Tool Build Failures for rtems6
Thu Jan 10 10:33:54 UTC 2019
On 08/01/2019 16:04, Joel Sherrill wrote:
> Hi
> Chris appears to have some broad issue but I had better luck on CentOS
> 7. Only the Epiphany failed and this doesn't look RTEMS specific.
> ../../../../../gnu-mirror-gcc-1c2a6eef8661753ce316c46c55c7bb8c4e593943/libstdc++-v3/src/c++17/memory_resource.cc:
> In member function 'void
> std::pmr::monotonic_buffer_resource::_M_new_buffer(std::size_t,
> std::size_t)':
> ../../../../../gnu-mirror-gcc-1c2a6eef8661753ce316c46c55c7bb8c4e593943/libstdc++-v3/src/c++17/memory_resource.cc:235:62:
> error: static assertion failed
>   235 |  static_assert(alignof(monotonic_buffer_resource::_Chunk) == 1);
> make[5]: *** [memory_resource.lo] Error 1
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=88789
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
