[PATCH] Replace build date with Git hash and commit date
Thu Jan 10 08:21:57 UTC 2019
On 10/01/2019 09:19, Sebastian Huber wrote:
> On 10/01/2019 00:42, Chris Johns wrote:
>> On 9/1/19 7:24 pm, Sebastian Huber wrote:
>>> The usage of a build date prevents reproducible builds.
>> Sorry to revisit this change. I have reviewed the generated the docs
>> and they
>> look good and the changes are welcome, thank you. I would like to ask
>> a few
>> questions.
>> 1. Can the hash be the short version? I am seeing in the PDF in the
>> page header:
>>   Release 5.0.0.05d066a08fe840f6f926bf6d2f3f3c0ebd6cc603 (9th January
>> 2019)
>> which is correct but the page header is now 2 lines and a line on a
>> page in the
>> PDF is precious. In the Classic API manual at 716 pages this is 716
>> extra lines.
>> Can we use a shortened hash?
> I played a bit around view various variants. One problem I had is in
> case the version line is long but not enough for two lines, then it
> overlaps the chapter number in the header. If you want a one liner,
> then the chapter number, the document title and the version must fit
> into it. I think this is only possible if we drop the date, use a
> short hash and cut down some document titles (or use a smaller font
> size).
We have to take also the hash-modified modifier into account if you
build with a non-clean Git checkout.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
