'])
+ f = out.strip('\n').split(',')
+ version = version + '.' + f[0] + modified
+ date = pretty_day(int(f[1])) + ' ' + f[2] + ' ' + f[3]
+ except waflib.Build.Errors.WafError:
+ date = 'unknown date'
+ ctx.env.DATE = date
+ ctx.env.RELEASE = version + ' (' + date + ')'
+ ctx.env.VERSION = version
# Generate any PlantUML images if enabled.
2.16.4
