Zynq RTEMS 5 SMP Crashing on call to connect in socket.h [Solved]
Tue Jan 15 07:30:17 UTC 2019
On 15/01/2019 08:24, Misra, Avinash wrote:
> Thank you for your response. I was using a custom scheduler configuration because of one of the RTEM smp examples I saw.
How did you find the examples? Are they in the RTEMS smptests? Did you
read the SMP chapter in the documentation
https://docs.rtems.org/branches/master/c-user/symmetric_multiprocessing_services.html
? I ask because you should select a custom scheduler configuration only
for specific reasons and this should be clear from the documentation.
> I didn't realize that it would end up affecting BSD and the networking protocol.
FreeBSD introduced the Epoch Based Reclamation in version 12 and
unfortunately it is not easy to support in RTEMS.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
