rtems-test : getting result invalid
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Jan 13 06:55:18 UTC 2019
On Sun, 13 Jan 2019 at 08:41, Chris Johns <chrisj at rtems.org> wrote:
> On 13/1/19 7:19 am, Vijay Kumar Banerjee wrote:
> > With the recent change to the qemu options I'm getting results invalid
> when
> > running rtems-test without the coverage option. However, it works fine
> when the
> > coverage option is enabled.
> What are the command lines for each run?
> $HOME/development/rtems/rtems-tools/tester/rtems-test \
--rtems-tools=$HOME/development/rtems/5 \
--log=coverage_analysis.log \
--rtems-bsp=leon3-qemu-cov \
/home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples
I'm also attaching the log file.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190113/c7461682/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190113/c7461682/attachment-0001.bin>
