RISC-V sis config file for rtems-test
Jiri Gaisler
jiri at gaisler.se
Wed Jan 16 18:56:05 UTC 2019
Attached is a config file for rtems-test, that allows running the RISC-V
sis simulator like this:
rtems-test --rtems-bsp=riscv-sis riscv-rtems5/c/grlib/testsuites
Jiri.
# RTEMS Tools Project (http://www.rtems.org/)
# Copyright 2015 On-Line Applications Research Corporation (OAR).
# All rights reserved.
# This file is part of the RTEMS Tools package in 'rtems-tools'.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
# 1. Redistributions of source code must retain the above copyright notice,
# this list of conditions and the following disclaimer.
# 2. Redistributions in binary form must reproduce the above copyright notice,
# this list of conditions and the following disclaimer in the documentation
# and/or other materials provided with the distribution.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
# POSSIBILITY OF SUCH DAMAGE.
# The RISC-V grlib BSP
[riscv-sis]
bsp = grlib
arch = riscv
tester = %{_rtscripts}/run.cfg
bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
bsp_run_opts = -nouartrx -r -tlim 300 s -freq 50 -m 4
