[PATCH 3/3] rsb: Move content of duplicate section
Thu Jan 10 11:52:25 UTC 2019
Move "Controlling the Tools Build" section and "Building Tools and
RTEMS" chapter to "Project Sets" chapter and "RTEMS" section.
 rsb/building-tools-and-rtems.rst | 37 -------------------------------------
 rsb/index.rst                    |  1 -
 rsb/project-sets.rst             | 24 ++++++++++++++++++++++++
 rsb/source-builder.rst           | 28 ----------------------------
 4 files changed, 24 insertions(+), 66 deletions(-)
 delete mode 100644 rsb/building-tools-and-rtems.rst
diff --git a/rsb/building-tools-and-rtems.rst b/rsb/building-tools-and-rtems.rst
deleted file mode 100644
index 3c4c09a..0000000
--- a/rsb/building-tools-and-rtems.rst
+++ /dev/null
@@ -1,37 +0,0 @@
-.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2012, 2018 Chris Johns <chrisj at rtems.org>
-Building Tools and RTEMS
-The Quick Start section of the RTEMS Users Guide covers the typical
-information and process needed to build both an RTEMS toolset and
-RTEMS itself. This section has information on specific configuration
-options that may be needed.
-Controlling the Build
-Build sets can be controlled via the command line to enable and disable various
-features. There is no definitive list of build options that can be listed
-because they are implemented with the configuration scripts. The best way to
-find what is available is to grep the configuration files. for ``with`` and
-``without``.
-Following are currently available:
-``--without-rtems``
-  Do not build RTEMS when building an RTEMS build set.
-``--without-cxx``
-  Do not build a C++ compiler.
-``--with-ada``
-  Attempt to build an Ada compiler.  You need a native GNAT installed.
-``--with-fortran``
-  Attempt to build a Fortran compiler.
-``--with-objc``
-  Attempt to build a C++ compiler.
diff --git a/rsb/index.rst b/rsb/index.rst
index 0452c45..f4594ed 100644
--- a/rsb/index.rst
+++ b/rsb/index.rst
@@ -29,7 +29,6 @@ RTEMS Source Builder (|version|).
     source-builder
     why-build-from-source.rst
-    building-tools-and-rtems.rst
     project-sets
     cross-canadian-cross
     third-party-packages
diff --git a/rsb/project-sets.rst b/rsb/project-sets.rst
index ed9db9b..cc63aaa 100644
--- a/rsb/project-sets.rst
+++ b/rsb/project-sets.rst
@@ -29,6 +29,12 @@ various tools. You can specialise these in your private configurations to make
 use of them. If you add new generic configurations please contribute them back
 to the project
+Build sets can be controlled via the command line to enable
+(``--with-<feature>``) and disable (``--without-<feature>``) various features.
+There is no definitive list of build options that can be listed because they
+are implemented with the configuration scripts.  The best way to find what is
+available is to grep the configuration files for ``with`` and ``without``.
 Bare Metal
@@ -134,6 +140,24 @@ and the following uses the version control heads for ``binutils``, ``gcc``,
        --macros=snapshots/binutils-gcc-newlib-gdb-head.mc \
        4.11/rtems-sparc
+Following features can be enabled/disabled via the command line for the RTEMS
+build sets:
+``--without-rtems``
+  Do not build RTEMS when building an RTEMS build set.
+``--without-cxx``
+  Do not build a C++ compiler.
+``--with-ada``
+  Attempt to build an Ada compiler.  You need a native GNAT installed.
+``--with-fortran``
+  Attempt to build a Fortran compiler.
+``--with-objc``
+  Attempt to build a C++ compiler.
 Patches
diff --git a/rsb/source-builder.rst b/rsb/source-builder.rst
index 81e4ea8..9b2f096 100644
--- a/rsb/source-builder.rst
+++ b/rsb/source-builder.rst
@@ -76,31 +76,3 @@ configuration can read the remaining sections.
    If you think you have found a problem please see :ref:`Bugs, Crashes, and
    Build Failures`.
-Controlling the Tools Build
-``without``.
-``--without-cxx``
-``--with-ada``
-``--with-fortran``
-``--with-objc``
2.16.4
