[PATCH] Fix 'build_max_size_human' ref. before assignment
Tue Jan 15 12:31:56 UTC 2019
On 13/01/2019 23:17, Chris Johns wrote:
> On 14/1/19 8:05 am, Chris Johns wrote:
>> On 11/1/19 4:31 pm, Sebastian Huber wrote:
>>> ----- Am 11. Jan 2019 um 0:11 schrieb Chris Johns chrisj at rtems.org:
>>>> On 10/1/19 11:17 pm, Sebastian Huber wrote:
>>>>> This patch resulted in this mail report issue:
>>>>> Your mail to 'build' with the subject
>>>>>      Build Linux: FAILED 6/rtems-epiphany on x86_64-linux-gnu
>>>>> (epiphany-rtems6-gcc-76fb04650b2bacd33eaff257f08fabcc237ec885-newlib-fbd3835384fa586fd32ce80280d81bb51ab042ba-x86_64-linux-gnu-1)
>>>>> Is being held until the list moderator can review it for approval.
>>>>> The reason it is being held:
>>>>>      Message body is too big: 1093190 bytes with a limit of 256 KB
>>>> Are you asking for the size limit on the list to be raised?
>>> No, but is this the normal size for a failed report?
>> It should not be. I will accept the post and then we can see the reason.
> The report captures the last part of the build and it looks like the lines in
> the section of the libstdc++ library being built are long. The use of full
> length hashes in gcc and newlib has increased the path lengths.
> I increased the number of lines captured a while ago because the number of cores
> being used when building meant distance in the output between the error and the
> end of the log can be a long way.
> Maybe a smarter parser should be added and just the error logged?
When I look for tool chain build errors I simply go to the end of the
log file and then search backwards for "error:".
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
