[PATCH 2/3] Remove superfluous "All rights reserved."
Wed Jan 9 15:14:05 UTC 2019
 bsp-howto/ada95_interrupt.rst                  | 1 -
 bsp-howto/ata.rst                              | 1 -
 bsp-howto/clock.rst                            | 1 -
 bsp-howto/console.rst                          | 1 -
 bsp-howto/frame_buffer.rst                     | 1 -
 bsp-howto/getentropy.rst                       | 1 -
 bsp-howto/i2c.rst                              | 1 -
 bsp-howto/ide_controller.rst                   | 1 -
 bsp-howto/initilization_code.rst               | 1 -
 bsp-howto/linker_script.rst                    | 1 -
 bsp-howto/miscellanous_support.rst             | 1 -
 bsp-howto/networking.rst                       | 1 -
 bsp-howto/preface.rst                          | 1 -
 bsp-howto/real_time_clock.rst                  | 1 -
 bsp-howto/shared_memory_support.rst            | 1 -
 bsp-howto/spi.rst                              | 1 -
 bsp-howto/target_dependant_files.rst           | 1 -
 bsp-howto/timer.rst                            | 1 -
 c-user/ada_support.rst                         | 1 -
 c-user/barrier_manager.rst                     | 1 -
 c-user/board_support_packages.rst              | 1 -
 c-user/chains.rst                              | 1 -
 c-user/clock_manager.rst                       | 1 -
 c-user/configuring_a_system.rst                | 1 -
 c-user/constant_bandwidth_server.rst           | 1 -
 c-user/cpu_usage_statistics.rst                | 1 -
 c-user/directive_status_codes.rst              | 1 -
 c-user/dual_ports_memory_manager.rst           | 1 -
 c-user/event_manager.rst                       | 1 -
 c-user/example_application.rst                 | 1 -
 c-user/fatal_error.rst                         | 1 -
 c-user/initialization.rst                      | 1 -
 c-user/interrupt_manager.rst                   | 1 -
 c-user/io_manager.rst                          | 1 -
 c-user/key_concepts.rst                        | 1 -
 c-user/linker_sets.rst                         | 1 -
 c-user/message_manager.rst                     | 1 -
 c-user/multiprocessing.rst                     | 1 -
 c-user/object_services.rst                     | 1 -
 c-user/overview.rst                            | 1 -
 c-user/partition_manager.rst                   | 1 -
 c-user/pci_library.rst                         | 1 -
 c-user/preface.rst                             | 1 -
 c-user/rate_monotonic_manager.rst              | 1 -
 c-user/red_black_trees.rst                     | 1 -
 c-user/region_manager.rst                      | 1 -
 c-user/rtems_data_types.rst                    | 1 -
 c-user/scheduling_concepts.rst                 | 1 -
 c-user/self_contained_objects.rst              | 1 -
 c-user/semaphore_manager.rst                   | 1 -
 c-user/signal_manager.rst                      | 1 -
 c-user/stack_bounds_checker.rst                | 1 -
 c-user/symmetric_multiprocessing_services.rst  | 1 -
 c-user/task_manager.rst                        | 1 -
 c-user/timer_manager.rst                       | 1 -
 c-user/timespec_helpers.rst                    | 1 -
 c-user/user_extensions.rst                     | 1 -
 cpu-supplement/altera_nios_ii.rst              | 1 -
 cpu-supplement/arm.rst                         | 1 -
 cpu-supplement/atmel_avr.rst                   | 1 -
 cpu-supplement/ephiphany.rst                   | 1 -
 cpu-supplement/intel_amd_x86.rst               | 1 -
 cpu-supplement/lattice_micro32.rst             | 1 -
 cpu-supplement/m68xxx_and_coldfire.rst         | 1 -
 cpu-supplement/mips.rst                        | 1 -
 cpu-supplement/openrisc_1000.rst               | 1 -
 cpu-supplement/port.rst                        | 1 -
 cpu-supplement/powerpc.rst                     | 1 -
 cpu-supplement/preface.rst                     | 1 -
 cpu-supplement/renesas_m32c.rst                | 1 -
 cpu-supplement/riscv.rst                       | 1 -
 cpu-supplement/sparc.rst                       | 1 -
 cpu-supplement/sparc64.rst                     | 1 -
 cpu-supplement/superh.rst                      | 1 -
 cpu-supplement/xilinx_microblaze.rst           | 1 -
 develenv/directory.rst                         | 1 -
 develenv/introduction.rst                      | 1 -
 eclipse/index.rst                              | 1 -
 eclipse/overview.rst                           | 1 -
 eclipse/rtems.rst                              | 1 -
 filesystem/call_development.rst                | 1 -
 filesystem/fileystem_implmentation.rst         | 1 -
 filesystem/in-memory.rst                       | 1 -
 filesystem/minature_in-memory.rst              | 1 -
 filesystem/mounting_and_unmounting.rst         | 1 -
 filesystem/pathname_eval.rst                   | 1 -
 filesystem/preface.rst                         | 1 -
 filesystem/system_init.rst                     | 1 -
 networking/network_task_structure.rst          | 1 -
 networking/networking_driver.rst               | 1 -
 networking/preface.rst                         | 1 -
 networking/testing_the_driver.rst              | 1 -
 networking/using_networking_rtems_app.rst      | 1 -
 porting/code_tuning.rst                        | 1 -
 porting/cpu_init.rst                           | 1 -
 porting/cpu_model_variations.rst               | 1 -
 porting/development_tools.rst                  | 1 -
 porting/idle_thread.rst                        | 1 -
 porting/interrupts.rst                         | 1 -
 porting/preface.rst                            | 1 -
 porting/priority_bitmap.rst                    | 1 -
 porting/source_code_org.rst                    | 1 -
 porting/task_context.rst                       | 1 -
 posix-compliance/preface.rst                   | 1 -
 posix-users/condition_variable.rst             | 1 -
 posix-users/devctl.rst                         | 1 -
 posix-users/device_and_class_specific.rst      | 1 -
 posix-users/files_and_directory.rst            | 1 -
 posix-users/input_and_output.rst               | 1 -
 posix-users/key.rst                            | 1 -
 posix-users/language_specific_services.rst     | 1 -
 posix-users/memory_managment.rst               | 1 -
 posix-users/message_passing.rst                | 1 -
 posix-users/mutex.rst                          | 1 -
 posix-users/preface.rst                        | 1 -
 posix-users/process_creation_and_execution.rst | 1 -
 posix-users/process_environment.rst            | 1 -
 posix-users/scheduler.rst                      | 1 -
 posix-users/semaphore.rst                      | 1 -
 posix-users/services_provided_by_c.rst         | 1 -
 posix-users/services_provided_by_math.rst      | 1 -
 posix-users/signal.rst                         | 1 -
 posix-users/system_database.rst                | 1 -
 posix-users/thread.rst                         | 1 -
 posix-users/thread_cancellation.rst            | 1 -
 posix-users/timer.rst                          | 1 -
 shell/concept.rst                              | 1 -
 shell/configuration_and_init.rst               | 1 -
 shell/file_and_directory.rst                   | 1 -
 shell/function_and_variable.rst                | 1 -
 shell/general_commands.rst                     | 1 -
 shell/index.rst                                | 1 -
 shell/memory_commands.rst                      | 1 -
 shell/network_commands.rst                     | 1 -
 shell/preface.rst                              | 1 -
 shell/rtems_specific_commands.rst              | 1 -
 user/apps/index.rst                            | 1 -
 user/bsps/index.rst                            | 1 -
 user/ecosys/index.rst                          | 1 -
 user/exe/debugging.rst                         | 1 -
 user/exe/executables.rst                       | 1 -
 user/exe/execution.rst                         | 1 -
 user/exe/index.rst                             | 1 -
 user/exe/initialization.rst                    | 1 -
 user/hardware/architectures.rst                | 1 -
 user/hardware/bsps.rst                         | 1 -
 user/hardware/index.rst                        | 1 -
 user/hardware/targets.rst                      | 1 -
 user/hardware/tiers.rst                        | 1 -
 user/hosts/index.rst                           | 1 -
 user/hosts/macos.rst                           | 1 -
 user/hosts/os.rst                              | 1 -
 user/hosts/posix.rst                           | 1 -
 user/hosts/windows.rst                         | 1 -
 user/installation/developer.rst                | 1 -
 user/installation/index.rst                    | 1 -
 user/installation/kernel.rst                   | 1 -
 user/installation/prefixes-sandboxing.rst      | 1 -
 user/installation/releases.rst                 | 1 -
 user/start/index.rst                           | 1 -
 user/testing/configuration.rst                 | 1 -
 user/testing/consoles.rst                      | 1 -
 user/testing/gdb-jtag.rst                      | 1 -
 user/testing/index.rst                         | 1 -
 user/testing/simulation.rst                    | 1 -
 user/testing/tests.rst                         | 1 -
 user/testing/tftp.rst                          | 1 -
 user/tools/bsp-builder.rst                     | 1 -
 user/tools/exeinfo.rst                         | 1 -
 user/tools/index.rst                           | 1 -
 user/tools/linker.rst                          | 1 -
 user/tools/symbols.rst                         | 1 -
 user/tools/tester.rst                          | 1 -
 user/tracing/captureengine.rst                 | 1 -
 user/tracing/examples.rst                      | 1 -
 user/tracing/index.rst                         | 1 -
 user/tracing/introduction.rst                  | 1 -
 user/tracing/tracelinker.rst                   | 1 -
 178 files changed, 178 deletions(-)
diff --git a/bsp-howto/ada95_interrupt.rst b/bsp-howto/ada95_interrupt.rst
index 748ee74..8723183 100644
--- a/bsp-howto/ada95_interrupt.rst
+++ b/bsp-howto/ada95_interrupt.rst
@@ -1,7 +1,6 @@
 .. comment SPDX-License-Identifier: CC-BY-SA-4.0
 .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
-.. COMMENT: All rights reserved.
 Ada95 Interrupt Support
diff --git a/bsp-howto/ata.rst b/bsp-howto/ata.rst
index a1b9700..5130148 100644
--- a/bsp-howto/ata.rst
+++ b/bsp-howto/ata.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 1988, 2002 On-Line Applications Research Corporation (OAR)
 ATA Driver
diff --git a/bsp-howto/clock.rst b/bsp-howto/clock.rst
index 26ce1d6..e39a649 100644
--- a/bsp-howto/clock.rst
+++ b/bsp-howto/clock.rst
@@ -1,7 +1,6 @@
 Clock Driver
diff --git a/bsp-howto/console.rst b/bsp-howto/console.rst
index 2ae9b53..7d72f2c 100644
--- a/bsp-howto/console.rst
+++ b/bsp-howto/console.rst
@@ -1,7 +1,6 @@
 Console Driver
diff --git a/bsp-howto/frame_buffer.rst b/bsp-howto/frame_buffer.rst
index 4cd253e..7042c93 100644
--- a/bsp-howto/frame_buffer.rst
+++ b/bsp-howto/frame_buffer.rst
@@ -1,7 +1,6 @@
 Frame Buffer Driver
diff --git a/bsp-howto/getentropy.rst b/bsp-howto/getentropy.rst
index c7c6a62..ade273f 100644
--- a/bsp-howto/getentropy.rst
+++ b/bsp-howto/getentropy.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 2017 embedded brains GmbH <rtems at embedded-brains.de>
 Entropy Source
diff --git a/bsp-howto/i2c.rst b/bsp-howto/i2c.rst
index e254ab0..deb31fe 100644
--- a/bsp-howto/i2c.rst
+++ b/bsp-howto/i2c.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 2016 embedded brains GmbH <rtems at embedded-brains.de>
 I2C Driver
diff --git a/bsp-howto/ide_controller.rst b/bsp-howto/ide_controller.rst
index 04f518a..0e67d7d 100644
--- a/bsp-howto/ide_controller.rst
+++ b/bsp-howto/ide_controller.rst
@@ -1,7 +1,6 @@
 IDE Controller Driver
diff --git a/bsp-howto/initilization_code.rst b/bsp-howto/initilization_code.rst
index 2304d43..3338e8b 100644
--- a/bsp-howto/initilization_code.rst
+++ b/bsp-howto/initilization_code.rst
@@ -1,7 +1,6 @@
 Initialization Code
diff --git a/bsp-howto/linker_script.rst b/bsp-howto/linker_script.rst
index 43c2c60..c5fccc5 100644
--- a/bsp-howto/linker_script.rst
+++ b/bsp-howto/linker_script.rst
@@ -2,7 +2,6 @@
 .. Copyright (C) 1988, 2011 On-Line Applications Research Corporation (OAR)
 Linker Script
diff --git a/bsp-howto/miscellanous_support.rst b/bsp-howto/miscellanous_support.rst
index 2dba828..1362fa3 100644
--- a/bsp-howto/miscellanous_support.rst
+++ b/bsp-howto/miscellanous_support.rst
@@ -2,7 +2,6 @@
 Miscellaneous Support Files
diff --git a/bsp-howto/networking.rst b/bsp-howto/networking.rst
index 2d5b6de..fbf88ae 100644
--- a/bsp-howto/networking.rst
+++ b/bsp-howto/networking.rst
@@ -1,7 +1,6 @@
 Networking Driver
diff --git a/bsp-howto/preface.rst b/bsp-howto/preface.rst
index 9cb5507..4881dc9 100644
--- a/bsp-howto/preface.rst
+++ b/bsp-howto/preface.rst
@@ -1,7 +1,6 @@
 Introduction
diff --git a/bsp-howto/real_time_clock.rst b/bsp-howto/real_time_clock.rst
index bc90bfa..010997a 100644
--- a/bsp-howto/real_time_clock.rst
+++ b/bsp-howto/real_time_clock.rst
@@ -1,7 +1,6 @@
 Real-Time Clock Driver
diff --git a/bsp-howto/shared_memory_support.rst b/bsp-howto/shared_memory_support.rst
index 8d572ca..65d159a 100644
--- a/bsp-howto/shared_memory_support.rst
+++ b/bsp-howto/shared_memory_support.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 1988, 2009 On-Line Applications Research Corporation (OAR)
 Shared Memory Support Driver
diff --git a/bsp-howto/spi.rst b/bsp-howto/spi.rst
index 9a19803..c183450 100644
--- a/bsp-howto/spi.rst
+++ b/bsp-howto/spi.rst
@@ -1,7 +1,6 @@
 SPI Driver
diff --git a/bsp-howto/target_dependant_files.rst b/bsp-howto/target_dependant_files.rst
index 4b1b439..8572d4b 100644
--- a/bsp-howto/target_dependant_files.rst
+++ b/bsp-howto/target_dependant_files.rst
@@ -1,7 +1,6 @@
 Target Dependent Files
diff --git a/bsp-howto/timer.rst b/bsp-howto/timer.rst
index c1b86b8..62633b8 100644
--- a/bsp-howto/timer.rst
+++ b/bsp-howto/timer.rst
@@ -1,7 +1,6 @@
 Timer Driver
diff --git a/c-user/ada_support.rst b/c-user/ada_support.rst
index 11e6129..8dbad24 100644
--- a/c-user/ada_support.rst
+++ b/c-user/ada_support.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 1989, 2017 On-Line Applications Research Corporation (OAR)
 .. index:: Ada
 .. _ada_support:
diff --git a/c-user/barrier_manager.rst b/c-user/barrier_manager.rst
index 5124998..75fbf60 100644
--- a/c-user/barrier_manager.rst
+++ b/c-user/barrier_manager.rst
@@ -2,7 +2,6 @@
 .. Copyright (C) 1988, 2008, 2018.
 .. COMMENT: On-Line Applications Research Corporation (OAR).
 .. index:: barrier
diff --git a/c-user/board_support_packages.rst b/c-user/board_support_packages.rst
index 2a19eef..fadbb6d 100644
--- a/c-user/board_support_packages.rst
+++ b/c-user/board_support_packages.rst
@@ -1,7 +1,6 @@
 .. index:: Board Support Packages
 .. index:: BSPs
diff --git a/c-user/chains.rst b/c-user/chains.rst
index defc400..e081fc3 100644
--- a/c-user/chains.rst
+++ b/c-user/chains.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 2014 Gedare Bloom
 .. index:: chains
diff --git a/c-user/clock_manager.rst b/c-user/clock_manager.rst
index 4e329e2..fd307f9 100644
--- a/c-user/clock_manager.rst
+++ b/c-user/clock_manager.rst
@@ -1,7 +1,6 @@
 .. index:: clock
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index b15519e..024f433 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -1,7 +1,6 @@
 .. index:: configuring a system
 .. _Configuring a System:
diff --git a/c-user/constant_bandwidth_server.rst b/c-user/constant_bandwidth_server.rst
index 615ce62..8a578cf 100644
--- a/c-user/constant_bandwidth_server.rst
+++ b/c-user/constant_bandwidth_server.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 1989, 2011 On-Line Applications Research Corporation (OAR)
 .. index:: cbs
diff --git a/c-user/cpu_usage_statistics.rst b/c-user/cpu_usage_statistics.rst
index 58f5cdb..0908a59 100644
--- a/c-user/cpu_usage_statistics.rst
+++ b/c-user/cpu_usage_statistics.rst
@@ -1,7 +1,6 @@
 .. index:: CPU Usage
diff --git a/c-user/directive_status_codes.rst b/c-user/directive_status_codes.rst
index 9d41f94..6c11ebb 100644
--- a/c-user/directive_status_codes.rst
+++ b/c-user/directive_status_codes.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 2015 embedded brains GmbH
 .. index:: Status Codes
diff --git a/c-user/dual_ports_memory_manager.rst b/c-user/dual_ports_memory_manager.rst
index 8e72648..33e8ea5 100644
--- a/c-user/dual_ports_memory_manager.rst
+++ b/c-user/dual_ports_memory_manager.rst
@@ -1,7 +1,6 @@
 .. index:: ports
 .. index:: dual ported memory
diff --git a/c-user/event_manager.rst b/c-user/event_manager.rst
index 38129a7..20c2328 100644
--- a/c-user/event_manager.rst
+++ b/c-user/event_manager.rst
@@ -1,7 +1,6 @@
 .. index:: events
diff --git a/c-user/example_application.rst b/c-user/example_application.rst
index d661f67..60f9969 100644
--- a/c-user/example_application.rst
+++ b/c-user/example_application.rst
@@ -1,7 +1,6 @@
 Example Application
diff --git a/c-user/fatal_error.rst b/c-user/fatal_error.rst
index cd8c8f8..5c211f5 100644
--- a/c-user/fatal_error.rst
+++ b/c-user/fatal_error.rst
@@ -1,7 +1,6 @@
 .. index:: fatal errors
diff --git a/c-user/initialization.rst b/c-user/initialization.rst
index 1088e16..7756657 100644
--- a/c-user/initialization.rst
+++ b/c-user/initialization.rst
@@ -1,7 +1,6 @@
 Initialization Manager
diff --git a/c-user/interrupt_manager.rst b/c-user/interrupt_manager.rst
index 30799c3..b9441a9 100644
--- a/c-user/interrupt_manager.rst
+++ b/c-user/interrupt_manager.rst
@@ -1,7 +1,6 @@
 .. index:: interrupts
diff --git a/c-user/io_manager.rst b/c-user/io_manager.rst
index cfa77ba..fb6dc1b 100644
--- a/c-user/io_manager.rst
+++ b/c-user/io_manager.rst
@@ -1,7 +1,6 @@
 .. index:: device drivers
 .. index:: IO Manager
diff --git a/c-user/key_concepts.rst b/c-user/key_concepts.rst
index b0c070c..98a8990 100644
--- a/c-user/key_concepts.rst
+++ b/c-user/key_concepts.rst
@@ -1,7 +1,6 @@
 Key Concepts
diff --git a/c-user/linker_sets.rst b/c-user/linker_sets.rst
index 87d5c9a..f6cd614 100644
--- a/c-user/linker_sets.rst
+++ b/c-user/linker_sets.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 1989, 2014 On-Line Applications Research Corporation (OAR)
 .. index:: linkersets
diff --git a/c-user/message_manager.rst b/c-user/message_manager.rst
index 2704a85..209070d 100644
--- a/c-user/message_manager.rst
+++ b/c-user/message_manager.rst
@@ -1,7 +1,6 @@
 .. index:: messages
 .. index:: message queues
diff --git a/c-user/multiprocessing.rst b/c-user/multiprocessing.rst
index 4d3a9c8..1f52da0 100644
--- a/c-user/multiprocessing.rst
+++ b/c-user/multiprocessing.rst
@@ -1,7 +1,6 @@
 .. index:: multiprocessing
diff --git a/c-user/object_services.rst b/c-user/object_services.rst
index 78e203d..f43d935 100644
--- a/c-user/object_services.rst
+++ b/c-user/object_services.rst
@@ -1,7 +1,6 @@
 .. index:: object manipulation
diff --git a/c-user/overview.rst b/c-user/overview.rst
index 2c804a3..69e4ac5 100644
--- a/c-user/overview.rst
+++ b/c-user/overview.rst
@@ -1,7 +1,6 @@
 Overview
diff --git a/c-user/partition_manager.rst b/c-user/partition_manager.rst
index 9b0ba11..d8aa28c 100644
--- a/c-user/partition_manager.rst
+++ b/c-user/partition_manager.rst
@@ -1,7 +1,6 @@
 .. index:: partitions
diff --git a/c-user/pci_library.rst b/c-user/pci_library.rst
index 7b8ae13..400b30e 100644
--- a/c-user/pci_library.rst
+++ b/c-user/pci_library.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 2011,2015 Aeroflex Gaisler AB
 .. index:: PCI
 .. index:: libpci
diff --git a/c-user/preface.rst b/c-user/preface.rst
index 0305abe..d158ba1 100644
--- a/c-user/preface.rst
+++ b/c-user/preface.rst
@@ -1,7 +1,6 @@
 Preface
diff --git a/c-user/rate_monotonic_manager.rst b/c-user/rate_monotonic_manager.rst
index 4899404..6298254 100644
--- a/c-user/rate_monotonic_manager.rst
+++ b/c-user/rate_monotonic_manager.rst
@@ -2,7 +2,6 @@
 .. Copyright (C) 2017 Kuan-Hsun Chen.
 .. index:: rate mononitonic tasks
 .. index:: periodic tasks
diff --git a/c-user/red_black_trees.rst b/c-user/red_black_trees.rst
index eb7544d..c7702eb 100644
--- a/c-user/red_black_trees.rst
+++ b/c-user/red_black_trees.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 1988, 2012 On-Line Applications Research Corporation (OAR)
 .. index:: Red-Black Trees
 .. index:: rbtrees
diff --git a/c-user/region_manager.rst b/c-user/region_manager.rst
index cdf23c2..07292d9 100644
--- a/c-user/region_manager.rst
+++ b/c-user/region_manager.rst
@@ -1,7 +1,6 @@
 .. index:: regions
diff --git a/c-user/rtems_data_types.rst b/c-user/rtems_data_types.rst
index 94567e9..de07131 100644
--- a/c-user/rtems_data_types.rst
+++ b/c-user/rtems_data_types.rst
@@ -1,7 +1,6 @@
 .. index:: RTEMS Data Types
 .. index:: data types
diff --git a/c-user/scheduling_concepts.rst b/c-user/scheduling_concepts.rst
index bd97006..18c6498 100644
--- a/c-user/scheduling_concepts.rst
+++ b/c-user/scheduling_concepts.rst
@@ -1,7 +1,6 @@
 .. index:: scheduling
 .. index:: task scheduling
diff --git a/c-user/self_contained_objects.rst b/c-user/self_contained_objects.rst
index 53e53ae..5a1287b 100644
--- a/c-user/self_contained_objects.rst
+++ b/c-user/self_contained_objects.rst
@@ -2,7 +2,6 @@
 .. Copyright (C) 2014, 2017.
 .. COMMENT: embedded brains GmbH.
 Self-Contained Objects
diff --git a/c-user/semaphore_manager.rst b/c-user/semaphore_manager.rst
index 6b1a08e..570cb7c 100644
--- a/c-user/semaphore_manager.rst
+++ b/c-user/semaphore_manager.rst
@@ -1,7 +1,6 @@
 .. index:: semaphores
 .. index:: binary semaphores
diff --git a/c-user/signal_manager.rst b/c-user/signal_manager.rst
index baa1357..deb85e8 100644
--- a/c-user/signal_manager.rst
+++ b/c-user/signal_manager.rst
@@ -1,7 +1,6 @@
 .. index:: signals
diff --git a/c-user/stack_bounds_checker.rst b/c-user/stack_bounds_checker.rst
index bfcda2b..2ec6b75 100644
--- a/c-user/stack_bounds_checker.rst
+++ b/c-user/stack_bounds_checker.rst
@@ -1,7 +1,6 @@
 .. index:: Stack Bounds Checker
 .. index:: stack
diff --git a/c-user/symmetric_multiprocessing_services.rst b/c-user/symmetric_multiprocessing_services.rst
index 2051577..042be81 100644
--- a/c-user/symmetric_multiprocessing_services.rst
+++ b/c-user/symmetric_multiprocessing_services.rst
@@ -3,7 +3,6 @@
 .. Copyright (C) 2014.
 .. Copyright (C) 2017 embedded brains GmbH.
 .. index:: Symmetric Multiprocessing
 .. index:: SMP
diff --git a/c-user/task_manager.rst b/c-user/task_manager.rst
index c0a5544..8008af7 100644
--- a/c-user/task_manager.rst
+++ b/c-user/task_manager.rst
@@ -1,7 +1,6 @@
 .. index:: tasks
diff --git a/c-user/timer_manager.rst b/c-user/timer_manager.rst
index 1f01726..b4e0035 100644
--- a/c-user/timer_manager.rst
+++ b/c-user/timer_manager.rst
@@ -1,7 +1,6 @@
 .. index:: timers
diff --git a/c-user/timespec_helpers.rst b/c-user/timespec_helpers.rst
index b596664..a5148b4 100644
--- a/c-user/timespec_helpers.rst
+++ b/c-user/timespec_helpers.rst
@@ -2,7 +2,6 @@
 .. Copyright (C) 2011.
 .. index:: TImespec Helpers
diff --git a/c-user/user_extensions.rst b/c-user/user_extensions.rst
index b6896f6..5425ac4 100644
--- a/c-user/user_extensions.rst
+++ b/c-user/user_extensions.rst
@@ -1,7 +1,6 @@
 .. index:: user extensions
diff --git a/cpu-supplement/altera_nios_ii.rst b/cpu-supplement/altera_nios_ii.rst
index da37de2..b2a624e 100644
--- a/cpu-supplement/altera_nios_ii.rst
+++ b/cpu-supplement/altera_nios_ii.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
 Altera Nios II Specific Information
diff --git a/cpu-supplement/arm.rst b/cpu-supplement/arm.rst
index fc80538..4898657 100644
--- a/cpu-supplement/arm.rst
+++ b/cpu-supplement/arm.rst
@@ -1,7 +1,6 @@
 ARM Specific Information
diff --git a/cpu-supplement/atmel_avr.rst b/cpu-supplement/atmel_avr.rst
index 958adbf..692ea97 100644
--- a/cpu-supplement/atmel_avr.rst
+++ b/cpu-supplement/atmel_avr.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 1988, 2006 On-Line Applications Research Corporation (OAR)
 Atmel AVR Specific Information
diff --git a/cpu-supplement/ephiphany.rst b/cpu-supplement/ephiphany.rst
index bbcd939..9812d5c 100644
--- a/cpu-supplement/ephiphany.rst
+++ b/cpu-supplement/ephiphany.rst
@@ -1,7 +1,6 @@
 Epiphany Specific Information
diff --git a/cpu-supplement/intel_amd_x86.rst b/cpu-supplement/intel_amd_x86.rst
index 774ff0e..af47dc5 100644
--- a/cpu-supplement/intel_amd_x86.rst
+++ b/cpu-supplement/intel_amd_x86.rst
@@ -1,7 +1,6 @@
 .. COMMENT: Jukka Pietarinen <jukka.pietarinen at mrf.fi>, 2008,
 .. COMMENT: Micro-Research Finland Oy
diff --git a/cpu-supplement/lattice_micro32.rst b/cpu-supplement/lattice_micro32.rst
index 2fbeb1d..68ee85e 100644
--- a/cpu-supplement/lattice_micro32.rst
+++ b/cpu-supplement/lattice_micro32.rst
@@ -1,6 +1,5 @@
-.. Copyright (C) 2014 embedded brains GmbH.  All rights reserved.
 Lattice Mico32 Specific Information
diff --git a/cpu-supplement/m68xxx_and_coldfire.rst b/cpu-supplement/m68xxx_and_coldfire.rst
index 080e084..e04153f 100644
--- a/cpu-supplement/m68xxx_and_coldfire.rst
+++ b/cpu-supplement/m68xxx_and_coldfire.rst
@@ -1,6 +1,5 @@
 M68xxx and Coldfire Specific Information
diff --git a/cpu-supplement/mips.rst b/cpu-supplement/mips.rst
index 421b2cb..c59a064 100644
--- a/cpu-supplement/mips.rst
+++ b/cpu-supplement/mips.rst
@@ -1,6 +1,5 @@
 MIPS Specific Information
diff --git a/cpu-supplement/openrisc_1000.rst b/cpu-supplement/openrisc_1000.rst
index ac3e30c..ad15f8d 100644
--- a/cpu-supplement/openrisc_1000.rst
+++ b/cpu-supplement/openrisc_1000.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 1989, 2007 On-Line Applications Research Corporation (OAR)
 OpenRISC 1000 Specific Information
diff --git a/cpu-supplement/port.rst b/cpu-supplement/port.rst
index f61e328..7cbeaa9 100644
--- a/cpu-supplement/port.rst
+++ b/cpu-supplement/port.rst
@@ -1,7 +1,6 @@
 Port Specific Information
diff --git a/cpu-supplement/powerpc.rst b/cpu-supplement/powerpc.rst
index 2c630f2..95934d3 100644
--- a/cpu-supplement/powerpc.rst
+++ b/cpu-supplement/powerpc.rst
@@ -1,7 +1,6 @@
 PowerPC Specific Information
diff --git a/cpu-supplement/preface.rst b/cpu-supplement/preface.rst
index a363e1a..76eb1b9 100644
--- a/cpu-supplement/preface.rst
+++ b/cpu-supplement/preface.rst
@@ -1,7 +1,6 @@
 Preface
diff --git a/cpu-supplement/renesas_m32c.rst b/cpu-supplement/renesas_m32c.rst
index f07042f..55ed861 100644
--- a/cpu-supplement/renesas_m32c.rst
+++ b/cpu-supplement/renesas_m32c.rst
@@ -1,7 +1,6 @@
 Renesas M32C Specific Information
diff --git a/cpu-supplement/riscv.rst b/cpu-supplement/riscv.rst
index a19723d..e761761 100644
--- a/cpu-supplement/riscv.rst
+++ b/cpu-supplement/riscv.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 2018 embedded brains GmbH
 RISC-V Specific Information
diff --git a/cpu-supplement/sparc.rst b/cpu-supplement/sparc.rst
index 3e8cfd8..faea55e 100644
--- a/cpu-supplement/sparc.rst
+++ b/cpu-supplement/sparc.rst
@@ -1,7 +1,6 @@
 SPARC Specific Information
diff --git a/cpu-supplement/sparc64.rst b/cpu-supplement/sparc64.rst
index 2e326b8..bfd4323 100644
--- a/cpu-supplement/sparc64.rst
+++ b/cpu-supplement/sparc64.rst
@@ -1,7 +1,6 @@
 SPARC-64 Specific Information
diff --git a/cpu-supplement/superh.rst b/cpu-supplement/superh.rst
index 2c1c2f4..e199d4e 100644
--- a/cpu-supplement/superh.rst
+++ b/cpu-supplement/superh.rst
@@ -1,7 +1,6 @@
 SuperH Specific Information
diff --git a/cpu-supplement/xilinx_microblaze.rst b/cpu-supplement/xilinx_microblaze.rst
index f71955f..3eca1fa 100644
--- a/cpu-supplement/xilinx_microblaze.rst
+++ b/cpu-supplement/xilinx_microblaze.rst
@@ -1,7 +1,6 @@
 Xilinx MicroBlaze Specific Information
diff --git a/develenv/directory.rst b/develenv/directory.rst
index 8f9cf59..0e9c285 100644
--- a/develenv/directory.rst
+++ b/develenv/directory.rst
@@ -1,7 +1,6 @@
 Directory Structure
diff --git a/develenv/introduction.rst b/develenv/introduction.rst
index 3707308..1c94dca 100644
--- a/develenv/introduction.rst
+++ b/develenv/introduction.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 1989, 2010 On-Line Applications Research Corporation (OAR)
 Introduction
diff --git a/eclipse/index.rst b/eclipse/index.rst
index 82f6ac1..96f3066 100644
--- a/eclipse/index.rst
+++ b/eclipse/index.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 2016 Chris Johns <chrisj at rtems.org>
-.. comment: All rights reserved.
 .. highlight:: c
diff --git a/eclipse/overview.rst b/eclipse/overview.rst
index 327a495..d5bab8c 100644
--- a/eclipse/overview.rst
+++ b/eclipse/overview.rst
@@ -1,7 +1,6 @@
 .. _overview:
diff --git a/eclipse/rtems.rst b/eclipse/rtems.rst
index fc3c03a..8cd3716 100644
--- a/eclipse/rtems.rst
+++ b/eclipse/rtems.rst
@@ -1,7 +1,6 @@
 .. _rtems-development:
diff --git a/filesystem/call_development.rst b/filesystem/call_development.rst
index 51134b1..0f9fe4f 100644
--- a/filesystem/call_development.rst
+++ b/filesystem/call_development.rst
@@ -1,7 +1,6 @@
 System Call Development Notes
diff --git a/filesystem/fileystem_implmentation.rst b/filesystem/fileystem_implmentation.rst
index c4378fa..c13f39c 100644
--- a/filesystem/fileystem_implmentation.rst
+++ b/filesystem/fileystem_implmentation.rst
@@ -1,7 +1,6 @@
 Filesystem Implementation Requirements
diff --git a/filesystem/in-memory.rst b/filesystem/in-memory.rst
index 60154c8..87eb97d 100644
--- a/filesystem/in-memory.rst
+++ b/filesystem/in-memory.rst
@@ -1,7 +1,6 @@
 In-Memory Filesystem
diff --git a/filesystem/minature_in-memory.rst b/filesystem/minature_in-memory.rst
index 9386ccf..1161ca4 100644
--- a/filesystem/minature_in-memory.rst
+++ b/filesystem/minature_in-memory.rst
@@ -1,7 +1,6 @@
 Miniature In-Memory Filesystem
diff --git a/filesystem/mounting_and_unmounting.rst b/filesystem/mounting_and_unmounting.rst
index 387e038..09fdea8 100644
--- a/filesystem/mounting_and_unmounting.rst
+++ b/filesystem/mounting_and_unmounting.rst
@@ -1,7 +1,6 @@
 Mounting and Unmounting Filesystems
diff --git a/filesystem/pathname_eval.rst b/filesystem/pathname_eval.rst
index 0e03c9d..1120020 100644
--- a/filesystem/pathname_eval.rst
+++ b/filesystem/pathname_eval.rst
@@ -1,7 +1,6 @@
 Pathname Evaluation
diff --git a/filesystem/preface.rst b/filesystem/preface.rst
index 42d53cf..bf44925 100644
--- a/filesystem/preface.rst
+++ b/filesystem/preface.rst
@@ -1,7 +1,6 @@
 Preface
diff --git a/filesystem/system_init.rst b/filesystem/system_init.rst
index 4ca60df..ed47b86 100644
--- a/filesystem/system_init.rst
+++ b/filesystem/system_init.rst
@@ -1,7 +1,6 @@
 System Initialization
diff --git a/networking/network_task_structure.rst b/networking/network_task_structure.rst
index bf93670..5e27cbf 100644
--- a/networking/network_task_structure.rst
+++ b/networking/network_task_structure.rst
@@ -2,7 +2,6 @@
 .. COMMENT: Written by Eric Norum
 Network Task Structure and Data Flow
diff --git a/networking/networking_driver.rst b/networking/networking_driver.rst
index eaf70f9..ae362e0 100644
--- a/networking/networking_driver.rst
+++ b/networking/networking_driver.rst
@@ -2,7 +2,6 @@
 Networking Driver
diff --git a/networking/preface.rst b/networking/preface.rst
index 9482179..3c632ed 100644
--- a/networking/preface.rst
+++ b/networking/preface.rst
@@ -2,7 +2,6 @@
 Preface
diff --git a/networking/testing_the_driver.rst b/networking/testing_the_driver.rst
index 05c20eb..1c39a1f 100644
--- a/networking/testing_the_driver.rst
+++ b/networking/testing_the_driver.rst
@@ -2,7 +2,6 @@
 .. COMMENT: Text Written by Jake Janovetz
 Testing the Driver
diff --git a/networking/using_networking_rtems_app.rst b/networking/using_networking_rtems_app.rst
index 369d904..efca48e 100644
--- a/networking/using_networking_rtems_app.rst
+++ b/networking/using_networking_rtems_app.rst
@@ -2,7 +2,6 @@
 Using Networking in an RTEMS Application
diff --git a/porting/code_tuning.rst b/porting/code_tuning.rst
index 7a0040f..26b848f 100644
--- a/porting/code_tuning.rst
+++ b/porting/code_tuning.rst
@@ -1,7 +1,6 @@
 Code Tuning Parameters
diff --git a/porting/cpu_init.rst b/porting/cpu_init.rst
index 00a1a66..7bcfa69 100644
--- a/porting/cpu_init.rst
+++ b/porting/cpu_init.rst
@@ -1,7 +1,6 @@
 CPU Initialization
diff --git a/porting/cpu_model_variations.rst b/porting/cpu_model_variations.rst
index bd7f20c..e242460 100644
--- a/porting/cpu_model_variations.rst
+++ b/porting/cpu_model_variations.rst
@@ -1,7 +1,6 @@
 CPU Model Variations
diff --git a/porting/development_tools.rst b/porting/development_tools.rst
index facb303..e2751bd 100644
--- a/porting/development_tools.rst
+++ b/porting/development_tools.rst
@@ -1,7 +1,6 @@
 Development Tools
diff --git a/porting/idle_thread.rst b/porting/idle_thread.rst
index e056f23..12b93f6 100644
--- a/porting/idle_thread.rst
+++ b/porting/idle_thread.rst
@@ -1,7 +1,6 @@
 IDLE Thread
diff --git a/porting/interrupts.rst b/porting/interrupts.rst
index 02c6d12..1fd4107 100644
--- a/porting/interrupts.rst
+++ b/porting/interrupts.rst
@@ -1,7 +1,6 @@
 Interrupts
diff --git a/porting/preface.rst b/porting/preface.rst
index 6fba312..df9c23f 100644
--- a/porting/preface.rst
+++ b/porting/preface.rst
@@ -1,7 +1,6 @@
 Preface
diff --git a/porting/priority_bitmap.rst b/porting/priority_bitmap.rst
index ac9158b..6d792a5 100644
--- a/porting/priority_bitmap.rst
+++ b/porting/priority_bitmap.rst
@@ -1,7 +1,6 @@
 Priority Bitmap Manipulation
diff --git a/porting/source_code_org.rst b/porting/source_code_org.rst
index d4c1af7..dd1a937 100644
--- a/porting/source_code_org.rst
+++ b/porting/source_code_org.rst
@@ -1,7 +1,6 @@
 Source Code Organization
diff --git a/porting/task_context.rst b/porting/task_context.rst
index 97122a4..6272a7c 100644
--- a/porting/task_context.rst
+++ b/porting/task_context.rst
@@ -1,7 +1,6 @@
 Task Context Management
diff --git a/posix-compliance/preface.rst b/posix-compliance/preface.rst
index b66ebef..37fe974 100644
--- a/posix-compliance/preface.rst
+++ b/posix-compliance/preface.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 1988, 2017 On-Line Applications Research Corporation (OAR)
 Preface
diff --git a/posix-users/condition_variable.rst b/posix-users/condition_variable.rst
index 4310bf6..2e3c346 100644
--- a/posix-users/condition_variable.rst
+++ b/posix-users/condition_variable.rst
@@ -1,7 +1,6 @@
 Condition Variable Manager
diff --git a/posix-users/devctl.rst b/posix-users/devctl.rst
index 7fd4973..7bbad48 100644
--- a/posix-users/devctl.rst
+++ b/posix-users/devctl.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 2017 On-Line Applications Research Corporation (OAR)
 Device Control
diff --git a/posix-users/device_and_class_specific.rst b/posix-users/device_and_class_specific.rst
index d04f7b6..82b4227 100644
--- a/posix-users/device_and_class_specific.rst
+++ b/posix-users/device_and_class_specific.rst
@@ -1,7 +1,6 @@
 Device- and Class- Specific Functions Manager
diff --git a/posix-users/files_and_directory.rst b/posix-users/files_and_directory.rst
index 61eb0ff..5b5f4eb 100644
--- a/posix-users/files_and_directory.rst
+++ b/posix-users/files_and_directory.rst
@@ -1,7 +1,6 @@
 Files and Directories Manager
diff --git a/posix-users/input_and_output.rst b/posix-users/input_and_output.rst
index f1799b8..769f30c 100644
--- a/posix-users/input_and_output.rst
+++ b/posix-users/input_and_output.rst
@@ -1,7 +1,6 @@
 Input and Output Primitives Manager
diff --git a/posix-users/key.rst b/posix-users/key.rst
index eaf49d6..5ee4ba4 100644
--- a/posix-users/key.rst
+++ b/posix-users/key.rst
@@ -1,7 +1,6 @@
 Key Manager
diff --git a/posix-users/language_specific_services.rst b/posix-users/language_specific_services.rst
index 2580f82..89ffcb2 100644
--- a/posix-users/language_specific_services.rst
+++ b/posix-users/language_specific_services.rst
@@ -1,7 +1,6 @@
 Language-Specific Services for the C Programming Language Manager
diff --git a/posix-users/memory_managment.rst b/posix-users/memory_managment.rst
index c88dea1..3023684 100644
--- a/posix-users/memory_managment.rst
+++ b/posix-users/memory_managment.rst
@@ -1,7 +1,6 @@
 Memory Management Manager
diff --git a/posix-users/message_passing.rst b/posix-users/message_passing.rst
index 139ad8f..280a91c 100644
--- a/posix-users/message_passing.rst
+++ b/posix-users/message_passing.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 1988, 2014 On-Line Applications Research Corporation (OAR)
 Message Passing Manager
diff --git a/posix-users/mutex.rst b/posix-users/mutex.rst
index c0de42a..bafae9d 100644
--- a/posix-users/mutex.rst
+++ b/posix-users/mutex.rst
@@ -1,7 +1,6 @@
 Mutex Manager
diff --git a/posix-users/preface.rst b/posix-users/preface.rst
index ef67748..be3b5bd 100644
--- a/posix-users/preface.rst
+++ b/posix-users/preface.rst
@@ -1,7 +1,6 @@
 Preface
diff --git a/posix-users/process_creation_and_execution.rst b/posix-users/process_creation_and_execution.rst
index b9ff6e8..b0af3ff 100644
--- a/posix-users/process_creation_and_execution.rst
+++ b/posix-users/process_creation_and_execution.rst
@@ -1,7 +1,6 @@
 Process Creation and Execution Manager
diff --git a/posix-users/process_environment.rst b/posix-users/process_environment.rst
index e251db3..f17c2bc 100644
--- a/posix-users/process_environment.rst
+++ b/posix-users/process_environment.rst
@@ -1,7 +1,6 @@
 Process Environment Manager
diff --git a/posix-users/scheduler.rst b/posix-users/scheduler.rst
index eed003a..493a6ff 100644
--- a/posix-users/scheduler.rst
+++ b/posix-users/scheduler.rst
@@ -1,7 +1,6 @@
 Scheduler Manager
diff --git a/posix-users/semaphore.rst b/posix-users/semaphore.rst
index 1b9ea18..db2b36c 100644
--- a/posix-users/semaphore.rst
+++ b/posix-users/semaphore.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 1989, 2008 On-Line Applications Research Corporation (OAR)
 Semaphore Manager
diff --git a/posix-users/services_provided_by_c.rst b/posix-users/services_provided_by_c.rst
index d0c8540..7501b6c 100644
--- a/posix-users/services_provided_by_c.rst
+++ b/posix-users/services_provided_by_c.rst
@@ -1,7 +1,6 @@
 Services Provided by C Library (libc)
diff --git a/posix-users/services_provided_by_math.rst b/posix-users/services_provided_by_math.rst
index fb189ed..3d7b116 100644
--- a/posix-users/services_provided_by_math.rst
+++ b/posix-users/services_provided_by_math.rst
@@ -1,7 +1,6 @@
 Services Provided by the Math Library (libm)
diff --git a/posix-users/signal.rst b/posix-users/signal.rst
index 02f6964..cc9d41c 100644
--- a/posix-users/signal.rst
+++ b/posix-users/signal.rst
@@ -1,7 +1,6 @@
 Signal Manager
diff --git a/posix-users/system_database.rst b/posix-users/system_database.rst
index d004172..45a7bb3 100644
--- a/posix-users/system_database.rst
+++ b/posix-users/system_database.rst
@@ -1,7 +1,6 @@
 System Databases Manager
diff --git a/posix-users/thread.rst b/posix-users/thread.rst
index 5376b64..97cd13a 100644
--- a/posix-users/thread.rst
+++ b/posix-users/thread.rst
@@ -1,7 +1,6 @@
 Thread Manager
diff --git a/posix-users/thread_cancellation.rst b/posix-users/thread_cancellation.rst
index 8576860..1db8b67 100644
--- a/posix-users/thread_cancellation.rst
+++ b/posix-users/thread_cancellation.rst
@@ -1,7 +1,6 @@
 Thread Cancellation Manager
diff --git a/posix-users/timer.rst b/posix-users/timer.rst
index b52b0ab..ca2bddf 100644
--- a/posix-users/timer.rst
+++ b/posix-users/timer.rst
@@ -1,7 +1,6 @@
 Timer Manager
diff --git a/shell/concept.rst b/shell/concept.rst
index 4fc3efd..be4795a 100644
--- a/shell/concept.rst
+++ b/shell/concept.rst
@@ -1,7 +1,6 @@
 Concept Index
diff --git a/shell/configuration_and_init.rst b/shell/configuration_and_init.rst
index 6c924a9..11fb19f 100644
--- a/shell/configuration_and_init.rst
+++ b/shell/configuration_and_init.rst
@@ -1,7 +1,6 @@
 Configuration and Initialization
diff --git a/shell/file_and_directory.rst b/shell/file_and_directory.rst
index 5cd9993..459aaf8 100644
--- a/shell/file_and_directory.rst
+++ b/shell/file_and_directory.rst
@@ -1,7 +1,6 @@
 File and Directory Commands
diff --git a/shell/function_and_variable.rst b/shell/function_and_variable.rst
index ce3dd44..955c2ba 100644
--- a/shell/function_and_variable.rst
+++ b/shell/function_and_variable.rst
@@ -1,7 +1,6 @@
 Function and Variable Index
diff --git a/shell/general_commands.rst b/shell/general_commands.rst
index f60b125..12e6647 100644
--- a/shell/general_commands.rst
+++ b/shell/general_commands.rst
@@ -1,7 +1,6 @@
 General Commands
diff --git a/shell/index.rst b/shell/index.rst
index cab3f08..23998ea 100644
--- a/shell/index.rst
+++ b/shell/index.rst
@@ -1,7 +1,6 @@
 RTEMS Shell Guide (|version|).
diff --git a/shell/memory_commands.rst b/shell/memory_commands.rst
index 921182f..708042c 100644
--- a/shell/memory_commands.rst
+++ b/shell/memory_commands.rst
@@ -1,7 +1,6 @@
 Memory Commands
diff --git a/shell/network_commands.rst b/shell/network_commands.rst
index 5561963..5deacf3 100644
--- a/shell/network_commands.rst
+++ b/shell/network_commands.rst
@@ -1,7 +1,6 @@
 Network Commands
diff --git a/shell/preface.rst b/shell/preface.rst
index 1364172..16604e5 100644
--- a/shell/preface.rst
+++ b/shell/preface.rst
@@ -1,7 +1,6 @@
 Preface
diff --git a/shell/rtems_specific_commands.rst b/shell/rtems_specific_commands.rst
index cc0b6d7..b321157 100644
--- a/shell/rtems_specific_commands.rst
+++ b/shell/rtems_specific_commands.rst
@@ -1,7 +1,6 @@
 RTEMS Specific Commands
diff --git a/user/apps/index.rst b/user/apps/index.rst
index 0875421..d2eaf95 100644
--- a/user/apps/index.rst
+++ b/user/apps/index.rst
@@ -1,7 +1,6 @@
 .. _applications:
diff --git a/user/bsps/index.rst b/user/bsps/index.rst
index 3f72c2f..d2d0da2 100644
--- a/user/bsps/index.rst
+++ b/user/bsps/index.rst
@@ -1,7 +1,6 @@
 .. _BoardSupportPackages:
diff --git a/user/ecosys/index.rst b/user/ecosys/index.rst
index 46cf97b..c051a0e 100644
--- a/user/ecosys/index.rst
+++ b/user/ecosys/index.rst
@@ -1,7 +1,6 @@
 .. _ecosystem:
diff --git a/user/exe/debugging.rst b/user/exe/debugging.rst
index 31d461b..b0733bb 100644
--- a/user/exe/debugging.rst
+++ b/user/exe/debugging.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 2018 Chris Johns <chrisj at rtems.org>
 Debugging
diff --git a/user/exe/executables.rst b/user/exe/executables.rst
index d08a48c..2aa3d8b 100644
--- a/user/exe/executables.rst
+++ b/user/exe/executables.rst
@@ -1,7 +1,6 @@
 RTEMS Executable
diff --git a/user/exe/execution.rst b/user/exe/execution.rst
index e15dbaf..2e10e5c 100644
--- a/user/exe/execution.rst
+++ b/user/exe/execution.rst
@@ -1,7 +1,6 @@
 Target Execution
diff --git a/user/exe/index.rst b/user/exe/index.rst
index d4d9167..91e0be0 100644
--- a/user/exe/index.rst
+++ b/user/exe/index.rst
@@ -1,7 +1,6 @@
 Executables
diff --git a/user/exe/initialization.rst b/user/exe/initialization.rst
index d14cb69..75cbb69 100644
--- a/user/exe/initialization.rst
+++ b/user/exe/initialization.rst
@@ -1,7 +1,6 @@
 BSP Initialization
diff --git a/user/hardware/architectures.rst b/user/hardware/architectures.rst
index c120ad2..74bdaf4 100644
--- a/user/hardware/architectures.rst
+++ b/user/hardware/architectures.rst
@@ -1,7 +1,6 @@
 Architectures
diff --git a/user/hardware/bsps.rst b/user/hardware/bsps.rst
index e1da6ba..ff82cd3 100644
--- a/user/hardware/bsps.rst
+++ b/user/hardware/bsps.rst
@@ -1,7 +1,6 @@
 .. _bsps:
diff --git a/user/hardware/index.rst b/user/hardware/index.rst
index 4d11eb2..7757a76 100644
--- a/user/hardware/index.rst
+++ b/user/hardware/index.rst
@@ -1,7 +1,6 @@
 .. _Hardware:
diff --git a/user/hardware/targets.rst b/user/hardware/targets.rst
index d2675ef..ae1cdbc 100644
--- a/user/hardware/targets.rst
+++ b/user/hardware/targets.rst
@@ -1,7 +1,6 @@
 .. _targets:
diff --git a/user/hardware/tiers.rst b/user/hardware/tiers.rst
index 40527b1..620dc26 100644
--- a/user/hardware/tiers.rst
+++ b/user/hardware/tiers.rst
@@ -1,7 +1,6 @@
 .. _tiers:
diff --git a/user/hosts/index.rst b/user/hosts/index.rst
index 54881df..e02acb4 100644
--- a/user/hosts/index.rst
+++ b/user/hosts/index.rst
@@ -1,7 +1,6 @@
 .. _host-computer:
diff --git a/user/hosts/macos.rst b/user/hosts/macos.rst
index 82c025e..de84b8d 100644
--- a/user/hosts/macos.rst
+++ b/user/hosts/macos.rst
@@ -1,7 +1,6 @@
 .. _macos:
diff --git a/user/hosts/os.rst b/user/hosts/os.rst
index d1099f8..03b512d 100644
--- a/user/hosts/os.rst
+++ b/user/hosts/os.rst
@@ -1,7 +1,6 @@
 .. _host-os:
diff --git a/user/hosts/posix.rst b/user/hosts/posix.rst
index 1428bd7..2c85919 100644
--- a/user/hosts/posix.rst
+++ b/user/hosts/posix.rst
@@ -1,7 +1,6 @@
 .. _posix-hosts:
diff --git a/user/hosts/windows.rst b/user/hosts/windows.rst
index 58c01e3..38fec97 100644
--- a/user/hosts/windows.rst
+++ b/user/hosts/windows.rst
@@ -1,7 +1,6 @@
 .. _microsoft-windows:
diff --git a/user/installation/developer.rst b/user/installation/developer.rst
index 99401fe..cea65d2 100644
--- a/user/installation/developer.rst
+++ b/user/installation/developer.rst
@@ -1,7 +1,6 @@
 .. _developer:
 .. _development-version:
diff --git a/user/installation/index.rst b/user/installation/index.rst
index 2c7cc09..6a7152d 100644
--- a/user/installation/index.rst
+++ b/user/installation/index.rst
@@ -1,7 +1,6 @@
 .. index:: Installation
 .. _installation:
diff --git a/user/installation/kernel.rst b/user/installation/kernel.rst
index 7e737fe..2f06422 100644
--- a/user/installation/kernel.rst
+++ b/user/installation/kernel.rst
@@ -1,7 +1,6 @@
 .. _rtems-kernel:
diff --git a/user/installation/prefixes-sandboxing.rst b/user/installation/prefixes-sandboxing.rst
index a42166b..6389b84 100644
--- a/user/installation/prefixes-sandboxing.rst
+++ b/user/installation/prefixes-sandboxing.rst
@@ -1,7 +1,6 @@
 .. index:: Prefixes
 .. _prefixes:
diff --git a/user/installation/releases.rst b/user/installation/releases.rst
index 61e945e..d48f68b 100644
--- a/user/installation/releases.rst
+++ b/user/installation/releases.rst
@@ -1,7 +1,6 @@
 .. _released-version:
diff --git a/user/start/index.rst b/user/start/index.rst
index 65e1a02..19f2f41 100644
--- a/user/start/index.rst
+++ b/user/start/index.rst
@@ -1,7 +1,6 @@
 .. index:: Quick Start
diff --git a/user/testing/configuration.rst b/user/testing/configuration.rst
index 181ce27..d7c0890 100644
--- a/user/testing/configuration.rst
+++ b/user/testing/configuration.rst
@@ -1,7 +1,6 @@
 Tester Configuration
diff --git a/user/testing/consoles.rst b/user/testing/consoles.rst
index f60688c..209e90e 100644
--- a/user/testing/consoles.rst
+++ b/user/testing/consoles.rst
@@ -1,7 +1,6 @@
 .. _tester-consoles:
diff --git a/user/testing/gdb-jtag.rst b/user/testing/gdb-jtag.rst
index 9ef7639..5e4d52a 100644
--- a/user/testing/gdb-jtag.rst
+++ b/user/testing/gdb-jtag.rst
@@ -1,7 +1,6 @@
 GDB and JTAG
diff --git a/user/testing/index.rst b/user/testing/index.rst
index a00eafc..1e74ba9 100644
--- a/user/testing/index.rst
+++ b/user/testing/index.rst
@@ -1,7 +1,6 @@
 Testing
diff --git a/user/testing/simulation.rst b/user/testing/simulation.rst
index 04b7ee3..1fad1a9 100644
--- a/user/testing/simulation.rst
+++ b/user/testing/simulation.rst
@@ -1,7 +1,6 @@
 Simulation
diff --git a/user/testing/tests.rst b/user/testing/tests.rst
index 6a248af..da2760e 100644
--- a/user/testing/tests.rst
+++ b/user/testing/tests.rst
@@ -1,7 +1,6 @@
 Test Banners
diff --git a/user/testing/tftp.rst b/user/testing/tftp.rst
index d32eba2..03d5a90 100644
--- a/user/testing/tftp.rst
+++ b/user/testing/tftp.rst
@@ -1,7 +1,6 @@
 TFTP and U-Boot
diff --git a/user/tools/bsp-builder.rst b/user/tools/bsp-builder.rst
index e62c9eb..baa0eed 100644
--- a/user/tools/bsp-builder.rst
+++ b/user/tools/bsp-builder.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 2017 Chris Johns <chrisj at rtems.org>
 RTEMS BSP Builder
diff --git a/user/tools/exeinfo.rst b/user/tools/exeinfo.rst
index 3c6162f..a9640d7 100644
--- a/user/tools/exeinfo.rst
+++ b/user/tools/exeinfo.rst
@@ -1,7 +1,6 @@
 RTEMS Executable Infomation
diff --git a/user/tools/index.rst b/user/tools/index.rst
index 2311e39..2e25e4f 100644
--- a/user/tools/index.rst
+++ b/user/tools/index.rst
@@ -1,7 +1,6 @@
 Host Tools
diff --git a/user/tools/linker.rst b/user/tools/linker.rst
index d628929..c8bea6e 100644
--- a/user/tools/linker.rst
+++ b/user/tools/linker.rst
@@ -1,7 +1,6 @@
 RTEMS Linker
diff --git a/user/tools/symbols.rst b/user/tools/symbols.rst
index fc54056..9156921 100644
--- a/user/tools/symbols.rst
+++ b/user/tools/symbols.rst
@@ -1,7 +1,6 @@
 RTEMS Symbols
diff --git a/user/tools/tester.rst b/user/tools/tester.rst
index 31b1f7d..410f1c0 100644
--- a/user/tools/tester.rst
+++ b/user/tools/tester.rst
@@ -1,7 +1,6 @@
 .. _rtems-tester-command:
diff --git a/user/tracing/captureengine.rst b/user/tracing/captureengine.rst
index 6522fcd..fa21210 100644
--- a/user/tracing/captureengine.rst
+++ b/user/tracing/captureengine.rst
@@ -1,7 +1,6 @@
 .. Copyright (C) 2018 Vidushi Vashishth <vidushivashishth96 at gmail.com>
 .. _capturengine:
diff --git a/user/tracing/examples.rst b/user/tracing/examples.rst
index f4dac76..eeac475 100644
--- a/user/tracing/examples.rst
+++ b/user/tracing/examples.rst
@@ -1,7 +1,6 @@
 .. _examples:
diff --git a/user/tracing/index.rst b/user/tracing/index.rst
index 98c260a..ce8e109 100644
--- a/user/tracing/index.rst
+++ b/user/tracing/index.rst
@@ -1,7 +1,6 @@
 .. _tracing-framework:
diff --git a/user/tracing/introduction.rst b/user/tracing/introduction.rst
index c112d67..b03f5d1 100644
--- a/user/tracing/introduction.rst
+++ b/user/tracing/introduction.rst
@@ -1,7 +1,6 @@
 .. _introduction:
diff --git a/user/tracing/tracelinker.rst b/user/tracing/tracelinker.rst
index 0bcc26c..4c3ede5 100644
--- a/user/tracing/tracelinker.rst
+++ b/user/tracing/tracelinker.rst
@@ -1,7 +1,6 @@
 .. _tracelinker:
2.16.4
