[PATCH] psxhdrs: Add POSIX API Signature Compliance Tests for aio.h
Jacob Shin
jacobshin313 at gmail.com
Fri Jan 11 03:28:37 UTC 2019
testsuites/psxtests/Makefile.am | 10 +++-
testsuites/psxtests/psxhdrs/aio/aio_cancel.c | 49 +++++++++++++++++
testsuites/psxtests/psxhdrs/aio/aio_error.c | 53 +++++++++++++++++++
testsuites/psxtests/psxhdrs/aio/aio_fsync.c | 49 +++++++++++++++++
testsuites/psxtests/psxhdrs/aio/aio_read.c | 52 ++++++++++++++++++
testsuites/psxtests/psxhdrs/aio/aio_return.c | 53 +++++++++++++++++++
testsuites/psxtests/psxhdrs/aio/aio_suspend.c | 52 ++++++++++++++++++
testsuites/psxtests/psxhdrs/aio/aio_write.c | 52 ++++++++++++++++++
testsuites/psxtests/psxhdrs/aio/lio_listio.c | 51 ++++++++++++++++++
9 files changed, 420 insertions(+), 1 deletion(-)
create mode 100755 testsuites/psxtests/psxhdrs/aio/aio_cancel.c
create mode 100755 testsuites/psxtests/psxhdrs/aio/aio_error.c
create mode 100755 testsuites/psxtests/psxhdrs/aio/aio_fsync.c
create mode 100755 testsuites/psxtests/psxhdrs/aio/aio_read.c
create mode 100755 testsuites/psxtests/psxhdrs/aio/aio_return.c
create mode 100755 testsuites/psxtests/psxhdrs/aio/aio_suspend.c
create mode 100755 testsuites/psxtests/psxhdrs/aio/aio_write.c
create mode 100755 testsuites/psxtests/psxhdrs/aio/lio_listio.c
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 3b1c36338a..f1c4f43a0d 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1826,7 +1826,15 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
psxhdrs/sys/select/FD_SET.c \
psxhdrs/sys/select/FD_ZERO.c \
psxhdrs/sys/select/pselect.c \
- psxhdrs/sys/select/select.c
+ psxhdrs/sys/select/select.c \
+ psxhdrs/aio/aio_read.c \
+ psxhdrs/aio/aio_error.c \
+ psxhdrs/aio/aio_cancel.c \
+ psxhdrs/aio/aio_write.c \
+ psxhdrs/aio/aio_fsync.c \
+ psxhdrs/aio/aio_return.c \
+ psxhdrs/aio/aio_suspend.c \
+ psxhdrs/aio/lio_listio.c
## Not supported by RTEMS, but POSIX API Compliance tests exist.
## lib_a_SOURCES += psxhdrs/ulimit/ulimit.c
diff --git a/testsuites/psxtests/psxhdrs/aio/aio_cancel.c b/testsuites/psxtests/psxhdrs/aio/aio_cancel.c
new file mode 100755
index 0000000000..78f312eb27
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/aio/aio_cancel.c
@@ -0,0 +1,49 @@
+ * @file
+ * @brief aio_cancel() API Conformance Test
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 Jacob Shin
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <aio.h>
+int test( void );
+int test( void )
+ int return_value;
+ int fildes = -1;
+ struct aiocb *aiocbp = NULL;
+ return_value = aio_cancel(fildes, aiocbp);
+ return (return_value != -1);
\ No newline at end of file
diff --git a/testsuites/psxtests/psxhdrs/aio/aio_error.c b/testsuites/psxtests/psxhdrs/aio/aio_error.c
index 0000000000..1e0fed821f
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/aio/aio_error.c
@@ -0,0 +1,53 @@
+ * @file
+ * @brief aio_error() API Conformance Test
+ * are met:
+#endif
+#include <aio.h>
+int test( void );
+int test( void )
+ int return_value;
+ struct aiocb aiocbp;
+ char buf[1];
+ aiocbp.aio_fildes = -1;
+ aiocbp.aio_nbytes = 1;
+ aiocbp.aio_buf = &buf;
+ aio_read(&aiocbp);
+ return_value = aio_error(&aiocbp);
diff --git a/testsuites/psxtests/psxhdrs/aio/aio_fsync.c b/testsuites/psxtests/psxhdrs/aio/aio_fsync.c
index 0000000000..bdb15e94fc
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/aio/aio_fsync.c
@@ -0,0 +1,49 @@
+ * @file
+ * @brief aio_fsync() API Conformance Test
+ * are met:
+#endif
+#include <aio.h>
+int test( void );
+int test( void )
+ int return_value;
+ int op = O_SYNC;
+ return_value = aio_fsync(op, &aiocbp);
diff --git a/testsuites/psxtests/psxhdrs/aio/aio_read.c b/testsuites/psxtests/psxhdrs/aio/aio_read.c
index 0000000000..e3e7aaeefe
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/aio/aio_read.c
@@ -0,0 +1,52 @@
+ * @file
+ * @brief aio_read() API Conformance Test
+ * are met:
+#endif
+#include <aio.h>
+int test( void );
+int test( void )
+ int return_value;
+ char buf[1];
+ return_value = aio_read(&aiocbp);
diff --git a/testsuites/psxtests/psxhdrs/aio/aio_return.c b/testsuites/psxtests/psxhdrs/aio/aio_return.c
index 0000000000..d638dd142a
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/aio/aio_return.c
@@ -0,0 +1,53 @@
+ * @file
+ * @brief aio_return() API Conformance Test
+ * are met:
+#endif
+#include <aio.h>
+int test( void );
+int test( void )
+ int return_value;
+ char buf[1];
+ return_value = aio_return(&aiocbp);
diff --git a/testsuites/psxtests/psxhdrs/aio/aio_suspend.c b/testsuites/psxtests/psxhdrs/aio/aio_suspend.c
index 0000000000..3834754dda
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/aio/aio_suspend.c
@@ -0,0 +1,52 @@
+ * @file
+ * @brief aio_suspend() API Conformance Test
+ * are met:
+#endif
+#include <aio.h>
+int test( void );
+int test( void )
+ int return_value;
+ const struct aiocb *list[1] = {NULL};
+ int nent = 1;
+ struct timespec timeout;
+ timeout.tv_sec = 1;
+ timeout.tv_nsec = 0;
+ return_value = aio_suspend(list, nent, &timeout);
diff --git a/testsuites/psxtests/psxhdrs/aio/aio_write.c b/testsuites/psxtests/psxhdrs/aio/aio_write.c
index 0000000000..711eb43323
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/aio/aio_write.c
@@ -0,0 +1,52 @@
+ * @file
+ * @brief aio_write() API Conformance Test
+ * are met:
+#endif
+#include <aio.h>
+int test( void );
+int test( void )
+ int return_value;
+ char buf[1];
+ return_value = aio_write(&aiocbp);
diff --git a/testsuites/psxtests/psxhdrs/aio/lio_listio.c b/testsuites/psxtests/psxhdrs/aio/lio_listio.c
index 0000000000..fba0362df3
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/aio/lio_listio.c
@@ -0,0 +1,51 @@
+ * @file
+ * @brief lio_listio() API Conformance Test
+ * are met:
+#endif
+#include <aio.h>
+int test( void );
+int test( void )
+ int return_value;
+ struct aiocb *list[1] = {NULL};
+ int nent = 1;
+ int mode = LIO_NOWAIT;
+ struct sigevent *sig = NULL;
+ return_value = lio_listio(mode, list, nent, sig);
2.17.1
